Doesn't work properly at uni wifi
Hi, I recently bought a new laptop and the first thing I did was install manjaro.
Internet works well at home wifi but doesn’t at uni for more than 3 minutes, I have to keep constantly changing between the two networks there to keep using it (one of them being eduroam).
Usually the speed at the panel just drops to 0 kbps no matter what I do
Use the search function looking for eduroam. It will give you maybe some hints.
However, it it really works for a few minutes and then fails, it seems more like a network problem and not a device issue.
And I’ve seen enough eduroam issues here to have an opinion as to what’s causing it…
