Hi, Manjaro team!
I’m on the unstable
branch, KDE
, ordinary ISO (not minimal
version).
I just got the batch of updates:
$ tail /var/log/pacman.log
[2021-07-26T21:56:58+0300] [PACMAN] starting full system upgrade
[2021-07-26T21:58:11+0300] [ALPM] transaction started
[2021-07-26T21:58:12+0300] [ALPM] removed jack (0.125.0-9)
[2021-07-26T21:58:12+0300] [ALPM] installed celt (0.11.3-4)
[2021-07-26T21:58:12+0300] [ALPM] installed jack2 (1.9.19-2)
[2021-07-26T21:58:12+0300] [ALPM] upgraded poppler (21.07.0-2 -> 21.07.0-3)
[2021-07-26T21:58:12+0300] [ALPM] upgraded poppler-glib (21.07.0-2 -> 21.07.0-3)
[2021-07-26T21:58:12+0300] [ALPM] upgraded poppler-qt5 (21.07.0-2 -> 21.07.0-3)
[2021-07-26T21:58:12+0300] [ALPM] transaction completed
[2021-07-26T21:58:12+0300] [ALPM] running '30-systemd-update.hook'...
$ pacman -Si celt
Repository : extra
Version : 0.11.3-4
Description : Low-latency audio communication codec
Architecture : x86_64
URL : https://gitlab.xiph.org/xiph/celt
Licenses : BSD
Groups : None
Provides : libcelt0.so=2-64
Depends On : libogg
Optional Deps : None
Conflicts With : None
Replaces : None
Download Size : 73.68 KiB
Installed Size : 175.89 KiB
Packager : Jan Alexander Steffens (heftig) <<hidden>>
Build Date : Thu 07 May 2020 21:01:33 EEST
Validated By : MD5 Sum SHA-256 Sum Signature
on the page by the URL above I got the package repo w/ the latest commit (in the master
branch) of:
14 Sep, 2011 1 commit
Direct users at the opus repository.
Ralph Giles authored 9 years ago
This repository is no longer used for active development.
Do we really need the outdated (cause 10 years w/o fixes and features in lossy audio matters) celt
package?
Why we need the package?
$ pacman -Si jack2
Repository : extra
Version : 1.9.19-2
Description : The JACK low-latency audio server
URL : https://github.com/jackaudio/jack2
Licenses : GPL2 LGPL2.1
Groups : None
Provides : jack libjack.so=0-64 libjacknet.so=0-64 libjackserver.so=0-64
Depends On : db gcc-libs glibc opus libasound.so=2-64 libcelt0.so=2-64 libdbus-1.so=3-64 libreadline.so=8-64
libsamplerate.so=0-64 libsndfile.so=1-64 libsystemd.so=0-64 libzita-alsa-pcmi.so=0-64
libzita-resampler.so=1-64
Optional Deps : a2jmidid: for ALSA MIDI to JACK MIDI bridging
libffado: for firewire support using FFADO
jack2-dbus: for dbus integration
realtime-privileges: for realtime privileges
zita-ajbridge: for using multiple ALSA devices
Conflicts With : jack
Replaces : jack
Download Size : 588.02 KiB
Installed Size : 2678.28 KiB
Packager : David Runge <<hidden>>
Build Date : Mon 26 Jul 2021 20:15:38 EEST
If we need some functionality from the celt
, then why not to use more modern opus
(www.opus-codec.org) instead?
Thanks!
