Hi, I just joined so idk how things work in here so pardon me if I do any mistake, now on topic:
I found that my discord app fully freeze my whole system when I enable hardware acceleration using parameters : discord --ignore-gpu-blocklist --disable-features=UseOzonePlatform --enable-features=VaapiVideoDecoder --use-gl=desktop --enable-gpu-rasterization --enable-zero-copy
I have to press power button every time to reboot my laptop. Although it works fine without HW acceleration. Is there any fix for this issue?
inxi -Fxzd ✔
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 41.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.18
serial: <superuser required>
Mobo: RR model: Freed_RRS v: V1.18 serial: <superuser required>
UEFI: Insyde v: 1.18 date: 06/18/2020
ID-1: BAT1 charge: 40.0 Wh (100.0%) condition: 40.0/48.9 Wh (81.8%)
volts: 16.6 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x0088
status: Full
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen rev: 0 cache: L2: 2 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 31948
Speed: 1389 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1399 2: 1393 3: 1422 4: 1411 5: 1763 6: 2199 7: 1410 8: 1376
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 01:00.0
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 04:00.0
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 3-1:2
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.42.0
5.15.2-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 04:00.1
Device-2: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus-ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel bus-ID: 03:00.0
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.13 TiB used: 530.54 GiB (45.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0
ID-2: /dev/sdb vendor: Western Digital model: WDS240G2G0B-00EPW0
ID-1: / size: 92.95 GiB used: 21.7 GiB (23.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/sda3
ID-1: swap-1 type: partition size: 4.5 GiB used: 0 KiB (0.0%)
dev: /dev/sda4
Message: No sensor data found. Is lm-sensors configured?
Processes: 274 Uptime: 25m Memory: 14.61 GiB used: 1.9 GiB (13.0%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1054 Shell: Zsh v: 5.8
inxi: 3.3.09
