Hi, I have been coming back to a black screen after leaving my PC for extended periods of time. My mouse/keyboard do not do anything but my PC is on which requires a hard reset to make it work again. I have recently installed manjaro and I am fairly new to Linux aswell. I have tried kernel 5.4 which shows no difference and have also checked power options
Any suggestions are most welcome, thank you
root=UUID=a2ee788a-62cc-4500-8c44-96e907343c52 ro quiet apparmor=1
security=apparmor resume=UUID=8c03a71a-a4aa-43a0-9050-6701076f2494
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4011 date: 04/19/2018
Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001137 L2 cache: 3 MiB
bogomips: 76670
Speed: 1372 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 1372 2: 1372 3: 1374 4: 1374 5: 1378 6: 1432 7: 1375 8: 1373 9: 1375
10: 1371 11: 1373 12: 1373
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 07:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x333mm (23.7x13.1")
s-diag: 688mm (27.1")
Monitor-1: HDMI-0 res: 2560x1440 hz: 144 dpi: 108
size: 600x330mm (23.6x13.0") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 10de:10f0
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 09:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.4.89-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8811AU 802.11a/b/g/n/ac WLAN Adapter type: USB
driver: rtl8812au bus ID: 3-3.3:4 chip ID: 0bda:a811 serial: <filter>
IF: enp8s0f3u3u3 state: up mac: <filter>
Local Storage: total: 2.96 TiB used: 77.26 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 2B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LM003 HN-M201RAD
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0008
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZRZ-00HTKB0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A01
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Verbatim model: STORE N GO
size: 7.47 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.0
ID-1: / raw size: 215.39 GiB size: 211.01 GiB (97.97%)
used: 21.19 GiB (10.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 56.9 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 296 Uptime: 1h 25m wakeups: 0 Memory: 15.64 GiB
used: 1.97 GiB (12.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1297 lib: 403 flatpak: 0 Shell: Bash v: 5.1.0 running in: yakuake
inxi: 3.2.02
