thank you very much for the help.
inxi -Fv7azy îČ â
Kernel: 5.15.102-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=3a6e263d-3e29-433e-afd3-8524fd688548 rw quiet splash apparmor=1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: SAMSUNG product: 350V5C/351V5C/3540VC/3440VC
v: P09ABE.012.CP serial: <superuser required> Chassis: type: 9 v: 0.1
Mobo: SAMSUNG model: NP350V5C-A0EUK v: BOARD REVISION 00
serial: <superuser required> UEFI: American Megatrends v: P09ABE
date: 07/04/2013
ID-1: BAT1 charge: 46.6 Wh (100.0%) condition: 46.6/48.8 Wh (95.4%)
volts: 12.4 min: 11.1 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full cycles: 163
RAM: total: 5.69 GiB used: 2.25 GiB (39.6%)
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1353 high: 1824 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1197 3: 1197
4: 1824 bogomips: 19961
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Silicon Motion WebCam SC-13HDL11939N type: USB driver: uvcvideo
bus-ID: 1-1.4:5 chip-ID: 2232:1029 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: LVDS-1 model: AU Optronics 0x21ec built: 2011 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.2 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound API: ALSA v: k5.15.102-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Samsung Co driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-1.2:14 chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
Local Storage: total: 698.64 GiB used: 285.64 GiB (40.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS547575A9E384
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: A50A scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208BB rev: SC01
dev-links: cdrom
ID-1: / raw-size: 698.34 GiB size: 686.31 GiB (98.28%)
used: 285.64 GiB (41.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3a6e263d-3e29-433e-afd3-8524fd688548
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3D24-DDD4
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-1.2:14 info: Qualcomm Atheros AR3012 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
Device-3: 1-1.4:5 info: Silicon Motion WebCam SC-13HDL11939N type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: SteelSeries ApS Rival 3 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 1038:1824 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 237 Uptime: 12h 30m wakeups: 5 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1546 libs: 396 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
î° journalctl --boot 0 --no-pager | curl -F 'file=@-' https://0x0.st
Mar 31 23:07:37 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:07:40 manjaro kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=50:b7:c3:4b:51:1b:34:5d:9e:91:a0:cd:08:00 SRC=192.168.1.1 DST=192.168.1.14 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=10435 PROTO=UDP SPT=50242 DPT=5353 LEN=51 MARK=0x3214
Mar 31 23:07:42 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:07:42 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:07:47 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:07:47 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:07:52 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:07:52 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:07:57 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:07:57 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:02 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:02 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:07 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:07 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:12 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:12 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:17 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:17 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:22 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:22 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:27 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:27 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:32 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:32 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:37 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:37 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:42 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:42 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:47 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:47 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:52 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:52 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:57 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:08:57 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:08:58 manjaro kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=50:b7:c3:4b:51:1b:34:5d:9e:91:a0:cd:08:00 SRC=192.168.1.1 DST=192.168.1.14 LEN=71 TOS=0x00 PREC=0x00 TTL=64 ID=17837 PROTO=UDP SPT=40728 DPT=5353 LEN=51 MARK=0x3214
Mar 31 23:09:02 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:02 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:07 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:07 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:12 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:12 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:17 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:17 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:22 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:22 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:27 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:27 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:32 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:32 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:37 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:37 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:42 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:42 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:47 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:47 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:52 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:52 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:09:57 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:09:57 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:02 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:02 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:07 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:07 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:12 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:12 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:17 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:17 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:22 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:22 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:27 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:27 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:32 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mar 31 23:10:32 manjaro touchegg.desktop[2691]: Reconnecting in 5 seconds...
Mar 31 23:10:32 manjaro dbus-daemon[547]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.190' (uid=1000 pid=13688 comm="/usr/lib/libreoffice/program/soffice.bin --writer")
Mar 31 23:10:32 manjaro audit: BPF prog-id=55 op=LOAD
Mar 31 23:10:32 manjaro audit: BPF prog-id=56 op=LOAD
Mar 31 23:10:32 manjaro audit: BPF prog-id=57 op=LOAD
Mar 31 23:10:32 manjaro kernel: audit: type=1334 audit(1680300632.721:793): prog-id=55 op=LOAD
Mar 31 23:10:32 manjaro kernel: audit: type=1334 audit(1680300632.721:794): prog-id=56 op=LOAD
Mar 31 23:10:32 manjaro kernel: audit: type=1334 audit(1680300632.721:795): prog-id=57 op=LOAD
Mar 31 23:10:32 manjaro systemd[1]: Starting Hostname Service...
Mar 31 23:10:32 manjaro dbus-daemon[547]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mar 31 23:10:32 manjaro systemd[1]: Started Hostname Service.
Mar 31 23:10:32 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 31 23:10:32 manjaro kernel: audit: type=1130 audit(1680300632.794:796): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 31 23:10:37 manjaro touchegg.desktop[2691]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
thank you for your help. am old but new to all this but one ov yous have gave me some terminal commands to get info so hopefully i can find out what is happening
I could find some system related issues, which should be fixed:
- There no swap.
While it can run with 6GB RAM, but if you use multiple programs it can easily run out of ram. Note that programs crash and can do weird things.
- Your GPU is pretty old for a rolling release like Manjaro.
Note that new drivers has commonly new features, which can also lead to weird issues. Sometimes you need to disable some new features like power saving, which donât work well on older chipsets. That can lead to all sort of screen corruptions, artifacts and tearing. Commonly, you can disable them.
- Touchegg is there for supporting multi gestures, but it doesnât work with wayland, but with xorg. That is the reason why it keeps spamming this:
If you need it, then switch to xorg. Commonly, you can switch to xorg on the login screen. Bottom left, there is a button, which let you switch. Otherwise, remove it or disable the service.
By all mean, it has nothing to do with hacking, but your computer need maintenance. I see also that you have a firewall enabled and using the piavpn and clamav (a windows virus scanner for linux).
So at the end:
Either this is a result of an old gpu chipset with one of the newest driver features or it is just the fact that you run out of RAM, therefore programs close itself for stability reasons, since there is no swap configured.
You can search the forum and the web how to solve this. If you need assistance, then just ask, and we can do it step by step.
Thanks again for all your help as av not got much ov a clue i have a new build manjaro runs great on. An al try what you say xorg has made it better already
That would be great it you could help please say what to do or point the way and thank you
Maybe start with creating a swap and see if it solves it: Swap - Manjaro
Report back carefully, step by step, what you have done, so one can follow you.
PS: Please use discourse not like a chat app, so not only a sentence per post, but combine it if possible. Thank you.
@jhall I have 2 good news for you:
- At this point, you canât be hacked.
- Now you have time to learn.
lol ect/fstab # that got me back onâŠobviously its ppl messing with me on these old bones lol a bit. if you would ad like help in steps its lots to take in but amazing to. thanks again
I wish what ever is going on stops fgs. This is something av had before its what am going on about. Years now sadly
