Displays Randomly goes black
Hello all,
My initial thought is that my GPU is just dying (or PSU?), but wanted to get a second opinion before I spend money.
I normally have my desktop on 24/7
On Kernel 6.6, I updated to Stable 2024-09-02. Then turned of my desktop and went away for the weekend.
Came back, booted, and I don’t remember the displays turning on for bios post.
I forced restarted twice to get displays on.
After that, the GPU seems to crash at random times.
  • Displays will turn black while in use
  • Displays will refuse to turn on after screens go to sleep
Its all random, sometimes it survives the night, sometimes it happens during the day
I do not use suspend or sleep on the OS.
I installed Kernel 6.10 and same problems.
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
    root=UUID=ff83e47a-360c-45ae-a427-8463948ff5e3 rw rootflags=subvol=@
    quiet apparmor=1 security=apparmor
    resume=UUID=3d2db8bd-b1cb-41f7-b74e-38717333fc45 udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop Mobo: ASRock model: X570 Steel Legend
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: P3.80 date: 08/04/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 64 GiB available: 62.72 GiB used: 8.54 GiB (13.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 32 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3600 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2195 min/max: 2200/4559 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2195 2: 2195 3: 2195
    4: 2195 5: 2195 6: 2195 7: 2195 8: 2195 9: 2195 10: 2195 11: 2195 12: 2195
    13: 2195 14: 2195 15: 2195 16: 2195 bogomips: 124621
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-1
    code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3 empty: DP-1,HDMI-A-1
    bus-ID: 10:00.0 chip-ID: 1002:731f class-ID: 0300
  Device-2: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:3 chip-ID: 046d:082c
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
    s-diag: 1407mm (55.38")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Acer XV272U V
    serial: <filter> built: 2022 res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red:
    x: 0.678 y: 0.310 green: x: 0.267 y: 0.663 blue: x: 0.149 y: 0.051 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1280x1440,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,left
    model: Dell S2719DGF serial: <filter> built: 2019 res: 2560x1440 dpi: 109
    gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.314 y: 0.627 blue:
    x: 0.137 y: 0.043 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 18.1.8 DRM 3.57 6.10.6-10-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:731f surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 10:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-04946d584ed3 state: down mac: <filter>
  IF-ID-2: br-28c645223bcc state: down mac: <filter>
  IF-ID-3: br-457f84a8e65e state: down mac: <filter>
  IF-ID-4: br-4fa92560481c state: down mac: <filter>
  IF-ID-5: br-6bd56c8e9106 state: down mac: <filter>
  IF-ID-6: br-7b0a222cbebb state: down mac: <filter>
  IF-ID-7: br-92aa4ebb65b2 state: down mac: <filter>
  IF-ID-8: br-9523f95a7cf9 state: down mac: <filter>
  IF-ID-9: br-a7e5108cf1a7 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-10: br-ba8cf43447b1 state: down mac: <filter>
  IF-ID-11: br-ca682372c5ce state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-12: br-d2b1f615244c state: down mac: <filter>
  IF-ID-13: br-d8f2e894960e state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-14: br-d91bf3ebc180 state: down mac: <filter>
  IF-ID-15: br-e246861ce0b2 state: down mac: <filter>
  IF-ID-16: br-e9936dbf9734 state: down mac: <filter>
  IF-ID-17: br-ee3eccd61fae state: down mac: <filter>
  IF-ID-18: br-f64b5df52f79 state: down mac: <filter>
  IF-ID-19: br-fb958db809af state: down mac: <filter>
  IF-ID-20: docker0 state: down mac: <filter>
  IF-ID-21: veth0216cad state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-22: veth054bd4e state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-23: veth24af439 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-24: veth2d4c9f0 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-25: veth3da4be6 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-26: veth4ad861a state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-27: veth7b49117 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-28: veth7d2feae state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-29: vetha5f3285 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-30: vethb613cb6 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-31: vethe590aef state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-32: vethed52e10 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Info: services: NetworkManager, nginx, sshd, systemd-timesyncd
  Local Storage: total: 23.92 TiB used: 4.87 TiB (20.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X6001T
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 9A0 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST6000NM0044
    size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: G00A scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: Expansion HDD
