Hi there,
I’ve recently started using a Bluetooth speaker with my system and have noticed that, while the speaker stays connected, whenever audio is resumed after a pause in audio playback there is a short delay until audio starts playing. It is reminding me of the power saving feature in Pipewire that was causing the same issue with analog audio until I commented out suspend-node
in /etc/pipewire/media-session.d
. While that fixed the issues with my analog audio, it did not fix the issue for Bluetooth. Does anyone know of a way to disable the power saving for Bluetooth?
Thanks
My inxi -Fz
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.24.0
Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: B150 GAMING M3 (MS-7978) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: B.C0
date: 07/05/2018
Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 4000 min/max: 800/4200 cores: 1: 4000 2: 4000 3: 4000
4: 4000 5: 4000 6: 4000 7: 4000 8: 4000
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nvidia v: 510.47.03
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org 1.21.1.3 driver: loaded: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03
Device-1: NVIDIA GP102 HDMI Audio driver: N/A
Device-3: ASUSTek Xonar SoundCard type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.45 running: yes
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet driver: alx
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb
Local Storage: total: 4.19 TiB used: 2.78 TiB (66.2%)
ID-1: /dev/sda vendor: Western Digital model: WD40EFRX-68N32N0
ID-2: /dev/sdb vendor: Kingston model: SV300S37A240G size: 223.57 GiB
ID-3: /dev/sdc vendor: SanDisk model: SDSSDX120GG25 size: 111.79 GiB
ID-4: /dev/sdd vendor: Western Digital model: WD2500AAJS-65B4A0
ID-1: / size: 71.72 GiB used: 59.96 GiB (83.6%) fs: ext4 dev: /dev/sdb5
ID-2: /boot/efi size: 187.1 MiB used: 258 KiB (0.1%) fs: vfat
dev: /dev/sdb1
ID-3: /home size: 109.37 GiB used: 58.28 GiB (53.3%) fs: ext4
dev: /dev/sdb6
ID-1: swap-1 type: file size: 8 GiB used: 2 MiB (0.0%) file: /swapfile
System Temperatures: cpu: 29.8 C pch: 50.0 C mobo: 27.8 C gpu: nvidia
temp: 61 C
Processes: 349 Uptime: 34m Memory: 15.58 GiB used: 6.9 GiB (44.3%)
Shell: Bash inxi: 3.3.12
My media-session.conf
# Media session config file for PipeWire version "0.3.26" #
context.properties = {
# Properties to configure the session and some
# modules.
#mem.mlock-all = false
#support.dbus = true
#log.level = 2
#alsa.seq.name = Midi-Bridge
context.spa-libs = {
# Mapping from factory name to library.
api.bluez5.* = bluez5/libspa-bluez5
api.alsa.* = alsa/libspa-alsa
api.v4l2.* = v4l2/libspa-v4l2
api.libcamera.* = libcamera/libspa-libcamera
context.modules = [
#{ name = <module-name>
# [ args = { <key> = <value> ... } ]
# [ flags = [ [ ifexists ] [ nofail ] ]
# Loads a module with the given parameters.
# If ifexists is given, the module is ignored when it is not found.
# If nofail is given, module initialization failures are ignored.
# Uses RTKit to boost the data thread priority.
{ name = libpipewire-module-rtkit
args = {
#nice.level = -11
#rt.prio = 88
#rt.time.soft = 200000
#rt.time.hard = 200000
flags = [ ifexists nofail ]
# The native communication protocol.
{ name = libpipewire-module-protocol-native }
# Allows creating nodes that run in the context of the
# client. Is used by all clients that want to provide
# data to PipeWire.
{ name = libpipewire-module-client-node }
# Allows creating devices that run in the context of the
# client. Is used by the session manager.
{ name = libpipewire-module-client-device }
# Makes a factory for wrapping nodes in an adapter with a
# converter and resampler.
{ name = libpipewire-module-adapter }
# Allows applications to create metadata objects. It creates
# a factory for Metadata objects.
{ name = libpipewire-module-metadata }
# Provides factories to make session manager objects.
{ name = libpipewire-module-session-manager }
session.modules = {
# These are the modules that are enabled when a file with
# the key name is found in the media-session.d config directory.
# the default bundle is always enabled.
default = [
flatpak # manages flatpak access
portal # manage portal permissions
v4l2 # video for linux udev detection
#libcamera # libcamera udev detection
#suspend-node # suspend inactive nodes
policy-node # configure and link nodes
#metadata # export metadata API
#default-nodes # restore default nodes
#default-profile # restore default profiles
#default-routes # restore default route
#streams-follow-default # move streams when default changes
#alsa-seq # alsa seq midi support
#alsa-monitor # alsa udev detection
bluez5 # bluetooth support
#bluez5-autoswitch
#restore-stream # restore stream settings
#logind # systemd-logind seat support
with-audio = [
metadata
default-nodes
default-profile
default-routes
alsa-seq
alsa-monitor
with-alsa = [
with-audio
with-jack = [
with-audio
with-pulseaudio = [
with-audio
bluez5
logind
restore-stream
