Disabling display makes KDE go crazy, when it's not fully powered off
Hi everybody,
I have an issue with disabling my second (from 3) (Acer) displays in the KDE system settings.
When I uncheck the “active” checkbox, the display turns off correctly, but a few seconds after I do that, it makes the settings UI go crazy.
I hear the “device unplugged” - “device attached” every few seconds sound in the background.
In addition, my third display (LG), which should be disabled all the time, appears in the UI for a second or so and then disappears again.
This makes the whole UI very laggy, because of the constant hardware changes.
The only way to stop this, is to power off the second display (Acer) completely.
I tried to make a screencast, but it is stuttering heavily, probably due to the hardware changes as well.
I could find the following information in the system logs, maybe it contains something interesting?:
22.05.25 16:03	systemd	Started Anzeige-Einrichtung.
22.05.25 16:03	kwin_wayland	kwin_libinput: Libinput: event4  - debounce state: DEBOUNCE_STATE_IS_UP_WAITING → DEBOUNCE_EVENT_TIMEOUT → DEBOUNCE_STATE_IS_UP
22.05.25 16:03	kwin_wayland	kwin_scene_opengl: 0x3: using glMapBufferRange(buffer 15, offset 0, length 64) to update a GL_STATIC_DRAW buffer
22.05.25 16:03	kwin_wayland	kwin_core: activating KWin::XdgToplevelWindow(0x5c417048b150, surface=KWin::SurfaceInterface(0x5c416fd71110), caption="Anzeige-Einrichtung — Systemeinstellungen") KWin::SurfaceInterface(0x5c416fd71110) on behalf of KWin::SurfaceInterface(0x5c416f7d2610) into Window(0x0)
22.05.25 16:03	kwin_wayland	kwin_libinput: Libinput: event4  - debounce state: DEBOUNCE_STATE_IS_UP → DEBOUNCE_EVENT_PRESS → DEBOUNCE_STATE_IS_DOWN_WAITING
22.05.25 16:03	kwin_wayland	kwin_libinput: Libinput: event4  - debounce state: DEBOUNCE_STATE_IS_DOWN_WAITING → DEBOUNCE_EVENT_TIMEOUT → DEBOUNCE_STATE_IS_DOWN
22.05.25 16:03	kwin_wayland	kwin_libinput: Libinput: event4  - debounce state: DEBOUNCE_STATE_IS_DOWN → DEBOUNCE_EVENT_RELEASE → DEBOUNCE_STATE_IS_UP_DETECTING_SPURIOUS
22.05.25 16:03	kwin_wayland	kwin_libinput: Libinput: event4  - debounce state: DEBOUNCE_STATE_IS_UP_DETECTING_SPURIOUS → DEBOUNCE_EVENT_TIMEOUT_SHORT → DEBOUNCE_STATE_IS_UP_WAITING
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Connected", countMode=37), DrmConnector(id=113, gpu="/dev/dri/card2", name="DP-2", connection="Connected", countMode=44), DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=91, gpu="/dev/dri/card2"), DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Unassigning CRTC from connector 132
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card2", name="DP-2", connection="Connected", countMode=44), DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=91, gpu="/dev/dri/card2"), DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Assigning CRTC 91 to connector 113
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Testing CRTC assignment... passed
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=99, gpu="/dev/dri/card1", name="HDMI-A-1", connection="Connected", countMode=44), DrmConnector(id=109, gpu="/dev/dri/card1", name="HDMI-A-2", connection="Disconnected", countMode=0), DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=53, gpu="/dev/dri/card1"), DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Unassigning CRTC from connector 99
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=109, gpu="/dev/dri/card1", name="HDMI-A-2", connection="Disconnected", countMode=0), DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=53, gpu="/dev/dri/card1"), DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=53, gpu="/dev/dri/card1"), DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=53, gpu="/dev/dri/card1"), DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_core: precision lost! floating value sent to X 3840.2
22.05.25 16:03	kwin_wayland	kwin_core: precision lost! floating value sent to X 2160.2
22.05.25 16:03	kwin_wayland	kwin_core: precision lost! floating value sent to X 2098.6
22.05.25 16:03	kwin_wayland	kwin_xwl: Setting primary KWin::DrmOutput(0x5c416e248ed0, name="DP-2", geometry=QRect(0,0 2743x1543), scale=1.4) 33
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Received change event for monitored drm device "/dev/dri/card2"
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Removing output KWin::DrmOutput(0x5c416e249960, name="HDMI-A-4", geometry=QRect(-1920,602 1920x1080), scale=1)
