Did something stupid, deleted libxml2
Hello dear Manjaro members,
as you read in the title:
I deleted libxml2 with -Rdd
As a result pacman is broken with
sudo pacman -Syu
pacman: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
I tried installing it from source, which finally succeeded with
CFLAGS='-O2 -fno-semantic-interposition'  ./configure --prefix=/usr/
make check
sudo make install
Then I finally thought this might work. Just to be welcomed by the same problem. For which I thought I’d found a solution:
cd /usr/lib
ln -s libxml2.so.16.0.2 libxml2.so.2
and reloading shared libraries with
sudo ldconfig
but it still complained about libarchive.so.13 (as far as I remember)
The machine got rebooted (by accident) but I still got access via SSH.
Some help would be appreciated.
You may have the libxml2 package in /var/cache/pacman/pkg/
Can you install it from local with pacman -U?
Nope, unfortunately not. This was the first thing I tried.
sudo pacman -U /var/cache/pacman/pkg/libxml2-2.13.8-1-x86_64.pkg.tar.zst
There is pacman-static for such cases. Search for it in the arch wiki and use it to do full sync and reinstall what’s missing.
unfortunately
~/build/pacman-static  master ✔        38d4h  ⍉
â–¶ LANG=C makepkg -sirc
==> Making package: pacman-static 7.0.0.r6.gc685ae6-17 (So 25 Mai 2025 12:37:19 CEST)
/usr/bin/pacman: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
==> ERROR: An unknown error has occurred. Exiting...
==> Cleaning up...
[1]    61194 user-defined signal 1  LANG=C makepkg -sirc
Wait running now with
makepkg -ci
lets see
nearly
==> Verifying source file signatures with gpg...
    pacman git repo ... FAILED (unknown public key F99FFE0FEAE999BD)
    c-ares-1.34.5.tar.gz ... FAILED (unknown public key C1D15611B2E4720B)
    curl-8.13.0.tar.gz ... FAILED (unknown public key 5CC908FDB71E12C2)
    openssl-3.5.0.tar.gz ... FAILED (unknown public key 216094DFD0CB81EF)
    zlib-1.3.1.tar.gz ... FAILED (unknown public key 783FCD8E58BCAFBA)
    bzip2-1.0.8.tar.gz ... FAILED (unknown public key FC57E3CCACD99A78)
    zstd-1.5.7.tar.zst ... FAILED (unknown public key EF8FE99528B52FFD)
    libgpg-error-1.53.tar.bz2 ... FAILED (unknown public key E98E9B2D19C6C8BD)
    libassuan-3.0.0.tar.bz2 ... FAILED (unknown public key 528897B826403ADA)
    gpgme-1.24.2.tar.bz2 ... FAILED (unknown public key E98E9B2D19C6C8BD)
    libarchive-3.7.9.tar.xz ... FAILED (unknown public key 5848A18B8F14184B)
==> ERROR: One or more PGP signatures could not be verified!
can I skip those?
skipping PGP didn’t help either
~/build/pacman-static  master âś—        38d4h â—’
â–¶ LANG=C makepkg -ic --skippgpcheck
==> Making package: pacman-static 7.0.0.r6.gc685ae6-17 (So 25 Mai 2025 12:44:04 CEST)
==> Retrieving sources...
  -> Updating pacman git repo...
  -> Found pacman-revertme-makepkg-remove-libdepends-and-libprovides.patch
  -> Found nghttp2-1.65.0.tar.xz
  -> Found c-ares-1.34.5.tar.gz
  -> Found c-ares-1.34.5.tar.gz.asc
  -> Found curl-8.13.0.tar.gz
  -> Found curl-8.13.0.tar.gz.asc
  -> Found openssl-3.5.0.tar.gz
  -> Found openssl-3.5.0.tar.gz.asc
  -> Found ca-dir.patch
  -> Found openssl-3.0.7-no-atomic.patch
  -> Found zlib-1.3.1.tar.gz
  -> Found zlib-1.3.1.tar.gz.asc
  -> Updating xz git repo...
