Hi.
I regularly encounter the following command to cause 99% cpu load in longer periods of time, and I’m starting to wonder if this is some misconfiguration/bug or the like.
/usr/bin/dnsmasq -k --enable-dbus --user=dnsmasq --pid-file
It is rather annoying as it is obviously is causing fans to spin at full speed.
Is it normal? If not, what could be the cause and a fix to it?
Cheers!
