The audio is very quiet for and I don’t know how to make it louder. I am mainly a Windows user and don’t know how to do much.
CPU: i5-10600
GPU: Intel UHD Graphics 630
RAM: 16GB
Motherboard: Gigabyte H410 H
Desktop: KDE Plasma
The single speakers I have are built in my monitor and they are affected too
Headphones are bluetooth but my bluetooth dosen’t work on linux because of the adaptor that I use, so I am using a wire without any volume control
Info on hardware used and desktop environment (inxi -Fazy)?
What did you already try?
The builtin speakers are not affected?
… we do not even know whether your system has speakers …
Headphones may have a volume adjust on the cable …
You told us virtually nothing.
CPU: i5-10600
RAM: 16GB
Desktop: KDE Plasma
What I suggested to post was the output of:
inxi -Fazy
and please format the output using the code tag → this symbol: </>
it contains much more information than what you provided
and may give someone a clue as to how to help you
Info: model: Intel Core i5-10600 bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 3 microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1494 high: 3879 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 3879
4: 2824 5: 1522 6: 969 7: 799 8: 800 9: 800 10: 800 11: 800 12: 3140
bogomips: 79235
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
you need to try again - that was not nearly all the output - and it was not formatted using the </> (code) tag
Sorry for wasting your time after a restart the audio went back loud again, the single thing I want to know is where is the button to delete the post I can’t find it.
that is because it does not exist …
But I don’t actually think that is so
But it may be so for the initial post - I don’t know.
Mark your issue as solved
and be done with it.
Deleting or editing your posts would leave all the replies being useless and without context …
