So I’ve Installed Manjaro XFCE and everything works fine but I installed discord with snap and I have some slight issue with bad characters on the taskbar.
Does anyone know why ?
Here is some infos :
Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ac353d07-6bdf-4ee0-b6d1-b2d92fe1ef82 rw quiet apparmor=1
security=apparmor resume=UUID=d73409cb-00b8-46cb-8eeb-7cc46c815112
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: HP product: OMEN by HP Laptop 15-ce0xx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 838F v: 40.28 serial: <filter> UEFI: American Megatrends
v: F.19 date: 04/18/2019
ID-1: BAT0 charge: 34.5 Wh condition: 43.9/43.9 Wh (100%) volts: 16.2/15.4
model: HP Primary type: Li-ion serial: N/A status: Discharging
Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: D6
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 20004
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 455.28 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-6:4 chip ID: 04f2:b5d6
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia
display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.9.1-1-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: c000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: c000
bus ID: 04:00.0 chip ID: 8086:095a
Local Storage: total: 1.05 TiB used: 35.68 GiB (3.3%)
ID-1: /dev/nvme0n1 vendor: LITE-ON model: CA1-8D128-HP size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: A182 scheme: GPT
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A3T0 scheme: GPT
ID-3: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 29.25 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
scheme: MBR
ID-1: / raw size: 109.91 GiB size: 107.69 GiB (97.97%)
used: 10.50 GiB (9.8%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home raw size: 687.37 GiB size: 675.58 GiB (98.29%)
used: 24.85 GiB (3.7%) fs: ext4 dev: /dev/sda5
ID-1: swap-1 type: partition size: 8.79 GiB used: 327.3 MiB (3.6%)
priority: -2 dev: /dev/nvme0n1p1
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 247 Uptime: 18h 43m Memory: 7.66 GiB used: 3.61 GiB (47.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1138 pacman: 1129
lib: 345 flatpak: 0 snap: 9 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
