discord doesn’t allow me to share any of my application windows but only my whole screen. This is weird because it works flawlessly and allows me to choose the application window when I boot from a manjaro live USB. I am using Xorg on both the usb and my main install.
here’s a screenshot from the usb:
here’s a screenshot from my main install:
and here’s my system info:
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=fe780552-423e-483f-a39f-82c6a23f80b4 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron 3542 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0KHNVP v: A13 serial: <superuser required> UEFI: Dell
v: A13 date: 01/30/2018
ID-1: BAT0 charge: 40.3 Wh (100.0%) condition: 40.3/41.6 Wh (96.9%)
volts: 16.6 min: 14.6 model: SMP-LG2.85 DELL 1C12X31 type: Li-ion
serial: <filter> status: Full
RAM: total: 3.74 GiB used: 1.93 GiB (51.5%)
RAM Report:
Info: model: Intel Core i3-4005U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1696 high: 1697 min/max: 800/1700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1696 2: 1697 3: 1696
4: 1696 bogomips: 13574
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 0c45:670b class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.43 running: no
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel bus-ID: 06:00.0 chip-ID: 168c:0036
class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.6:6 chip-ID: 0cf3:0036 class-ID: e001
Local Storage: total: 931.51 GiB used: 130.39 GiB (14.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0004 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C0
dev-links: cdrom
ID-1: / raw-size: 70 GiB size: 68.35 GiB (97.64%) used: 16.19 GiB (23.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: root
uuid: fe780552-423e-483f-a39f-82c6a23f80b4
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: AE3A-D706
ID-3: /home raw-size: 53 GiB size: 51.87 GiB (97.86%)
used: 5.77 GiB (11.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: home
uuid: d2f8fd7a-7f22-4b97-8ad7-b2fa88b7a451
ID-4: /media/storage raw-size: 702.36 GiB size: 702.36 GiB (100.00%)
used: 108.44 GiB (15.4%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: storage
uuid: 3C8E47E5341FDBFD
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 61a1b64b-c795-4beb-881a-0ea46ed95b4e
ID-1: /dev/sda6 maj-min: 8:6 size: 97.66 GiB fs: ext4 label: backuptimeshift
uuid: 87eb4f07-8984-46b0-8994-9d0d0338e3e7
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 1-1.5:3 info: Microdia Integrated_Webcam_HD type: Video
Device-2: 1-1.6:6 info: Qualcomm Atheros AR9462 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-3: 1-1.8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: 48.0 C
Fan Speeds (RPM): cpu: 1968
Processes: 205 Uptime: 10m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1472 lib: 387
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.12
how do i fix it?
