Difficulty Gaming
Hello, i’am a new Linux user,
I’ve tested ubuntu and debian and Manjaro some days, and i decided to keep Manjaro in my computer, i liked this distribution.
what bothers me is that I can’t play league of legends in this distribution as in the others, (the performance of the game is very lower compared to Windows and ubuntu).
No solution or guide to offer? (I am a Linux newbie).
Thanks :’)))
What hardware are you using?
In order for the people here help you, I recommend you open a terminal and post out inxi -Fazzy like described here How to provide good information
That will give us the specs of your machine. This will also teach you how to wrap terminal output in code here.
Here is it
Please post this as text, not images. Please put format your text with ``` at the beginning and end of your output.
Ok, sorry, here is it :
inxi -G
  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
  Device-2: Quanta HP Webcam type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.1
and :
inxi -Fazzy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=568ed794-2b8a-45ef-aa9b-d05c2163521c rw quiet splash apparmor=1
  security=apparmor resume=UUID=a0843789-1453-4b10-93bc-7039f49cc3d9
  udev.log_priority=3
  Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP 250 G7 Notebook PC
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8532 v: 70.29 serial: <filter> UEFI: Insyde v: F.18
  date: 03/15/2019
  ID-1: BAT1 charge: 38.8 Wh condition: 39.1/41.0 Wh (95%) volts: 12.9/11.4
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Unknown
  Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: DE L2 cache: 6 MiB
  bogomips: 28808
  Speed: 600 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
  4: 600 5: 600 6: 600 7: 599 8: 600
  Type: srbds mitigation: TSX disabled
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
  Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus ID: 1-5:3
  chip ID: 0408:5321 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :1 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 01:00.0
  chip ID: 10ec:8168
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtl8821ce v: N/A
  modules: rtw88_8821ce,8821ce port: 3000 bus ID: 02:00.0 chip ID: 10ec:c821
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 30
  Local Storage: total: 476.94 GiB used: 163.98 GiB (34.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS512GSSD230S
  size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: S6OA
  ID-1: / raw size: 467.84 GiB size: 459.5 GiB (98.22%)
  used: 163.98 GiB (35.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 36.0 C mobo: 29.8 C
  Processes: 266 Uptime: 8h 15m wakeups: 1 Memory: 15.53 GiB
  used: 2.5 GiB (16.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.0 Packages: 1542 pacman: 1529 lib: 450 flatpak: 0 snap: 13
  Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.2.01
Hi, like this:
inxi -G
Display: x11 server: [X.Org](http://X.Org) 1.20.10 driver: intel unloaded: modesetting
Even better to do it like this:
Summary
inxi -Fazzy
udev.log_priority=3
v: Type1ProductConfigId serial: Chassis: type: 10 serial:
Mobo: HP model: 8532 v: 70.29 serial: UEFI: Insyde v: F.18
date: 03/15/2019
status: Unknown
bogomips: 28808
Display: x11 server: [X.Org](http://X.Org) 1.20.10 compositor: gnome-shell driver: intel
diag: 389mm (15.3")
direct render: Yes
chip ID: 10ec:8168
IF: eno1 state: down mac:
IF: wlo1 state: up mac:
serial: rev: S6OA
^[[AInfo:
Welcome @TFate,
Leage of Legends? Wow! How do you play? In a virtual box?
Intel is not really the best gamers have to cope with. I suspect you are using the Nouveau drivers. I did’nt read the whole thing…sorry…
Let’s go one step at a time, here.
The GPU is an Intel. Okay.
Let’s start there…
Again, super welcome here. We’re glad to have you around.
Melissa
what do you recommend me to do?
How do you play LOL? Wine, Virtual Box,Lutris?
If you aren’t already, you should be playing League of Legends via Lutris
I got it by :
Sudo snap install leagueoflegends --edge --devmode
isn’t a good idea ?
Nope. Definitely would use the Lutris version over that 100% myself. Lets you use DXVK & esync as well for better frame rates.
