Displaylink problem on Tuxedo Red Manjaro
I installed displaylink 5.3.1.34-3 via a yay search and reading earlier in the forum… I have an intec usb- c docking station. My kernal is 5.4.67-1-manjaro. Everything installed fine but when I go to use the monitor plugged into the usb-c connector the response time goes down dramatically. If I type, it is very laggy and unworkable.
I put this in the kernel part because I believe it could be a function of the interaction between evdi and the kernel. If I plug in the hdmi directly to my computer no problem.
How do I fix this?
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  1. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
  2. This is probably due to your graphics chipset / drivers, not the kernel, but we’ll see after you provide above information…
    :+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
So I have run the queries you ask for, but the forum will not let me include them it says I can not include links which there are none so… Any other way I can submit the output of your query?
Have you by any chance read the wiki yet regarding DisplayLink?
https://wiki.archlinux.org/index.php/DisplayLink
I looked at another post which was more focused on installation so no. Yikes ! It looks like it is a hot mess and might not be worth doing?
I’ve looked into it myself a while back because my laptop doesn’t have DP over USB-C, and ended up thinking “I am not even going to deal with this” haha.
Yes, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
so:
output in here
That is some command! I do not know what is best on this forum to attach or to Cut and Paste so I went with the latter.
  Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=d7dc2ea5-3935-4c80-a1ab-c7ec9425807f rw quiet udev.log_priority=3
  acpi_osi= bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
  apparmor=1 security=apparmor
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: TUXEDO product: InfinityBook Pro 15 v5 v: N/A
  serial: <filter> Chassis: Notebook type: 10 serial: <filter>
  Mobo: TUXEDO model: N150CU serial: <filter> UEFI: INSYDE v: 1.07.08RTR1
  date: 05/27/2020
  ID-1: BAT0 charge: 53.8 Wh condition: 53.8/53.2 Wh (101%) volts: 17.3/15.4
  model: Notebook BAT type: Li-ion serial: <filter> status: Full
  RAM: total: 62.52 GiB used: 3.86 GiB (6.2%)
  Topology: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
  L2 cache: 8192 KiB bogomips: 36812
  Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 801 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:9b41
  Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
  bus ID: 1-7:5 chip ID: 04f2:b685
  Display: x11 server: X.Org 1.20.9 driver: modesetting
  alternate: fbdev,intel,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
  s-diag: 583mm (23")
  Monitor-1: HDMI-2 res: 1920x1080 hz: 60 dpi: 72 size: 673x284mm (26.5x11.2")
  diag: 730mm (28.8")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
  alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
  Device-2: Logitech HD Pro Webcam C920 type: USB
  driver: snd-usb-audio,uvcvideo bus ID: 1-3.4.4:13 chip ID: 046d:082d
  serial: <filter>
  Device-3: DisplayLink USB3.0 Hub type: USB
  driver: cdc_ncm,snd-usb-audio,usbfs bus ID: 4-1.1:3 chip ID: 17e9:6000
  serial: <filter>
  Sound Server: ALSA v: k5.4.67-1-MANJARO
  vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus ID: 3b:00.1
  chip ID: 10ec:8168
  IF: enp59s0f1 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
  bus ID: 3c:00.0 chip ID: 8086:2723
  IF: wlp60s0 state: down mac: <filter>
  IF-ID-1: enp58s0u1u1i5 state: up speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 1.14 TiB used: 547.17 GiB (47.0%)
  ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO M.2 250GB size: 232.89 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 4B6Q scheme: GPT
  ID-2: /dev/sdc type: USB vendor: Western Digital model: WD My Passport 0748
  size: 931.48 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1015 scheme: MBR
  ID-1: / raw size: 224.38 GiB size: 219.86 GiB (97.98%)
  used: 36.55 GiB (16.6%) fs: ext4 dev: /dev/sda2 label: N/A
  uuid: d7dc2ea5-3935-4c80-a1ab-c7ec9425807f
  ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%)
  used: 160 KiB (0.0%) fs: vfat dev: /dev/sda1 label: N/A uuid: CC73-0FA7
