I make any changes in the /etc/firejail path, after updating firejail, the settings are reset
For example, changes in the chromium profile in the path
/etc/firejail/chromium.profile
I apply it, but after the update, the changes are lost
How to save changes?
Normally, you should have a firejail
directory/folder in your home directory somewhere. Either it will be a hidden directory whose name starts with a period — i.e. ~/.firejail
— or it will be under ~/.config
somewhere, or perhaps under the ~/.mozilla
or ~/.firefox
directories.
It is there that you should make your modifications. GNU/Linux is a multiuser operating system, and anything under /etc
is for system-wide configuration, not user-specific configuration changes.
