Displays Overlap after Sleep
Having installed NVIDIA proprietary drivers, configured the display layout (2 monitors, 4K left [primary], 1920x1200 right) via either xcfe4-display-settings GUI or nvidia-settings I can get the layout as desired and functional. The displays blank/sleep based on Power Manager settings.
When returning from sleep the position of the displays is changed, and both displays overlap (0,0 absolute, top left aligned), the Panel shifts to the ‘second’ monitor, individual desktop wallpapers still applied. The second display cannot be re-positioned (drag/drop position) from this state.
The only way I’ve found to resolve this so far is to ‘disable’ the second monitor, this re-positions it to the right of the primary monitor, and when re-enabled, will remain there.
Looking for hints/directions of where to look, what to try to resolve this.
How did you do that exactly?
Share some info about your system as described in [HowTo] Provide System Information
Also share from terminal:
cat /etc/X11/mhwd.d/nvidia.conf
Make sure to properly format the Terminal output.
Hi,
Settings were changed with the respective GUI’s accessed from the Menu appfinder Display and NVIDIA X Server Settings, and also following the wiki: Configure NVIDIA (non-free) settings and load them on Startup - Manjaro.
inxi output:
  Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=869b105f-9307-4aad-9dac-da90d6af48d3 ro quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Desktop System: Gigabyte product: Z87X-OC Force v: N/A
  serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: Gigabyte model: Z87X-OC Force-CF v: x.x serial: <filter>
  BIOS: American Megatrends v: 10b date: 06/12/2014
  RAM: total: 31.25 GiB used: 4.1 GiB (13.1%)
  Info: Quad Core model: Intel Core i7-4770K bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
  L2: 8 MiB bogomips: 55892
  Speed: 3869 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3869 2: 3866
  3: 3875 4: 3844 5: 3849 6: 3836 7: 3852 8: 3828
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
  ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
  xtpr
  Type: l1tf
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
  class-ID: 0300
  Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: eVga.com. driver: nvidia
  v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 03:00.0 chip-ID: 10de:1b81
  class-ID: 0300
  Device-3: NVIDIA GP104 [GeForce GTX 1070] vendor: eVga.com. driver: nvidia
  v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 04:00.0 chip-ID: 10de:1b81
  class-ID: 0300
  Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.0x22.5")
  s-diag: 1628mm (64.1")
  Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
  diag: 708mm (27.9")
  Monitor-2: DP-2 res: 1920x1200 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5")
  diag: 184mm (7.2")
  OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
  direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
  class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-3: SAVITECH JDS Labs Element DAC type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-7:5 chip-ID: 262a:1048
  class-ID: 0102
  Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
  port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
  Device-2: Intel I210 Gigabit Network vendor: Gigabyte driver: igb v: kernel
  port: e000 bus-ID: 05:00.0 chip-ID: 8086:1533 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
  driver: ath9k v: kernel port: e000 bus-ID: 06:00.0 chip-ID: 168c:0034
  class-ID: 0280
  IF: wlp6s0 state: down mac: <filter>
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 7.97 TiB used: 3.46 TiB (43.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
  size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: MU03 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
  rotation: 7200 rpm serial: <filter> rev: CC27 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM001-1CH164
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 500GB
  rotation: SSD serial: <filter> rev: 1B6Q scheme: MBR
  ID-5: /dev/sde maj-min: 8:64 vendor: Seagate model: ST1000DX002-2DV162
  rotation: 7200 rpm serial: <filter> rev: CC41 scheme: GPT
  ID-6: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST1000DX002-2DV162
  ID-7: /dev/sdg maj-min: 8:96 vendor: Seagate model: ST2000DM008-2FR102
  rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-8: /dev/sdl maj-min: 8:176 type: USB vendor: Generic model: USB3.0 CRW -3
  size: 14.92 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.00 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.01
  dev-links: cdrom
  ID-1: / raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
  used: 21.16 GiB (4.6%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: N/A
