Dirty Frag solucion
Buen dia, pregunta, es necesario escribir la sentencia que fue enviada para mitigar el efecto de Dirty Frag o es solo para servidores, empresas, etc.?
Muchas gracias
  Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
    security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
    wm: kwin_wayland tools: avail: xscreensaver vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Dell product: Latitude 3420 v: N/A
  Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> part-nu: 0A7B
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.3.1
    date: 04/23/2021
  ID-1: BAT0 charge: 30.9 Wh (89.1%) condition: 34.7/41 Wh (84.7%) volts: 11.34
    min: 11.25 model: SMP DELL MGCM514 type: Li-poly serial: <filter> charging:
    status: discharging type: adaptive
    avail: adaptive,custom,fast,standard,trickle cycles: N/A
  System RAM: total: 12 GiB available: 11.42 GiB used: 2.91 GiB (25.5%)
  Device-1: DIMM 1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 0198000080AD part-no: 9905700-053.A00G serial: <filter>
  Device-2: DIMM 2 type: DDR4 detail: synchronous size: 4 GiB
    manufacturer: 01980000802C part-no: KCDT82-MIE serial: <filter>
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 22118
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:6d1a
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: mode: 1366x768
    hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 11.16 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 6 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.0.6-arch1.1
    device-ID: 8086:9a49 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: Dell driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active
    tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 1.36 TiB used: 100.22 GiB (7.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0N01 temp: 28.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
  ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 66.73 GiB (87.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 348 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 1C6D-8153
  ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
    used: 33.5 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
  ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: vfat label: N/A
    uuid: 7616-A725
  ID-2: /dev/sda2 maj-min: 8:2 size: 921.73 GiB fs: ext4 label: endeavouros
    uuid: c5836b3c-5bb7-4d47-8d49-56202845d398
  ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: swap
    uuid: 0a93cecb-4ed9-4925-aff6-72849d60ff7e
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Logitech Nano Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 34.0 C mobo: 30.0 C
  Fan Speeds (rpm): fan-1: 0
  Processes: 269 Power: uptime: 29m states: freeze,mem,disk suspend: s2idle
    image: 4.51 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 260
  Packages: 1716 pm: pacman pkgs: 1683 libs: 466 tools: pamac,yay pm: flatpak
    pkgs: 33 Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
English translation:
Good morning, question, is it necessary to write the sentence that was sent to mitigate the effect of
Dirty Frag or is it only for servers, companies, etc.?
Thank you so much
A post was merged into an existing topic: [ALERT] Dirty Frag - Root Privilege Vulnerability