    size: 14.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1801 scheme: GPT
  ID-1: / raw-size: 225.55 GiB size: 225.55 GiB (100.00%)
    used: 170.36 GiB (75.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
    label: N/A uuid: ff83e47a-360c-45ae-a427-8463948ff5e3
    used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
    uuid: EB83-B8DF
  ID-3: /home raw-size: 225.55 GiB size: 225.55 GiB (100.00%)
  ID-4: /mnt/plexdrive1 raw-size: 5.46 TiB size: 5.41 TiB (99.19%)
    used: 4.7 TiB (86.9%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: Expanded_1 uuid: 3176da63-3e41-4672-9791-5c6f7e1f9bdf
  ID-5: /var/cache raw-size: 225.55 GiB size: 225.55 GiB (100.00%)
  ID-6: /var/log raw-size: 225.55 GiB size: 225.55 GiB (100.00%)
  ID-1: swap-1 type: partition size: 6.84 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8 label: N/A
    uuid: 3d2db8bd-b1cb-41f7-b74e-38717333fc45
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
    uuid: 90A67321A67306CE
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
    uuid: 0677-1C0C
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 953.24 GiB fs: ntfs label: N/A
    uuid: 56467AEA467AC9EF
  ID-5: /dev/sda1 maj-min: 8:1 size: 943.86 GiB fs: ext4 label: Extra_SSD
    uuid: e3e8b289-2e02-4713-9cb2-ee2971505a83
  ID-6: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-7: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: VideoExport
    uuid: A46833D16833A14A
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-3:2 info: Seagate RSS LLC Expansion HDD type: mass storage
    driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 8mA chip-ID: 0bc2:2038 class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-3:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 5-3:3 info: Logitech HD Webcam C615 type: audio,video
    chip-ID: 046d:082c class-ID: 0e02 serial: <filter>
  Device-3: 5-4:4 info: ZSA Labs Voyager type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3297:1977 class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp: 52.0 C
    mem: 56.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 993
  Packages: 1726 pm: pacman pkgs: 1722 libs: 430 tools: pamac pm: flatpak
    pkgs: 4
    1: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    2: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 656
  1: cpu: 17.2% command: firefox pid: 25537 mem: 566.7 MiB (0.8%)
  2: cpu: 7.2% command: konsole pid: 57683 mem: 207.5 MiB (0.3%)
  3: cpu: 5.9% command: firefox pid: 33649 mem: 256.0 MiB (0.3%)
  4: cpu: 5.3% command: [btrfs-cleaner] pid: 378 mem: 0.00 MiB (0.0%)
  5: cpu: 5.3% command: zsh pid: 57713 mem: 11.4 MiB (0.0%)
  Memory top: 5 of 656
  1: mem: 619.0 MiB (0.9%) command: k3s pid: 3191 cpu: 5.1%
  2: mem: 566.7 MiB (0.8%) command: firefox pid: 25537 cpu: 17.2%
  3: mem: 556.0 MiB (0.8%) command: k3s pid: 3529 cpu: 5.0%
  4: mem: 476.1 MiB (0.7%) command: k3s pid: 2856 cpu: 3.8%
  5: mem: 377.8 MiB (0.5%) command: plasmashell pid: 10868 cpu: 0.7%
  Processes: 656 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.08 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.36
journal amdgpu
Sep 10 04:09:11 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=208474, emitted seq=208476
Sep 10 04:09:11 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 983 thread Xorg:cs0 pid 997
Sep 10 04:09:11 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:09:11 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:09:11 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:09:11 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:09:21 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=208474, emitted seq=208476
Sep 10 04:09:21 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 983 thread Xorg:cs0 pid 997
Sep 10 04:09:21 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:09:21 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:09:21 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:09:21 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:09:22 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=7617, emitted seq=7619
Sep 10 04:09:22 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:09:22 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:09:22 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:09:22 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:09:32 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=7617, emitted seq=7619
Sep 10 04:09:32 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:09:32 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:09:32 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:09:32 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:10:15 desktop-LinuxMain chromium[25028]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
Sep 10 04:10:25 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=13691, emitted seq=13695
Sep 10 04:10:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:10:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:10:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:10:25 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:10:35 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=13691, emitted seq=13695
Sep 10 04:10:35 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset begin!
