When I run top it shows PID 1 command is systemd.
When I run htop it shows PID 1 command is /sbin/init (as I had expected).
Can anyone tell me why there is a discrepancy between the two?
This is a learning issue, not a system outage issue.
Taking a course on Linux administration and just caught this difference and wondered why.
Here you can see a detailed explanation
Also, if you take a look
/sbin/init
is a symlink to /lib/systemd/systemd
plus they use different sources of information. /proc/1/cmdline
(htop = cat /proc/1/cmdline) shows how the process was invoked, while /proc/1/stat
(top = cat /proc/1/stat) shows that the process name is systemd
–Edit–
Just wanted to clarify my response and gratitude.
Good explanation.
Complicated (topic), but good (explanation).
Thanks!
