I have a strange issue regarding display scaling on a lenovo thinkpad with intel graphics.
First of all, yes, I rebooted multiple times.
I set my display scale to 125% with an external monitor connected.
I no longer have that display available, and the slider value for display scale is set to 100. It’s still 125 though.
0 and 125 are the same. 106.25 works, and is smaller than 100 or 125.
I messed around with xrandr.
xrandr --output "eDP1" --scale 1
returns the scaling to 125.
anyone deal with this before? If so what do you suggest?
Otherwise.
In which file can in find the config for scaling?
Thanks!
