ye_0
February 8, 2023, 4:41pm
1
Hey Guys!
every time i start my computer i need to manually do startx via TTY2 because it hangs on a black screen, after i run startx everything works (kinda), is there any way to fix it, im still kinda a noobie with linux so if you want any logs just tell me how to get them and i will post them, thx
Joe_Ge
February 8, 2023, 4:57pm
2
Seems you need a display manager like lightdm or sddm.
Install it and restart.
ye_0
February 8, 2023, 5:03pm
3
i installed lightdm via pacman and after a quick restart it fixed nothing…
Joe_Ge
February 8, 2023, 5:18pm
4
You may need to activate it with
sudo systemctl enable lightdm -f
Just installing a display manager isn’t enough.
It needs to be set so it starts every time.
systemctl status display-manager.service
But KDE already comes with sddm
- look for that name in the output of the above command.
Perhaps it just doesn’t start for some reason.
Be sure you didn’t install and enable a second one
you mentioned lightdm
that will create problems when two are active at the same time.
Hardware info for all to see what you are dealing with would be good:
inxi -Fazy
ye_0
February 8, 2023, 5:29pm
6
yeah, i uninstalled sddm and tried it but still isnt working, so i just removed that again and installed sddm again, will try the above mentioned now
ye_0
February 8, 2023, 5:30pm
7
i did systemctl status with display-manager and sddm and both showed enabled and had no problems shown
I can’t help now.
And others will need details …