Sep 10 04:10:35 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: device lost from bus!
Sep 10 04:10:35 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GPU reset end with ret = -19
Sep 10 04:10:35 desktop-LinuxMain kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* GPU Recovery Failed: -19
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_gmc_flush_gpu_tlb+0x158/0x270 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_gart_unbind+0xbe/0x120 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_ttm_backend_unbind+0x64/0xb0 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_ttm_tt_unpopulate+0x16/0xd0 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_bo_unref+0x1e/0x30 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_vm_pt_free+0xf5/0x110 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_vm_pt_free_root+0x118/0x160 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_vm_fini+0x2f5/0x570 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 04:12:42 desktop-LinuxMain kernel:  amdgpu_driver_postclose_kms+0x199/0x280 [amdgpu 4492767182e959f3f2c29aeaf9507222079aca83]
Sep 10 09:05:25 desktop-LinuxMain kernel: [drm] amdgpu kernel modesetting enabled.
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: Virtual CRAT table created for CPU
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: Topology: Add CPU node
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: No more image in the PCI ROM
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: Fetched VBIOS from ROM BAR
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: ATOM BIOS: 115-D199PI0-100
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: vgaarb: deactivate vga console
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
Sep 10 09:05:25 desktop-LinuxMain kernel: [drm] amdgpu: 8176M of VRAM memory ready
Sep 10 09:05:25 desktop-LinuxMain kernel: [drm] amdgpu: 32114M of GTT memory ready.
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: Will use PSP to load VCN firmware
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: reserve 0x900000 from 0x81fd000000 for PSP TMR
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: RAS: optional ras ta ucode is not available
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: RAP: optional rap ta ucode is not available
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: use vbios provided pptable
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: smc_dpm_info table revision(format.content): 4.5
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: SMU is initialized successfully!
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: HMM registered 8176MB device memory
Sep 10 09:05:25 desktop-LinuxMain kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Sep 10 09:05:25 desktop-LinuxMain kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: Virtual CRAT table created for GPU
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu: Topology: Add dGPU node [0x731f:0x1002]
Sep 10 09:05:25 desktop-LinuxMain kernel: kfd kfd: amdgpu: added device 1002:731f
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 10, active_cu_number 40
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 11 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring vcn_dec uses VM inv eng 0 on hub 8
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 1 on hub 8
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 4 on hub 8
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: amdgpu: Using BACO for runtime pm
Sep 10 09:05:25 desktop-LinuxMain kernel: [drm] Initialized amdgpu 3.57.0 20150101 for 0000:10:00.0 on minor 1
Sep 10 09:05:25 desktop-LinuxMain kernel: fbcon: amdgpudrmfb (fb0) is primary device
Sep 10 09:05:25 desktop-LinuxMain kernel: amdgpu 0000:10:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Sep 10 09:05:26 desktop-LinuxMain kernel: snd_hda_intel 0000:10:00.1: bound 0000:10:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Which Kernel did you used before?
Did you try TTY or crlt+shift+f12 for resetting your desktop?
Did you maybe executed a special demanding task? For example, I recently had problems with a Flatpak program, that lead to a freezing GPU after i closed the application and my GPU was idling for around 5-10min.
Did you try Wayland yet? The most AMD GPU owner’s prefer to run Wayland on KDE.
Kernel 6.6, has same problems
I thought the same, but once I just booted before I went to bed and not running any demanding application, and from the logs it seems to have had problems at 4am when I was asleep, and when I woke up the monitors wouldn’t turn on.
No, how would I go about switching?
On login screen, top left corner, drop down box. Change x11 to wayland
Thanks, I’ll use Wayland and see if the problem happens
KDE has a really strong focus for Wayland with Plasma 6 release. I still use X11 for my nvidia/intel rig but for my AMD Laptop there is no way to evade Wayland.
In sddm it’s in the bottom left corner. :wink:
Depends entirely on your theme.
