Does Krita work on any arm release?
I am considering getting a VIM3 Pro to run Manjaro but I am confused about the status of Krita. Will it work on any Manjaro amlogic release?
From back 2017 - this is what Boudewijn said
Then, since here
https://archlinuxarm.org/packages
if you put Krita in the search box you find it, even the gmic plugin, it means it should work. :slight_smile:
Krita does work. But only if you use the regular qt5 packages and not the qt5-es2 packages we ship with our Plasma edition.
But like said above, it might be very slow. :slight_smile:
bogdancovaciu and Strit thanks very much for your replies. I think I will wait until I can buy a SFF Ryzen 4xxx.
