Displaylink not listed in xrandr and not working
Hi,
I have a Lenovo 40af USB-C dock with DisplayLink. USB and peripherals are working fine, only the DisplayLink is what I cannot get working, though the ports are working under Windows.
I stuck to the installation guide on the ArchLinux wiki.
I installed the drivers (displaylink, tried it with displaylink-git as well, same goes for evdi) and the service is listed as enabled and running:
● displaylink.service - DisplayLink Manager Service
     Loaded: loaded (/usr/lib/systemd/system/displaylink.service; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/displaylink.service.d
             └─displaylink-connect.conf
     Active: active (running) since Fri 2023-09-15 15:55:17 CEST; 16min ago
    Process: 669 ExecStartPre=/sbin/modprobe evdi (code=exited, status=0/SUCCESS)
    Process: 679 ExecStartPost=/bin/sleep 1 (code=exited, status=0/SUCCESS)
    Process: 1059 ExecStartPost=/usr/bin/run_as_users_with_display systemctl --user --no-block start displaylink-connect.service (code=exited, status=0/SUCCESS)
   Main PID: 678 (DisplayLinkMana)
      Tasks: 9 (limit: 16541)
     Memory: 13.2M
        CPU: 109ms
     CGroup: /system.slice/displaylink.service
             └─678 /usr/lib/displaylink/DisplayLinkManager
Sep 15 15:55:15 laurenz-mobil systemd[1]: Starting DisplayLink Manager Service...
Sep 15 15:55:17 laurenz-mobil systemd[1]: Started DisplayLink Manager Service.
However nothing comes up on the displays (2x connected via HDMI) and they are asleep. I tried xrandr and it doen’t list DisplayLink as a provider:
Providers: number : 1
Provider 0: id: 0x46 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 4 associated providers: 0 name:modesetting
xrandr itself states, that the two DisplayPort outputs are not connected (I assume that are the two provided via USB-C. It is working with Anker USB-C adapters):
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.05*+  50.01    48.02    59.93
   1680x1050     59.95    60.05    59.88
   1400x1050     59.98
      [and so on...]
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080     60.00*+  59.96    50.00    59.94    59.93
   1680x1050     59.95    59.88
      [and so on...]
   360x202       59.51    59.13
   320x180       59.84    59.32
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
I tried everything I could find on the web both on X11 and Wayland with the usual reboots in between. I also tried to totally power off both the dock and my laptop (Lenovo ThinkBook).
A similar dock was working with this laptop beforehand, however it was, iirc, a 40AN which has Thunderbold, I believe.
If anyone has any idea, what I can try I would be very thankful!
inxi --system:
  Host: [name] Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.7 Distro: Manjaro Linux
inxi --graphics:
  Host: laurenz-mobil Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64
