Does Manjaro for WSL2 using wsldl come with a GUI pre-installed?
Firstly I’m accessing manjaro on windows via wsl so I have to start any GUI apps from the terminal. Is there a GUI pre-installed or do I have to install one with pacman?
That is Windows Subsystem for Linux … not Manjaro.
The 3 official Desktop Environments provided with the ISO are fully functional GUIs as can be seen in download page Manjaro - Downloads
If you are referring to this project
is not done by any of Manjaro team members … so, ask more about on their project page.
OK, thanks bogdan. I am using the sileshn download.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
OK Fabby, thanks.
