Hello!
I have been running Manjaro KDE Plasma on my desktop for a few weeks. Previously, I ran the Cinnamon edition but switched to see if the official versions were more stable. However, I have a couple of reoccurring video glitches. Also, I dual boot with Windows, using different hard drives. I have not had any similar problems using Windows, so I believe the issue is strictly with the Manjaro installation.
Often when I shutdown my system, a flash of pink, glitched lines briefly appears across my display. The system still shuts down though. Also, it tends to occur when I shutdown after waking the system up from sleep mode (not immediately after though, I can use the system for hours before shutting down). It happened more frequently when I ran the Cinnamon edition, sometimes when I was using light applications, such as Libreoffice and Okular. But the main way to reproduce the glitch is to put the system to sleep, wake it, then shutdown.
The other issue, which I believe to be related, is that sometimes, after selecting Manjaro at the GRUB boot menu, the login screen will not show up. A black screen is all that appears. Resetting seems to be the fix, but I felt like it might be related.
So far, I have tried switching kernels, from the latest 5.8, to the LTS, 5.4. Also, I have tried updating the graphics drivers, using both the Manjaro Settings Manager and the Manjaro Hardware Detection command. Both state that I have to correct drivers installed. Though I still believe the issue is with the drivers. One theory I have, based on reading various posts online, is that I will simply need to wait for more updates, to make the system more stable.
Any help would be appreciated. This is my first post, so kindly let me know if I can improve my forum etiquette.
Hardware info:
Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=0a49be96-a621-4f13-baab-956e0ece0ad1 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1407 date: 04/02/2020
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 3072 KiB
bogomips: 86279
Speed: 2621 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3388 2: 2173 3: 2091 4: 2058 5: 2153 6: 4101 7: 2070 8: 2090 9: 3017
10: 1987 11: 1955 12: 4110
conditional, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASRock
driver: amdgpu v: kernel bus ID: 0a:00.0 chip ID: 1002:7340
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-2 res: 2560x1440 hz: 60 dpi: 93
size: 699x393mm (27.5x15.5") diag: 802mm (31.6")
OpenGL:
renderer: Radeon RX 5500 XT (NAVI14 DRM 3.35.0 5.4.60-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 0a:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0c:00.4 chip ID: 1022:1487
Device-3: Sunplus Innovation Lihappe8 Webcam L0485A2SP type: USB
driver: snd-usb-audio,uvcvideo bus ID: 5-2:2 chip ID: 1bcf:0b15
Sound Server: ALSA v: k5.4.60-2-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.29 TiB used: 678.63 GiB (29.0%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: S5Z42105 scheme: GPT
ID-2: /dev/sda vendor: Intel model: SSDSC2KW512G8 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 002C scheme: GPT
ID-3: /dev/sdb vendor: Western Digital model: WD10EZEX-22MFCA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%)
used: 40.48 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 48 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 300 Uptime: 17m Memory: 15.61 GiB used: 2.43 GiB (15.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1288 lib: 368
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
