Hi all,
I use 2 separate mice, my laptops touchpad aswell as a Logitech g502. I was wondering if i could disable mouse acceleration via some sort of config file?
Many thanks
Hi all,
Many thanks
Xfce you say?
LANG=C xfce4-settings-manager
or use the start menu to access it
go to “Mouse and Touchpad” - the “Devices” tab (it is the one that it opens with by default)
There you can adjust it - per device (the device selector it at the top)
