I’m looking at this laptop, it seems pretty cool:
Lenovo V14 G2 82KA002VGE
It has the Intel Core i5-1135G7 chipset, has anyone run Manjaro on this yet?
When I got my last laptop with an i7 10th gen CPU (I got it pretty early after release though), it took a good 3-5 months for the kernel to support everything nicely.
Would be even greater to have report on this specific laptop model, of course…
hi
manjaro works absolutely fine. i am running 5.10 lts. got this in march 2021
Thanks! May I just ask, what model and make is your computer?
dell inspiron 5502
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=edf1fd96-32cf-4167-b3ec-fc5c0406d7fa rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 5502 v: N/A
Mobo: Dell model: 0HWH1N v: A00 serial: <superuser required> UEFI: Dell
v: 1.8.0 date: 10/01/2021
ID-1: BAT0 charge: 24.6 Wh (46.4%) condition: 53.0/53.0 Wh (100.0%)
volts: 14.6 min: 15.0 model: SMP DELL 9077G0A type: Li-poly serial: <filter>
status: Discharging
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2247 high: 2365 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2306 2: 2136 3: 2285
4: 2287 5: 2365 6: 2329 7: 2119 8: 2153 bogomips: 22120
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:2c:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp44s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 0cf3:e007 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 67.28 GiB (14.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 10410106 temp: 64.8 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 67.28 GiB (14.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2569
Processes: 267 Uptime: 11m wakeups: 230 Memory: 7.5 GiB
used: 2.62 GiB (35.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1273 lib: 339 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.11
OMK80
31 December 2021 10:45
5
Hello ishaanbhimwal, i was just wondering if you had to switch to AHCI in your bios somehow to get this working, or did it work right out of the box?
I tried everything i could but it kept saying to drive detected because of the Intel Volume Management Device being set to RAID by default, if you can help it will be much appreciated
no. i am running on raid only.
OMK80
31 December 2021 18:19
7
Oh ok then you have 2 drives on RAID-0, somehow i have RAID ON with 1 HDD and cannot disable due to hp locking the bios lol.
system
Closed
3 January 2022 08:20
8
