Installed new Kernel 5.13, but after reboot it’s still stuck at older Kernel 5.12:
It’s a dual-boot system with two Manjaro KDE partitions.
Already updated to Kernel 5.13 on the other (first) partition sucessfully, because it will only switch to newer Kernel on second partition if the first partition is already on new Kernel.
This is, because the first install owns grub?
But now it doesn’t switch to newest Kernel anymore on partition 2 (second Manjaro KDE install).
I uninstalled Kernel 5.12 while using it to force 5.13, but no reboot anymore, had to reboot manually with Kernel 5.10 to install 5.12 again to be able to boot.
How can this be solved?
How can i set ownership of grub to the second installation?
Already tried update-grub
Please help.
System: Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: A300M-STX serial: <filter> UEFI: American Megatrends v: P3.60K date: 07/22/2020
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP cache: L2: 2 MiB
Speed: 1277 MHz min/max: 1400/3400 MHz Core speeds (MHz): 1: 1277 2: 1361 3: 1255 4: 1262 5: 1278 6: 1272 7: 1261
8: 1262
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.19-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.1
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
Drives: Local Storage: total: 1013.5 GiB used: 350.25 GiB (34.6%)
ID-1: /dev/nvme0n1 vendor: Silicon Power model: SPCC M.2 PCIe SSD size: 953.87 GiB
ID-2: /dev/sda type: USB vendor: Crucial model: M4-CT064M4SSD1 size: 59.63 GiB
Partition: ID-1: / size: 468.3 GiB used: 350.25 GiB (74.8%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0
Info: Processes: 243 Uptime: 16m Memory: 23.47 GiB used: 1.84 GiB (7.9%) Shell: Bash inxi: 3.3.06
