Discard option in filesystem
Should I enable discard in filesystem?
Is fstrim capable of trimming the ssd weekly without ‘discard’ enabled?
If you have an ssd remove discard from your /etc/fstab and enable periodic trim by
systemctl enable --now fstrim.timer
Currently, the recommended method. Will trim your mounted ssd partitions, weekly.
Reference:
Solid state drive - ArchWiki
Yup…have enabled fastrim
Haven’t selected ‘discard’ during installation…so I was confused whether to enable that or not…seems like all is ok… Thnx :grinning:
You can check the status by
systemctl status fstrim.timer
Yup…I was confused by the ‘discard’ word there:
" The service executes fstrim on all mounted filesystems on devices that support the discard operation."
Yup…it is active…trim every week