  uuid: 869b105f-9307-4aad-9dac-da90d6af48d3
  ID-2: /mnt/Data raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  used: 1.04 TiB (57.3%) fs: fuseblk dev: /dev/sdg2 maj-min: 8:98 label: Data
  uuid: 84DEAD6CDEAD5768
  ID-3: /mnt/Music raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  used: 888.54 GiB (47.7%) fs: fuseblk dev: /dev/sdb2 maj-min: 8:18
  label: Music uuid: 5CA86C12A86BE94A
  ID-4: /mnt/Video raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  used: 1.53 TiB (84.3%) fs: fuseblk dev: /dev/sdc2 maj-min: 8:34 label: Video
  uuid: 904874A548748BAA
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: fat (32 bit) label: N/A
  uuid: 98DF-1DE6
  ID-2: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 222.82 GiB fs: ntfs label: N/A
  uuid: F2D0E400D0E3C8C5
  ID-4: /dev/sda4 maj-min: 8:4 size: 531 MiB fs: ntfs label: N/A
  uuid: 1C3EA0003E9FD15E
  ID-5: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-6: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
  ID-7: /dev/sde1 maj-min: 8:65 size: 128 MiB fs: <superuser required>
  ID-8: /dev/sde2 maj-min: 8:66 size: 931.39 GiB fs: ntfs label: Steam
  uuid: 1C94F82594F7FF58
  ID-9: /dev/sdf1 maj-min: 8:81 size: 128 MiB fs: <superuser required>
  ID-10: /dev/sdf2 maj-min: 8:82 size: 931.39 GiB fs: ntfs label: Data2
  uuid: 7232208F32205A7D
  ID-11: /dev/sdg1 maj-min: 8:97 size: 16 MiB fs: <superuser required>
  ID-12: /dev/sdl1 maj-min: 8:177 size: 256 MiB fs: <superuser required>
  ID-13: /dev/sdl2 maj-min: 8:178 size: 1.49 GiB fs: ext2 label: p\xefotgw
  uuid: 7295bbc3-bbc2-4267-9fa0-099e18ef5b70
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Device-1: 3-3:2 info: Alcor Micro Multi Flash Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Device-2: 3-5:3 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
  power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
  Device-3: 3-6:4 info: Holtek USB Keyboard type: Keyboard,Mouse
  power: 100mA chip-ID: 04d9:0169 class-ID: 0301
  Device-4: 3-7:5 info: SAVITECH JDS Labs Element DAC type: HID,Audio
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 94mA chip-ID: 262a:1048 class-ID: 0102
  Hub-6: 3-9:10 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 045b:0209 class-ID: 0900
  Hub-7: 3-10:11 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 3-13:12 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-14:15
  info: Transcend Information microSD/SD/CF UHS-II Card Reader [RDF8 RDF9]
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
  speed: 480 Mb/s power: 500mA chip-ID: 8564:4000 class-ID: 0806
  serial: <filter>
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-5:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 045b:0210 class-ID: 0900
  Hub-10: 4-6:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 56 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 16%
  Processes: 308 Uptime: 21h 02m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: N/A Packages: 1198 pacman: 1192 lib: 398
  flatpak: 0 snap: 6 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
  inxi: 3.3.04
nvidia.conf output:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 465.31
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Ancor Communications Inc ASUS PB287Q"
    HorizSync       24.0 - 160.0
    VertRefresh     30.0 - 80.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "NVIDIA GeForce GTX 1070"
    BusID          "PCI:4:0:0"
EndSection
Section "Screen"
# Removed Option "metamodes" "HDMI-0: 1920x1200_60 +3840+0, DP-0: 3840x2160_60 +0+905"
# Removed Option "metamodes" "DP-0: nvidia-auto-select +0+884, DP-2: nvidia-auto-select +3840+0"
# Removed Option "metamodes" "DP-0: 3840x2160_60 +0+0, DP-2: 1920x1200_60 +3840+0"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-2"
    Option         "metamodes" "DP-0: nvidia-auto-select +0+0, DP-2: nvidia-auto-select +3840+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
This /etc/X11/mhwd.d/nvidia.conf should work
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BusID          "PCI:4:0:0"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
but before you reboot, delete the file displays.xml
rm ~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml
Thanks for the suggestion. Updated config installed/rebooted without issue (incl. removing display.xml noted), and displays correctly on logon however original issue reoccurs following display standby/sleep.
Did you noticed a difference in that file, before sleep and after wake from sleep ? If it gets modified that means the wake up protocol simply ignores the xorg config and initializes the monitors in different order and ends up with them overleaping … but at this point i have no idea what to suggest :man_shrugging:
