Digital artifacts with Pro Audio profile on PipeWire
Dear Manjaro Audio users
I use an RME Fireface UFX in class compliant mode.
The Fireface UFX is connected to my computer via a high-quality (not audiophile, but decent) USB cable. I use PipeWire with WirePlumber.
I get digital artifacts with the Pro Audio profile (activated via PulseAudio Volume Control > Configuration), while this is not the case with the “normal” profile. I can hear the artifacts both on the speakers connected to the RME and on the headphones (connected to the RME as well). However, if I record the signal with OBS, for example, the artifacts are not present on the recording.
To me, the artifacts sound similar to those audible when playing with the jog wheel on an old ADAT device. They are grinding, hissing, beeping digital noises.
The playback source doesn’t seem to matter. Bitwig Studio as Flatpak (via PipeWire) as well as QuodLibet (Flatpak too) or even Firefox (Flatpak) are affected.
Does anyone have an idea what I could do to fix this?
Many thanks in advance!
My system
  Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=7e83c4e1-9989-4fe6-b427-929ed254be96 rw udev.log_priority=3
    splash amd_pstate.shared_mem=1 amd_pstate=active
  Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: ProArt X570-CREATOR WIFI v: Rev X.0x
    UEFI: American Megatrends v: 0801 date: 04/26/2022
  Device-1: hid-CC2015200V3J5R9A9-battery model: Apple Inc. Magic Trackpad 2
    serial: N/A charge: N/A status: discharging
  System RAM: total: 64 GiB available: 62.71 GiB used: 8.38 GiB (13.4%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C16D4/16GX serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 2139 high: 4192 min/max: 550/4673 scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3987 2: 550 3: 3994
    4: 550 5: 550 6: 3873 7: 4001 8: 3898 9: 550 10: 4179 11: 4192 12: 550
    13: 4192 14: 4185 15: 550 16: 4186 17: 550 18: 550 19: 550 20: 550 21: 3515
    22: 550 23: 550 24: 550 bogomips: 182137
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: AMD Ellesmere [Radeon Pro WX 7100] driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-4
    empty: DP-1,DP-2,DP-3 bus-ID: 3e:00.0 chip-ID: 1002:67c4 class-ID: 0300
    temp: 70.0 C
  Device-2: AMD Ellesmere [Radeon Pro WX 7100] driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: none empty: DP-5, DP-6, DP-7, DP-8 bus-ID: 3f:00.0
    chip-ID: 1002:67c4 class-ID: 0300 temp: 43.0 C
  Device-3: Logitech BRIO 4K Stream Edition
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-2.4.2:4
    chip-ID: 046d:086b class-ID: 0300 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-4 model: VP32UQ serial: <filter> built: 2023 res: 3840x2160
    dpi: 139 gamma: 1.2 size: 700x390mm (27.56x15.35") diag: 801mm (31.5")
    ratio: 16:9 modes: max: 3840x2160 min: 640x480
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Pro WX 7100 Graphics
    (radeonsi polaris10 LLVM 17.0.6 DRM 3.57 6.9.2-1-MANJARO)
    device-ID: 1002:67c4 memory: 7.81 GiB unified: no display-ID: :0.0
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 3e:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 3f:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 42:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Microchip (formerly SMSC) Fireface UFX (23609326)
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 3-4:3 chip-ID: 0424:3fb8 class-ID: 0103 serial: <filter>
  Device-5: Atmel Intech Studio: Grid
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2.4.4.1:9 chip-ID: 03eb:ecad
    class-ID: 0103
  Device-6: RODE Microphones NT-USB driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2.4.4.2:10
    chip-ID: 19f7:0003 class-ID: 0300
  Device-7: Logitech BRIO 4K Stream Edition
  API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Aquantia AQtion AQC113CS NBase-T/IEEE 802.3an Ethernet [Antigua
    10G] vendor: ASUSTeK ProArt X570-CREATOR WIFI driver: atlantic v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 2 port: N/A bus-ID: 38:00.0
    chip-ID: 1d6a:94c0 class-ID: 0200
  IF: enp56s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 39:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp57s0 state: up mac: <filter>
  Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 3a:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp58s0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 3.64 TiB used: 917.38 GiB (24.6%)
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 56.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
