i am trying to install openrazer-driver/3.2.0 and this is the output that i get :
Building module:
cleaning build area...
KERNELDIR=/lib/modules/5.16.2-2-rt19-MANJARO/build make driver...(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.16.2-2-rt19-MANJARO (x86_64)
Consult /var/lib/dkms/openrazer-driver/3.2.0/build/make.log for more information.
am new in this distribution and i got no idea about how to fix this problem…
another problem that i get is when i boot the pc and it say :
mount:/ sys/firmaware/efi/efivarfas: unkown filesystem type 'efivarfs'.
i hava secure boot disabled and am booting the system without uefi
could please someone help me
cat /var/lib/dkms/openrazer-driver/3.2.0/build/make.log output:
:: Compiling OpenRazer kernel modules
make -C /lib/modules/5.16.2-2-rt19-MANJARO/build M=/var/lib/dkms/openrazer-driver/3.2.0/build/driver modules
make[1]: se entra en el directorio '/usr/lib/modules/5.16.2-2-rt19-MANJARO/build'
CC [M] /var/lib/dkms/openrazer-driver/3.2.0/build/driver/razerkbd_driver.o
cc1: error: incompatible gcc/plugin versions
cc1: error: failed to initialize plugin ./scripts/gcc-plugins/structleak_plugin.so
make[2]: *** [scripts/Makefile.build:287: /var/lib/dkms/openrazer-driver/3.2.0/build/driver/razerkbd_driver.o] Error 1
make[1]: *** [Makefile:1846: /var/lib/dkms/openrazer-driver/3.2.0/build/driver] Error 2
make[1]: se sale del directorio '/usr/lib/modules/5.16.2-2-rt19-MANJARO/build'
make: *** [Makefile:41: driver] Error 2
