Bumping with extra info.
I worked with someone to setup the GPUs following the guide on the Arch wiki.
I believe I have successfully setup the cards for pass-through, however I am still not able to boot into the Desktop Environment.
When I try to force start the display server using startx
I am given this in the log file.
[ 868.011]
X.Org X Server 1.21.1.3
[ 868.011] Current Operating System: Linux zer0svoid 5.15.41-1-MANJARO #1 SMP PREEMPT Wed May 18 09:20:01 UTC 2022 x86_64
[ 868.011] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=4fe816b8-724f-4798-a934-80245ca84471 rw splash apparmor=1 security=apparmor udev.log_priority=3 intel_iommu=on iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb rd.driver.pre=vfio_pci 3
[ 868.011]
[ 868.011] Current version of pixman: 0.40.0
[ 868.011] Before reporting problems, check http://wiki.x.org
[ 868.011] Markers: (--) probed, (**) from config file, (==) default setting,
[ 868.011] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 4 16:11:53 2022
[ 868.011] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 868.011] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 868.011] (==) ServerLayout "layout"
[ 868.011] (==) No screen section available. Using defaults.
[ 868.011] (**) |-->Screen "Default Screen Section" (0)
[ 868.011] (**) | |-->Monitor "<default monitor>"
[ 868.012] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 868.012] (**) | |-->Device "Device0"
[ 868.012] (==) No monitor specified for screen "Default Screen Section".
[ 868.012] (==) Automatically adding devices
[ 868.012] (==) Automatically enabling devices
[ 868.012] (==) Automatically adding GPU devices
[ 868.012] (==) Automatically binding GPU devices
[ 868.012] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 868.012] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 868.012] Entry deleted from font path.
[ 868.012] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 868.012] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 868.012] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 868.012] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 868.012] (==) FontPath set to:
/usr/share/fonts/TTF
[ 868.012] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 868.012] (**) Extension "Composite" is enabled
[ 868.012] (**) Extension "RENDER" is enabled
[ 868.012] (II) The server relies on udev to provide the list of input devices.
[ 868.012] (II) Module ABI versions:
[ 868.012] X.Org ANSI C Emulation: 0.4
[ 868.012] X.Org Video Driver: 25.2
[ 868.012] X.Org XInput driver : 24.4
[ 868.012] X.Org Server Extension : 10.0
[ 868.012] (++) using VT number 1
[ 868.013] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 868.013] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 868.013] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 868.013] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 868.014] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 868.014] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 868.017] (--) PCI:*(1@0:0:0) 10de:2488:3842:4767 rev 161, Mem @ 0xa2000000/16777216, 0x4000000000/8589934592, 0x4200000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/131072
[ 868.017] (--) PCI: (2@0:0:0) 10de:13c2:3842:3975 rev 161, Mem @ 0xa0000000/16777216, 0x4210000000/268435456, 0x4220000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 868.017] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 868.017] (II) LoadModule: "glx"
[ 868.017] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 868.018] (II) Module glx: vendor="X.Org Foundation"
[ 868.018] compiled for 1.21.1.3, module version = 1.0.0
[ 868.018] ABI class: X.Org Server Extension, version 10.0
[ 868.018] (II) LoadModule: "vesa"
[ 868.018] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 868.019] (II) Module vesa: vendor="X.Org Foundation"
[ 868.019] compiled for 1.21.1.1, module version = 2.5.0
[ 868.019] Module class: X.Org Video Driver
[ 868.019] ABI class: X.Org Video Driver, version 25.2
[ 868.019] (II) VESA: driver for VESA chipsets: vesa
[ 868.019] vesa: Refusing to run on UEFI
[ 868.019] (EE) No devices detected.
[ 868.019] (EE)
Fatal server error:
[ 868.019] (EE) no screens found(EE)
[ 868.019] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 868.019] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 868.019] (EE)
[ 868.024] (EE) Server terminated with error (1). Closing log file.
I still suspect it may be a display server issue, however I could very well be wrong.