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card2", name="DP-2", connection="Connected", countMode=44), DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=91, gpu="/dev/dri/card2"), DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Assigning CRTC 53 to connector 99
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=109, gpu="/dev/dri/card1", name="HDMI-A-2", connection="Disconnected", countMode=0), DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:03	kwin_wayland	kwin_scene_opengl: Egl Initialize succeeded
22.05.25 16:03	kwin_wayland	kwin_scene_opengl: EGL version:  1 . 5
22.05.25 16:03	kwin_wayland	kwin_scene_opengl: Created EGL context with attributes:
Version requested:	true
Version:	3.1
Robust:	true
Reset on video memory purge:	false
Forward compatible:	false
Core profile:	false
Compatibility profile:	false
High priority:	true
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: chose egl import with format AR24 and modifier 0
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: New output on GPU /dev/dri/card2: Acer S222HQL
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card2", name="DP-2", connection="Connected", countMode=44), DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Connected", countMode=37)) with QList(DrmObject(id=91, gpu="/dev/dri/card2"), DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Connected", countMode=37)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Connected", countMode=37)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:03	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Connected", countMode=37)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Received change event for monitored drm device "/dev/dri/card2"
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Removing output KWin::DrmOutput(0x5c41709b63f0, name="HDMI-A-4", geometry=QRect(-1920,602 1920x1080), scale=1)
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card2", name="DP-2", connection="Connected", countMode=44), DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=91, gpu="/dev/dri/card2"), DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Assigning CRTC 91 to connector 113
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=122, gpu="/dev/dri/card2", name="DP-3", connection="Disconnected", countMode=0), DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=127, gpu="/dev/dri/card2", name="DP-4", connection="Disconnected", countMode=0), DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=132, gpu="/dev/dri/card2", name="HDMI-A-4", connection="Disconnected", countMode=0)) with QList(DrmObject(id=95, gpu="/dev/dri/card2"), DrmObject(id=99, gpu="/dev/dri/card2"), DrmObject(id=103, gpu="/dev/dri/card2"), DrmObject(id=107, gpu="/dev/dri/card2"), DrmObject(id=111, gpu="/dev/dri/card2"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Testing CRTC assignment... passed
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=99, gpu="/dev/dri/card1", name="HDMI-A-1", connection="Connected", countMode=44), DrmConnector(id=109, gpu="/dev/dri/card1", name="HDMI-A-2", connection="Disconnected", countMode=0), DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=53, gpu="/dev/dri/card1"), DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Assigning CRTC 53 to connector 99
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=109, gpu="/dev/dri/card1", name="HDMI-A-2", connection="Disconnected", countMode=0), DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=113, gpu="/dev/dri/card1", name="DP-1", connection="Disconnected", countMode=0), DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:04	kwin_wayland	kwin_wayland_drm: Attempting to match QList(DrmConnector(id=120, gpu="/dev/dri/card1", name="HDMI-A-3", connection="Disconnected", countMode=0)) with QList(DrmObject(id=75, gpu="/dev/dri/card1"), DrmObject(id=97, gpu="/dev/dri/card1"))
22.05.25 16:04	kwin_wayland	kwin_xwl: Setting primary KWin::DrmOutput(0x5c416e248ed0, name="DP-2", geometry=QRect(0,0 2743x1543), scale=1.4) 33
22.05.25 16:04	kwin_wayland	kwin_core: precision lost! floating value sent to X 8141
22.05.25 16:04	kwin_wayland	kwin_core: precision lost! floating value sent to X 2419.2
22.05.25 16:04	kwin_wayland	kwin_core: precision lost! floating value sent to X 2098.6
22.05.25 16:04	kernel	amdgpu 0000:03:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
System info:
inxi --filter --verbosity=8         ✔
