Running Plasma 5.22.4, KDE Frameworks 5.84, Qt 5.15.2 on Kernal 5.12.19.
For the past several weeks, the system did not show any Update notification. So, I manually did sudo pacman -Syyu
. There were more than 2GB updates to be installed. All went well with the installation. The computer restarted without any problem.
But now I see an upgrade notification. Discover
shows a libtg_owt
system update. When I select Update All
, it produces an error could not find or read package.
I can not uninstall the package because of dependencies.
What is happening? How do I set things right? Or should I leave them as they are?
