It’s been a few days (I can’t pinpoint exactly when) I’m having issues with my displays.
I first noticed issues when playing THE FINALS. I used to play on my secondary screen, so in joined multiple displays mode; however the mouse started and then kept escaping the focus on the game screen/window and I kept losing control until I could regain focus (by frantically clicking on my gaming screen).
Following advice from this post (the only post I found that really matched my problem) I disabled the Dash to Dock extension; the issue became less frequent but still happened every now and then. So now I’m forced to play on single screen (disabling the other in Settings) for stability.
Then I turned to another game, STRAFTAT, which on ProtonDB is reported to work flawlessly for many users, and then trouble really started: the game only works in joined multiple screens mode, by which I mean that if I only use one screen (the other being disabled) the game just doesn’t display (displays a kind of screenshot of the first millisecond of the start menu). When in joined multiple screens, one of my screen is frozen (just as above), and the other displays the game correctly.
Finally, I have trouble clicking even when not gaming, especially in Steam where I need to try ten times on menu items in order to successfully clicking them. The only thing I could was make sure that in Tweaks the focusing mode was “Click to Focus”, and it was.
All in all, I strongly doubt that this is an issue with the games themselves, and suspect that somehow my laptop has some issue with displays in general, and my dual screens setup in particular. I have otherwise no clue on what may be causing these issues, as I’ve been playing in this precise way for more than a year without an issue.
Please help!
The system info that seemed most relevant to me (but I don’t understand most of it, so kindly ask for more if I missed something).
Manjaro version:
> lsb_release -sirc
ManjaroLinux 25.0.0 Zetar
System information:
> inxi -zv8
Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=93d40e49-ab61-4bb5-85b5-fddb5cfd7086 rw quiet splash apparmor=1
Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Laptop System: Micro-Star product: Cyborg 15 A12VF v: REV:1.0
Mobo: Micro-Star model: MS-15K1 v: REV:1.0 serial: <superuser required>
part-nu: 15K1.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E15K1IMS.310 date: 03/29/2024
ID-1: BAT1 charge: 37.4 Wh (91.4%) condition: 40.9/52.0 Wh (78.6%)
volts: 12.2 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
System RAM: total: 32 GiB available: 31.05 GiB used: 6.65 GiB (21.4%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 4800 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMCG78AGBSA095N serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
Info: model: 12th Gen Intel Core i7-12650H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x436
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 86048
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 0000:00:02.0 chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: Micro-Star MSI driver: nvidia v: 570.133.07
alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none empty: DP-1
bus-ID: 0000:01:00.0 chip-ID: 10de:28a0 class-ID: 0300
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:211b
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: Dell SE2419HR serial: <filter> built: 2020
res: 1920x1080 dpi: 93 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
x: 0.322 y: 0.612 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
modes: 1920x1080, 1600x900, 1280x1024, 1152x900, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 15.16 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22be
class-ID: 0403
API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000
bus-ID: 0000:04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 165.11 GiB (17.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRS1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 312.18 GiB size: 306.21 GiB (98.09%)
used: 165.01 GiB (53.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 93d40e49-ab61-4bb5-85b5-fddb5cfd7086
used: 6.2 MiB (2.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5570-4D8E
ID-1: swap-1 type: partition size: 34.16 GiB used: 101 MiB (0.3%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 3edf65c8-b606-4168-b7c5-b88b5269beaa
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 291.91 GiB fs: ext4 label: N/A
uuid: d781dc69-126d-4138-b1da-43f9a24f5435
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 292.97 GiB fs: ext4 label: N/A
uuid: 10c43a7c-6b96-4fa0-9151-705307530a30
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:5 info: Razer USA DeathAdder V3 type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:00b2 class-ID: 0301
Device-2: 1-6:3 info: Bison HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:211b class-ID: 0e02
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 48.8 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1859 libs: 510 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
2: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
3: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
4: http://manjaro.grena.ge/stable/$repo/$arch
5: https://mirror.dc.uz/manjaro/stable/$repo/$arch
6: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 403
1: cpu: 12.5% command: localsearch-extractor-3 pid: 21581
mem: 35.8 MiB (0.1%)
2: cpu: 5.6% command: gnome-shell pid: 1879 mem: 343.5 MiB (1.0%)
3: cpu: 4.5% command: steamwebhelper pid: 12236 mem: 579.9 MiB (1.8%)
4: cpu: 2.8% command: steamwebhelper pid: 12187 mem: 306.5 MiB (0.9%)
5: cpu: 2.2% command: gnome-control-center pid: 18858
mem: 313.3 MiB (0.9%)
Memory top: 5 of 403
1: mem: 653.0 MiB (2.0%) command: ./steamwebhelper pid: 12152 cpu: 0.8%
2: mem: 579.9 MiB (1.8%) command: steamwebhelper pid: 12236 cpu: 4.5%
3: mem: 477.5 MiB (1.5%) command: firefox pid: 2857 cpu: 1.9%
4: mem: 434.8 MiB (1.3%) command: firefox pid: 3142 cpu: 2.1%
5: mem: 371.7 MiB (1.1%) command: vivaldi-bin pid: 2667 cpu: 0.8%
Processes: 403 Power: uptime: 1h 19m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.39 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.38
Drivers:
> mhwd -li
e[1me[31m> e[mInstalled PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2025.01.13 false PCI
video-modesetting 2020.01.13 true PCI
e[1me[31mWarning: e[mNo installed USB configs!
PCI devices:
> lspci -k
0000:00:00.0 Host bridge: Intel Corporation Device 4649 (rev 02)
DeviceName: Onboard - Other
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 13b9
0000:00:01.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x16 Controller #1 (rev 02)
Kernel driver in use: pcieport
0000:00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P GT1 [UHD Graphics] (rev 0c)
DeviceName: Onboard - Video
Kernel driver in use: i915
Kernel modules: i915, xe
0000:00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant (rev 02)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
0000:00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 02)
0000:00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 02)
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
Subsystem: Intel Corporation Device 0000
Kernel driver in use: vmd
Kernel modules: vmd
0000:00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
Kernel driver in use: xhci_hcd
0000:00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
0000:00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Dual Band Wi-Fi 6(802.11ax) AX201 160MHz 2x2 [Harrison Peak]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
0000:00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
0000:00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
Kernel driver in use: mei_me
Kernel modules: mei_me
0000:00:1c.0 PCI bridge: Intel Corporation Device 51b8 (rev 01)
0000:00:1c.5 PCI bridge: Intel Corporation Alder Lake-P PCH PCIe Root Port #6 (rev 01)
0000:00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
DeviceName: Onboard - Sound
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 13e8
Kernel driver in use: sof-audio-pci-intel-tgl
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
0000:00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
0000:00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
0000:01:00.0 VGA compatible controller: NVIDIA Corporation AD107M [GeForce RTX 4060 Max-Q / Mobile] (rev a1)
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
0000:01:00.1 Audio device: NVIDIA Corporation AD107 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
0000:04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Kernel driver in use: r8169
Kernel modules: r8169
10000:e0:06.0 System peripheral: Intel Corporation RST VMD Managed Controller
10000:e0:06.2 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #2 (rev 02)
10000:e1:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. KC3000/FURY Renegade NVMe SSD [E18] (rev 01)
Subsystem: Kingston Technology Company, Inc. KC3000/FURY Renegade NVMe SSD [E18]
Kernel driver in use: nvme
Kernel modules: nvme
Thanks.
