Display not responding to brightness change
Sometimes whenever the screen dims, it dims completely and when I try to make it bright again, it doesn’t change. I have an OLED display. Might that be the issue?
I am giving here my laptop specs:
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=c0b7a99b-f9c9-49a0-9421-a744ae0f2d61 rw rootflags=subvol=@
    quiet splash udev.log_priority=3 gpio_ich.use_gpio=0
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
    wm: kwin_wayland with: Docker vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 83LT v: Legion Pro 5 16ADR10
    serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ADR10
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_83LT_BU_idea_FM_Legion Pro 5 16ADR10
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: RLCN32WW
    date: 11/25/2025
  ID-1: BAT0 charge: 39 Wh (47%) condition: 83/80 Wh (103.7%) power: 82.2 W
    volts: 16.21 min: 15.52 model: COSMX L24X4PC0 type: Li-poly serial: <filter>
    charging: status: charging type: standard avail: long_life,standard
    cycles: 11
  System RAM: total: 32 GiB available: 30.64 GiB used: 6.7 GiB (21.9%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Cxmt part-no: CXMR4E816S6AS-CN1C serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8745HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 5139 min/max: 404/5153 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 5139 2: 5139 3: 5139
    4: 5139 5: 5139 6: 5139 7: 5139 8: 5139 9: 5139 10: 5139 11: 5139 12: 5139
    13: 5139 14: 5139 15: 5139 16: 5139 bogomips: 114982
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 595.71.05 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
    active: none empty: DP-1, DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:2d59 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 53.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30c9:00f8
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung ATNA60HS03-0 built: 2024 res:
    mode: 2560x1600 hz: 165 scale: 125% (1.25) to: 2048x1280 dpi: 191 gamma: 1.2
    chroma: red: x: 0.682 y: 0.318 green: x: 0.220 y: 0.725 blue: x: 0.141
    y: 0.039 white: x: 0.314 y: 0.329 size: 340x220mm (13.39x8.66")
    diag: 405mm (15.94") modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
    112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
    raphael_mendocino ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:164e
    memory: 500 MiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 26.0.6-arch1.1
    device-ID: 1002:164e surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 5060 Laptop GPU driver: nvidia v: 595.71.05
    device-ID: 10de:2d59 surfaces: N/A
  Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22eb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network Adapter
    [Filogic 360] vendor: Lenovo driver: mt7925e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7925 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:3
    chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.4
    lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 953.87 GiB used: 532.14 GiB (55.8%)
    model: MZAL81T0HFLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 5L1QKXF7 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 532.11 GiB (55.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c0b7a99b-f9c9-49a0-9421-a744ae0f2d61
    used: 32.7 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 8070-76C3
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 3-2.3:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Device-2: 3-2.4:4 info: Integrated Express ITE Device(8258)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:c195 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00f8 class-ID: fe01
    serial: <filter>
  System Temperatures: cpu: 62.1 C mobo: 47.8 C gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A
  Packages: 1496 pm: pacman pkgs: 1488 libs: 402 tools: pamac,yay pm: flatpak
    pkgs: 8
    1: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    3: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 485
  1: cpu: 10.2% command: qemu-system-x86_64 pid: 2259 mem: 1090.3 MiB (3.4%)
  2: cpu: 4.6% command: kwin_wayland pid: 1306 mem: 246.2 MiB (0.7%)
  3: cpu: 4.2% command: vivaldi-bin pid: 3380 mem: 460.2 MiB (1.4%)
  4: cpu: 3.8% command: vivaldi-bin pid: 6313 mem: 251.9 MiB (0.8%)
  5: cpu: 3.5% command: plasmashell pid: 1527 mem: 442.3 MiB (1.4%)
  Memory top: 5 of 485
  1: mem: 1090.3 MiB (3.4%) command: qemu-system-x86_64 pid: 2259 cpu: 10.2%
  2: mem: 727.2 MiB (2.3%) command: pamac-checkupdates pid: 16821 cpu: 1.8%
  3: mem: 460.2 MiB (1.4%) command: vivaldi-bin pid: 3380 cpu: 4.2%
  4: mem: 442.3 MiB (1.4%) command: plasmashell pid: 1527 cpu: 3.5%
  5: mem: 271.6 MiB (0.8%) command: vivaldi-bin pid: 3632 cpu: 0.9%
  Processes: 485 Power: uptime: 37m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 4 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.13 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
It is a known Plasma issue, with a fix hopefully arriving when ddcutil v2.2.7 is released.
You might want to have a read of this recent topic for some advice on dealing with the dimming issue:
