I use i3wm as my primary DE.Yesterday, I did a fresh installation of i3wm, downloading iso from the Manjaro website. But after installation instead of getting Manjaro’s customized UI (i3-gaps and other panels) I got vanilla i3. I tried reinstalling the system but same thing continues. Also there are no softwares preinstalled like firefox which usually ships with Manjaro i3. Is there a way to get the Manjaro’s customization after installation? and why would this happen if I used the correct iso?
Are dot files and folders … aka they have a . at the begging of their name, hence are hidden by default in your File Manager. Either you enable to show them, or you do the copy via terminal.
both i3 & sway are unofficial, been kicked to the curb. luckily there’s community versions.
just not enough user base to justify the work i would guess.
i just did my current install from minimal+sway & there’s a lot more settings than a normal desktop version, very time consuming to setup a wm to be on par to a desktop.