    fw-rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 526.11 GiB (29.2%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:5 label: N/A
    uuid: 7e83c4e1-9989-4fe6-b427-929ed254be96
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
    uuid: 9240-29B4
  ID-3: /mnt/e410ce8d-4e17-4b15-801a-c3419dfa69ca raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 391.28 GiB (21.3%) fs: ext4 dev: /dev/nvme1n1p1
    maj-min: 259:3 label: backup uuid: e410ce8d-4e17-4b15-801a-c3419dfa69ca
  ID-4: /var/nfs/vault/amadeus raw-size: N/A size: 21.65 TiB
    used: 9.84 TiB (45.4%) fs: nfs4 remote: vault.local:/volume1/amadeus
  ID-5: /var/nfs/vault/backup raw-size: N/A size: 21.65 TiB
    used: 9.84 TiB (45.4%) fs: nfs4 remote: vault.local:/volume1/backup
  ID-6: /var/nfs/vault/shared raw-size: N/A size: 21.65 TiB
    used: 9.84 TiB (45.4%) fs: nfs4 remote: vault.local:/volume1/shared
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 32 GiB used: 2.5 MiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
    uuid: 68e6c686-aa00-47e4-93d2-b1e6ca82a495
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:3 info: Microchip (formerly SMSC) Fireface UFX (23609326)
    type: audio driver: snd-usb-audio interfaces: 5 rev: 2.0
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-2:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-6: 5-4:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
  Hub-7: 5-4.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Hub-8: 5-4.4.4:7 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Hub-9: 5-4.4.4.4:9 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Hub-10: 5-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-11: 5-6:6 info: Genesys Logic Hub ports: 3 rev: 2.0
  Device-1: 5-6.1:8 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-13: 6-4:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
  Hub-14: 6-4.4:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Hub-15: 6-4.4.4:4 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Hub-16: 6-4.4.4.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Hub-17: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-18: 7-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Device-1: 7-2.1:3 info: Holtek USB-HID Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0192 class-ID: 0300
  Device-2: 7-2.3:4 info: Apple Magic Trackpad 2 type: HID,mouse
    driver: magicmouse,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 05ac:0265 class-ID: 0300
    serial: <filter>
  Hub-19: 7-2.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Device-1: 7-2.4.1:6 info: Wings Tech Xtrfy MZ1 type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 480mA chip-ID: 2ea8:2203 class-ID: 0301
  Device-2: 7-2.4.3:7 info: Arduino SA Leonardo (CDC ACM HID)
    type: abstract (modem),CDC-data,HID driver: cdc_acm,hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2341:8036 class-ID: 0300 serial: <filter>
  Hub-20: 7-2.4.4:8 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Device-1: 7-2.4.4.1:9 info: Atmel Intech Studio: Grid
    type: abstract (modem),CDC-data,mouse,keyboard,audio
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    chip-ID: 03eb:ecad class-ID: 0103
  Device-2: 7-2.4.4.2:10 info: RODE Microphones NT-USB type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-21: 7-2.4.4.4:11 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
  Hub-22: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-23: 8-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Hub-24: 8-2.4:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Device-1: 8-2.4.2:4 info: Logitech BRIO 4K Stream Edition
    type: video,audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
    interfaces: 5 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 046d:086b class-ID: 0300
    serial: <filter>
  Hub-25: 8-2.4.4:5 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  Hub-26: 8-2.4.4.4:6 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
  System Temperatures: cpu: 63.0 C mobo: 45.0 C
  Fan Speeds (rpm): cpu: 0 fan-1: 1136 fan-2: 1746 fan-3: 983 fan-4: 502
    fan-5: 0 fan-6: 0 fan-7: 0
  GPU: device: amdgpu temp: 70.0 C fan: 1168 watts: 21.25 device: amdgpu
    temp: 43.0 C watts: 11.23
  Processes: 521 Power: uptime: 53m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.07 GiB services: gsd-power,
    tool: systemctl
  Packages: 1589 pm: pacman pkgs: 1450 libs: 427 tools: gnome-software,pamac
    pm: flatpak pkgs: 139 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: sh
    default: Zsh v: 5.9 running-in: kgx inxi: 3.3.34