  ID-3: /home/<filter>/pCloudDrive raw size: N/A size: 2.00 TiB
  used: 510.63 GiB (24.9%) fs: fuse source: ERR-102 label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda3 label: N/A uuid: c806dd5d-0e5b-472c-89f9-a8e19cc49c50
  ID-1: /dev/sdc1 size: 32.00 GiB fs: vfat label: ESD-USB uuid: 0619-1ED3
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Hub: 1-3:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip ID: 2109:2813
  Hub: 1-3.3:4 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip ID: 2109:2210
  Device-1: 1-3.3.2:8 info: Texas Instruments type: Billboard driver: N/A
  interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 0451:ace1 serial: <filter>
  Device-2: 1-3.3.3:10 info: Silicon Labs USB2.0 Hub type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  chip ID: 10c4:f608 serial: <filter>
  Hub: 1-3.4:7 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip ID: 2109:2813
  Device-1: 1-3.4.1:9 info: Lite-On type: Keyboard,HID
  chip ID: 04ca:0027
  Device-2: 1-3.4.2:11 info: Primax type: Mouse driver: hid-generic,usbhid
  interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 0461:4d65
  Device-3: 1-3.4.3:12 info: HP USB2.0 Hub type: <vendor specific>
  driver: usb-storage,usblp interfaces: 5 rev: 2.0 speed: 480 Mb/s
  chip ID: 03f0:0c54 serial: <filter>
  Device-4: 1-3.4.4:13 info: Logitech HD Pro Webcam C920 type: Video,Audio
  chip ID: 046d:082d serial: <filter>
  Device-5: 1-6:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00a8 serial: <filter>
  Device-6: 1-7:5 info: Chicony Chicony USB2.0 Camera type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b685
  Device-7: 1-10:6 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
  chip ID: 1d6b:0002
  Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  chip ID: 1d6b:0003
  Hub: 4-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip ID: 2109:0813
  Device-1: 4-1.1:3 info: DisplayLink USB3.0 Hub type: <vendor specific>
  driver: cdc_ncm,snd-usb-audio,usbfs interfaces: 7 rev: 3.2 speed: 5 Gb/s
  chip ID: 17e9:6000 serial: <filter>
  Device-2: 4-1.2:4 info: Western Digital My Passport (WDBKXH WDBY8L)
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
  chip ID: 1058:0748 serial: <filter>
  Hub: 4-1.3:5 info: VIA Labs Hub ports: 1 rev: 3.0 speed: 5 Gb/s
  chip ID: 2109:0210
  Hub: 4-1.4:6 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip ID: 2109:0813
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 254 Uptime: 43m Init: systemd v: 246 Compilers: gcc: 10.2.0
  Packages: pacman: 1190 lib: 325 flatpak: 0 Shell: Bash v: 5.0.18
  running in: xfce4-terminal inxi: 3.1.05
I am looking to update my profile but to fill some of the blanks- I am running a Tuxedo Infinity book Manjaro Red 15. My CPU info is (8 intel processors) here is the readout for one of them-
Processor	: 0
vendor_id	: GenuineIntel
cpu family	: 6
model		: 142
model name	: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
stepping	: 12
microcode	: 0xd6
cpu MHz		: 800.040
cache size	: 8192 KB
physical id	: 0
siblings	: 8
core id		: 0
cpu cores	: 4
apicid		: 0
initial apicid	: 0
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities
bugs		: spectre_v1 spectre_v2 spec_store_bypass swapgs itlb_multihit srbds
bogomips	: 4601.60
clflush size	: 64
cache_alignment	: 64
address sizes	: 39 bits physical, 48 bits virtual
power management:
*-display
       description: VGA compatible controller
       product: UHD Graphics
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
       resources: iomemory:600-5ff iomemory:400-3ff irq:133 memory:6022000000-6022ffffff memory:4000000000-400fffffff ioport:4000(size=64) memory:c0000-dffff
I think that is everything,
Please let me know and Thanks !
I’ve edited you post for readability, but you’re on an Intel Chipset and I’m on nVidia, so I can’t help you further but everything looks good from a system perspective, so I can only agree with @realmain.
Read the Arch Wiki docs and then come back and post a solution yourself because I don’t have one of those Tuxedo beauties (yet)…
:sob:
It is sweet to be sure. Thank you for all your help, Hopefully a solution will present itself, it is pretty cool to plug in one usbc cord and run everything.
Sigh,. Thanks again!!!
