Greetings,
I’m using Manjaro 21.1.5 XFCE on my desktop, and I have connected displays to both my integrated graphics card and my NVIDIA GTX 1060 3 GB, for the purposes of GPU passthrough on a KVM. However, the displays connected to the integrated graphics are not detected by the Display Settings, and therefore, I cannot do anything with them.
I saw on another topic that the minimum information required for this kind of support would be something along the lines of the output of:
$ inxi --full --admin --verbosity=7 --filter --no-host
Below I will include the output of the above command:
System: Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3c8603f6-adc2-4dd5-bc24-d2346665904f rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0
Machine: Type: Desktop Mobo: Gigabyte model: H87-HD3 v: x.x serial: <filter> UEFI: American Megatrends v: F2
date: 04/17/2013
Battery: Message: No system battery data found. Is one present?
Memory: RAM: total: 7.65 GiB used: 3.45 GiB (45.2%)
CPU: Info: Quad Core model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 cache: L2: 8 MiB bogomips: 54293
Speed: 3392 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3392 2: 3392 3: 3392 4: 3392 5: 3392 6: 3392 7: 3392
8: 3392
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Gigabyte driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-9:8 chip-ID: 05a3:9331 class-ID: 0102
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver: loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0") s-diag: 1245mm (49")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DP-2 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-4: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-9:8 chip-ID: 05a3:9331 class-ID: 0102
serial: <filter>
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb bus-ID: 3-1.1:4 chip-ID: 148f:5370
class-ID: 0000 serial: <filter>
IF: wlp0s20u1u1 state: down mac: <filter>
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 4.09 TiB used: 31.56 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00ZF5A0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 0A80 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: MQ01UBB200 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: MBR
ID-5: /dev/sdi maj-min: 8:128 type: USB vendor: Seagate model: ST9500325AS size: 465.76 GiB block-size:
physical: 512 B logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 0148 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB00 dev-links: cdrom
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / raw-size: 200.66 GiB size: 196.45 GiB (97.90%) used: 31.56 GiB (16.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: N/A uuid: 3c8603f6-adc2-4dd5-bc24-d2346665904f
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1
maj-min: 8:1 label: NO_LABEL uuid: A60E-FC40
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 87a72d9a-37c6-4b4b-83ed-5ce469bb47e0
Unmounted: ID-1: /dev/sda4 maj-min: 8:4 size: 256 GiB fs: ntfs label: SSD Xtras uuid: 7C9EFCDA16F7AD87
ID-2: /dev/sdb1 maj-min: 8:17 size: 868.03 GiB fs: ntfs label: Xar HDD 1 uuid: 4CE0DB16E0DB055C
ID-3: /dev/sdb2 maj-min: 8:18 size: 63.48 GiB fs: ntfs label: Xtras uuid: 12D86FC5D86FA627
ID-4: /dev/sdc1 maj-min: 8:33 size: 500 MiB fs: ntfs label: N/A uuid: B4FC7F32FC7EEE4C
ID-5: /dev/sdc2 maj-min: 8:34 size: 464.35 GiB fs: ntfs label: Windows uuid: B4FA33EAFA33A78E
ID-6: /dev/sdc3 maj-min: 8:35 size: 100 MiB fs: vfat label: N/A uuid: 843A-868A
ID-7: /dev/sdc4 maj-min: 8:36 size: 840 MiB fs: ntfs label: N/A uuid: E834C7A634C775DA
ID-8: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ntfs label: XarExternalHDDNo3 uuid: 72ACD728ACD6E61F
ID-9: /dev/sdi1 maj-min: 8:129 size: 465.76 GiB fs: ntfs label: XarExternalHDDNo2 uuid: 44DC8335DC832072
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8008
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8000
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-6: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 0bda:5411 class-ID: 0900
Device-1: 3-1.1:4 info: Ralink RT5370 Wireless Adapter type: Network driver: rt2800usb interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 450mA chip-ID: 148f:5370 class-ID: 0000 serial: <filter>
Device-2: 3-1.4:6 info: Wacom CTL-480 [Intuos Pen (S)] type: HID,Mouse driver: usbhid,wacom interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 498mA chip-ID: 056a:030e class-ID: 0301
Device-3: 3-5:3 info: ROCCAT Isku+ Force FX type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1e7d:3214 class-ID: 0300
Device-4: 3-6:5 info: SINOWEALTH Game Mouse type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-5: 3-8:7 info: Realtek Mass Storage Device (Multicard Reader) type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0151 class-ID: 0806 serial: <filter>
Device-6: 3-9:8 info: ARC Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Device-7: 3-10:9 info: Seagate RSS LLC FreeAgent Go type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0bc2:2120 class-ID: 0806 serial: <filter>
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-8: 4-1:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 0bda:0411 class-ID: 0900
Device-1: 4-3:3 info: Elgato Systems Game Capture HD60 S type: <vendor specific> driver: N/A interfaces: 2 rev: 3.0
speed: 5 Gb/s power: 400mA chip-ID: 0fd9:0074 class-ID: ff00 serial: <filter>
Device-2: 4-4:4 info: Toshiba America External USB 3.0 type: Mass Storage driver: usb-storage interfaces: 1
rev: 3.0 speed: 5 Gb/s power: 896mA chip-ID: 0480:a200 class-ID: 0806 serial: <filter>
Sensors: System Temperatures: cpu: 65.0 C mobo: 27.8 C gpu: nvidia temp: 49 C
Info: Processes: 251 Uptime: 37m wakeups: 0 Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1254 lib: 390 flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
I’m probably missing something really obvious here, but I cannot for the life of me find it