  Kernel: 6.12.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=d308b8a4-924c-4601-b983-c34485cd1d3a rw quiet apparmor=1
    security=apparmor resume=UUID=5ee1d153-9e4d-4840-9b3c-ff5fb8a50026
    udev.log_priority=3 intel_iommu=on preempt=voluntary
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: Z370 KRAIT GAMING (MS-7B46) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 1.C3 date: 11/16/2021
  System RAM: total: 32 GiB available: 31.22 GiB used: 13.21 GiB (42.3%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3000C16-8GISB
    serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    data: 64 total: 64 manufacturer: Crucial part-no: CT8G4DFD8213.C16FHP
    serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
    serial: <filter>
  Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 1498 min/max: 800/4300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1498 2: 1498 3: 1498 4: 1498 5: 1498 6: 1498
    bogomips: 43212
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: none off: HDMI-A-1 empty: DP-1,HDMI-A-2,HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800
    XT / 6900 XT] vendor: Sapphire Pulse driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2 off: HDMI-A-4
    empty: DP-3,DP-4,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:8
    chip-ID: 0c45:63ab class-ID: 0102 serial: <filter>
  Device-4: MacroSilicon driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
    chip-ID: 534d:2109 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    unloaded: radeon alternate: fbdev,vesa dri: radeonsi,iris gpu: amdgpu,i915
    display-ID: 0
  Monitor-1: DP-2 model: Philips PHL 326M6V serial: <filter> built: 2019
    res: mode: 3840x2160 hz: 60 scale: 140% (1.4) to: 2743x1543 dpi: 139
    gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green: x: 0.259 y: 0.686 blue:
    x: 0.153 y: 0.055 white: x: 0.314 y: 0.329 size: 698x398mm (27.48x15.67")
    diag: 801mm (31.5") ratio: 16:9 modes: 3840x2160, 1920x2160, 2560x1440,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
  Monitor-2: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
    built: 2021 res: 3840x2160 dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
    green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1920x1080i, 1280x1024, 1360x768,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x576i, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
    unhandled CEA mode 98 5: parse_edid: unhandled CEA mode 99 6: parse_edid:
    unhandled CEA mode 100
  Monitor-3: HDMI-A-4 model: Acer S222HQL serial: <filter> built: 2011
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.643 y: 0.349 green:
    x: 0.286 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
    LLVM 19.1.7 DRM 3.61 6.12.29-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:73bf surfaces: N/A device: 1 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 25.0.5-arch1.1 device-ID: 8086:3e92 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
  Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-5: Holtek HT82A834R Audio MCU
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-7.4:7 chip-ID: 04d9:2834 class-ID: 0300
  API: ALSA v: k6.12.29-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF-ID-1: br-746e592ab68b state: down mac: <filter>
  IF-ID-2: br-a61ab5459224 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: FritzBoxHorbach state: unknown speed: N/A duplex: N/A mac: N/A
  IF-ID-5: veth5288667 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-7: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 2.3 TiB used: 955.21 GiB (40.6%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 45.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHII240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler Max
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
    serial: <filter> fw-rev: 1000 scheme: MBR
  ID-5: /dev/sdg maj-min: 8:96 vendor: Kingston model: DT microDuo 3C
    size: 29.31 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS30 rev: 1.01
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 544.21 GiB (60.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d308b8a4-924c-4601-b983-c34485cd1d3a
    used: 29 MiB (9.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 8C6B-9D91
  ID-3: /media/Festplatte raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 407.26 GiB (44.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: Festplatte Neu uuid: 8d2954fc-ff7f-41e1-9784-945a947b25b0
