Hi all!
It’s my first time posting here, let me know if I missed something.
I just installed manjaro by replacing my old debian luks partition by the manjaro luks thanks to the installer (great work, it was super smooth).
However, I encounter issues with docker.
The installation of docker works perfectly (docker run hello world works) through the AUR or Snap but both cases seem to have issues with storage, each time I need to have shared volumes or download a larger docker it breaks with “No storage left”.
This issue is known on Arch: hxxps://wiki.archlinux.org/title/Docker#Failed_to_create_some/path/to/file:_No_space_left_on_device
However, I am not sure how to debug this. My computer has enough space and there seems to have tmpfs partition:
TARGET SOURCE FSTYPE OPTIONS
/ /dev/mapper/luks-dcfb534e-d8ae-4692-af4c-1fab61b01056 ext4 rw,noatime
├─/proc proc proc rw,nosuid,nodev,noexec,relatime
│ └─/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18434
├─/sys sys sysfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
│ ├─/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
│ ├─/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700
│ ├─/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
│ └─/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime
├─/dev dev devtmpfs rw,nosuid,relatime,size=12178116k,nr_inodes=3044529,mode=755,inode64
│ ├─/dev/shm tmpfs tmpfs rw,nosuid,nodev,inode64
│ ├─/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
│ ├─/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M
│ └─/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime
├─/run run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64
│ └─/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=2438100k,nr_inodes=609525,mode=700,uid=1000,gid=1000,inode64
│ └─/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
├─/tmp tmpfs tmpfs rw,nosuid,nodev,nr_inodes=409600,inode64
├─/boot/efi /dev/nvme0n1p1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
├─/var/lib/snapd/snap/gtk-common-themes/1515 /dev/loop0 squashfs ro,nodev,relatime
├─/var/lib/snapd/snap/core18/2074 /dev/loop2 squashfs ro,nodev,relatime
├─/var/lib/snapd/snap/snap-store/547 /dev/loop1 squashfs ro,nodev,relatime
├─/var/lib/snapd/snap/snapd/12704 /dev/loop3 squashfs ro,nodev,relatime
└─/var/lib/snapd/snap/gnome-3-34-1804/72 /dev/loop4 squashfs ro,nodev,relatime
I have another computer where I installed Manjaro on a clean disk and didn’t encounter this issue.
Have you already encountered such an issue?
uname: Linux xyz 5.10.53-1-MANJARO #1 SMP PREEMPT Mon Jul 26 07:18:28 UTC 2021 x86_64 GNU/Linux
