[Unstable Update] 2021-05-28 - Kernels, Perl, Cinnamon 5.0, Haskell, Tesseract, Cutefish
Hello community,
Another unstable branch update with some usual updates for you.
Find out more about the new Starbook by Starlabs!
  • Most of our Kernels got updated
  • There was a perl rebuild by upstream Arch
  • Cutefish DE got added
  • Cinnamon going to get updated to 5.0.0
  • Other regular upstream updates including python, tesseract and haskell
Get our latest daily developer images now from Github: Plasma, Gnome, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
  • linux44 4.4.270
  • linux49 4.9.270
  • linux414 4.14.234
  • linux419 4.19.192
  • linux54 5.4.122
  • linux510 5.10.40
  • linux511 5.11.22
  • linux512 5.12.7
  • linux513 5.13-rc3
  • linux54-rt 5.4.115_rt57
  • linux59-rt 5.9.1_rt19
  • linux511-rt 5.11.4_rt11
A detailed list of all package changes can be found here.
0 voters
On Unstable:
Is it okay to replace?
:: Replace qca with extra/qca-qt5? [Y/n]
The package was split:
https://archlinux.org/packages/extra/x86_64/qca/
Iā€™m not a fan of the new firefox 89 update. Iā€™m getting moderately worse performance on dual monitors and I normally like to watch youtube videos on 1.75x speed on one monitor and do normal items on the second and the performance hit is really noticeable compared to before. Iā€™ll change the performance settings in firefox for now manually to see if that helps but Iā€™ll be looking for an nvidia update or something soonā€¦ :neutral_face:
Itā€™s been awhile playing with firejail, but I suggest for those of you combining it with media players and setting the net none flag, go ahead and do some testing on your end to see if streaming-media files are properly ā€œfailing.ā€ I accidentally saved an html element as a ā€œvideo fileā€ and vlc+firejail choked on it to the point of needing to drop to TTY and then gracefully rebooting. For now Iā€™m sticking to the LTS kernel until we get another nvidia/mesa update.
I also cleaned up some orphans today: # pacman -Rns lib32-dconf lib32-libgudev lib32-libgusb lib32-polkit Thanks all.
Maybe it is time to try out Vivaldi ā€¦
A post was split to a new topic: Issues after updating to Cinnamon 5.0.0
A report on todayā€™s update:
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] y
warning: manjaro-release: local (21.0.5-1) is newer than core (21.0.4-1)
resolving dependencies...
:: installing libcanberra (0.30+2+gc0620e4-4) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
Also, pacman 6 is still not available in the unstable branch.
Remove libcanberra-gstreamer & lib32-libcanberra-gstreamer first.
EDIT:
lib32-libcanberra-gstreamer and libcanberra-gstreamer are no longer in the repos
FS#71144 - [libcanberra] Broken dependency since 0.30+2+gc0620e4-4
Brave is my friend for now. Vivaldi is bloated kind off
Dependency resolution failed for libcanberra -
Any ideas?
screenshot: h t t p s ://i.postimg.cc/7ZFBPqCH/Screenshot-20210606-132606.png
Always check Announcement posts and their comments before posting.
See my post above:
got it. thank you
Any Safe way to resolve this
:: installing pacman (6.0.0-1) breaks dependency 'pacman<5.3' required by pamac-common
EDIT 1:
Issue Resolved
Yep, Iā€™m getting the same thing:
:: installing pacman (6.0.0-1) breaks dependency ā€˜pacman<5.3ā€™ required by pamac-common
Now that the new pacman got imported, I guess the new pamac with libalpm13 support is almost readyā€¦
Issue Resolved!!
How did you resolve it? Still does not work for me.
//Edit: mirror refresh worked
pamac is broken in Manjaro unstable now due to the Pacman 5 to 6 updates but well one have to live with Unstable being unstable sometimes
