Do I need a VPN?
Using the following implementation:
Linux galago 5.15.7-1-MANJARO #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021 x86_64 GNU/Linux
I wonder if I should be using a VPN? I use TLS for mail and have configured Firefox to always use HTTPS, and if I need to, I can boot into Tails… Also, based on my forum search I see quite a few commets about difficulty folks seem to have.
Is it worth it? Is it the smart thing to do?
thx
Reid
Thx
Reid
Do you trust the VPN provider more than your Internet provider?
Do you need to (pretend) to be in a different country?
Do you use dodgy cafe wifi connections?
If you don’t know if you need one, then we don’t know either.
That’s because this is a support forum, not Reddit.
If you need help with installing VPN software or configuring a VPN, feel free to create a new forum topic.