  ID-4: /run/media/laurenz/USBOTG raw-size: 29.3 GiB
    size: 29.28 GiB (99.90%) used: 3.71 GiB (12.7%) fs: vfat dev: /dev/sdg1
    maj-min: 8:97 label: USBOTG uuid: A315-96A0
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 5ee1d153-9e4d-4840-9b3c-ff5fb8a50026
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 222.89 GiB fs: ntfs label: N/A
    uuid: 00461D84461D7B9A
  ID-3: /dev/sda3 maj-min: 8:3 size: 675 MiB fs: ntfs label: N/A
    uuid: F83E78FE3E78B6EA
  ID-4: /dev/sdc1 maj-min: 8:33 size: 238.47 GiB fs: exfat label: NicerDicer
    uuid: EFE7-FC62
  Device-1: 1-2:2 info: MacroSilicon type: video,audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.3:5 info: Solid Year Thermaltake MEKA G-Unit Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 060b:5253 class-ID: 0300
  Device-2: 1-7.4:7 info: Holtek HT82A834R Audio MCU type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 1-8:4 info: Micro Star MSI GM41 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0d41 class-ID: 0300
  Device-4: 1-9:6 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 1.1
  Device-5: 1-13:8 info: Microdia USB 2.0 Camera type: video,audio
  Hub-3: 1-14:9 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-14.4:10 info: QinHeng CH340 serial converter
    type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
    chip-ID: 1a86:7523 class-ID: ff00
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Device-1: 2-2:2 info: Kingston DT microDuo 3C type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 0951:16ae class-ID: 0806
    serial: <filter>
  Device-2: 2-7:3 info: Transcend Information microSD/SD/CF UHS-II Card
    Reader [RDF8 RDF9] type: mass storage driver: usb-storage interfaces: 1
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    power: 800mA chip-ID: 8564:4000 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Device-1: 4-2:2 info: Kingston DataTraveler Max type: mass storage
    driver: uas interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 0951:177f class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
    mem: 46.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 2601 pm: pacman pkgs: 2595 libs: 488 tools: pamac pm: flatpak
    pkgs: 6
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mirrors.xtom.de/bioarchlinux/$arch
  Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
    1: https://cdn-mirror.chaotic.cx/$repo/$arch
    2: https://geo-mirror.chaotic.cx/$repo/$arch
    3: https://br-mirror.chaotic.cx/$repo/$arch
    4: https://bg-mirror.chaotic.cx/$repo/$arch
    5: https://ca-mirror.chaotic.cx/$repo/$arch
    6: https://cl-mirror.chaotic.cx/$repo/$arch
    7: https://de-2-mirror.chaotic.cx/$repo/$arch
    8: https://de-3-mirror.chaotic.cx/$repo/$arch
    9: https://de-4-mirror.chaotic.cx/$repo/$arch
    10: https://fr-mirror.chaotic.cx/$repo/$arch
    11: https://gr-mirror.chaotic.cx/$repo/$arch
    12: https://in-mirror.chaotic.cx/$repo/$arch
    13: https://in-2-mirror.chaotic.cx/$repo/$arch
    14: https://in-3-mirror.chaotic.cx/$repo/$arch
    15: https://in-4-mirror.chaotic.cx/$repo/$arch
    16: https://kr-mirror.chaotic.cx/$repo/$arch
    17: https://es-mirror.chaotic.cx/$repo/$arch
    18: https://es-2-mirror.chaotic.cx/$repo/$arch
    19: https://us-mi-mirror.chaotic.cx/$repo/$arch
    20: https://us-tx-mirror.chaotic.cx/$repo/$arch
    21: https://us-ut-mirror.chaotic.cx/$repo/$arch
    1: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
Processes:
  CPU top: 5 of 379
  1: cpu: 100% command: ps pid: 106827 mem: 4.62 MiB (0.0%)
  2: cpu: 14.4% command: qemu-system-x86_64 pid: 1111 mem: 2163.4 MiB (6.7%)
  3: cpu: 13.5% command: firefox pid: 85356 mem: 803.5 MiB (2.5%)
  4: cpu: 13.2% command: spotify pid: 3101 mem: 581.7 MiB (1.8%)
  5: cpu: 12.7% command: kwin_wayland pid: 1791 mem: 649.7 MiB (2.0%)
  Memory top: 5 of 379
  1: mem: 2163.4 MiB (6.7%) command: qemu-system-x86_64 pid: 1111 cpu: 14.4%
  2: mem: 803.5 MiB (2.5%) command: firefox pid: 85356 cpu: 13.5%
  3: mem: 746.1 MiB (2.3%) command: plasmashell pid: 2066 cpu: 2.3%
  4: mem: 743.7 MiB (2.3%) command: spectacle pid: 100780 cpu: 9.2%
  5: mem: 687.9 MiB (2.1%) command: zapzap started-by: python pid: 2339
    cpu: 1.5%
  Processes: 379 Power: uptime: 5h 3m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.38
If you think this is maybe better suited for a upstream report, feel free to tell me where exactly.
