Greetings,
Is there an option to disable the shadow of kwin?
best regards
Storm
Greetings,
best regards
Storm
Well, there are two ways to go about that.
The most elegant way is to install a window decoration without shadows, the likes of which you can find at store.kde.org.
The crude way is to disable the compositor, but then you’ll have to miss out on all other effects as well, such as translucency.
we have a setting in decorators → Breeze, we have a hidden icon/btn at bottom right in all images
open a dialog (diff for all decorator)
Tag shadows : size… power et color
For styles (Brise,…) : same hidden button