  -> Found bzip2-1.0.8.tar.gz
  -> Found bzip2-1.0.8.tar.gz.sig
  -> Found zstd-1.5.7.tar.zst
  -> Found zstd-1.5.7.tar.zst.sig
  -> Found libgpg-error-1.53.tar.bz2
  -> Found libgpg-error-1.53.tar.bz2.sig
  -> Found libassuan-3.0.0.tar.bz2
  -> Found libassuan-3.0.0.tar.bz2.sig
  -> Found gpgme-1.24.2.tar.bz2
  -> Found gpgme-1.24.2.tar.bz2.sig
  -> Found libarchive-3.7.9.tar.xz
  -> Found libarchive-3.7.9.tar.xz.asc
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with sha512sums...
    pacman ... Passed
    pacman-revertme-makepkg-remove-libdepends-and-libprovides.patch ... Passed
    nghttp2-1.65.0.tar.xz ... Passed
    c-ares-1.34.5.tar.gz ... Passed
    c-ares-1.34.5.tar.gz.asc ... Skipped
    curl-8.13.0.tar.gz ... Passed
    curl-8.13.0.tar.gz.asc ... Skipped
    openssl-3.5.0.tar.gz ... Passed
    openssl-3.5.0.tar.gz.asc ... Skipped
    ca-dir.patch ... Passed
    openssl-3.0.7-no-atomic.patch ... Passed
    zlib-1.3.1.tar.gz ... Passed
    zlib-1.3.1.tar.gz.asc ... Skipped
    xz ... Passed
    bzip2-1.0.8.tar.gz ... Passed
    bzip2-1.0.8.tar.gz.sig ... Skipped
    zstd-1.5.7.tar.zst ... Passed
    zstd-1.5.7.tar.zst.sig ... Skipped
    libgpg-error-1.53.tar.bz2 ... Passed
    libgpg-error-1.53.tar.bz2.sig ... Skipped
    libassuan-3.0.0.tar.bz2 ... Passed
    libassuan-3.0.0.tar.bz2.sig ... Skipped
    gpgme-1.24.2.tar.bz2 ... Passed
    gpgme-1.24.2.tar.bz2.sig ... Skipped
    libarchive-3.7.9.tar.xz ... Passed
    libarchive-3.7.9.tar.xz.asc ... Skipped
==> Extracting sources...
  -> Creating working copy of pacman git repo...
Cloning into 'pacman'...
done.
Switched to a new branch 'makepkg'
  -> Extracting nghttp2-1.65.0.tar.xz with bsdtar
bsdtar: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
==> ERROR: Failed to extract nghttp2-1.65.0.tar.xz
    Aborting...
Have you another Manjaro machine? If ssh works, scp should work too. Can you copy the lost file from the working one to the other (maybe it’s a silly idea, but it’s the first thing that comes to my mind)?
I compiled libxml2 from source and it is in /usr/lib/, but I think the right symlinks are not set. I found a solution on the Garuda forums, but that didn’t work either.
What if instead you open a page for e.g. pacman-static (in pacman archwiki) and actually read it? Did you think of that? Or are you just doing things randomly, because it certainly looks like it.
If it can help you, these are the symlinks in my computer:
lrwxrwxrwx 1 root root      13 may 13 16:31 libxml2.so -> libxml2.so.16
lrwxrwxrwx 1 root root      17 may 13 16:31 libxml2.so.16 -> libxml2.so.16.0.3
-rwxr-xr-x 1 root root 1297360 may 13 16:31 libxml2.so.16.0.3
Looking at timeshift backups, libxml2.so.2 was installed until the May 19 backup. Now it’s not in my system (and pacman works fine).
I followed these instructions:
Pacman Static
which resulted in
this
It still needs bsdtar to extract nghttp2, which in turn needs libxml2 again. Thus this is not a working solution either, unfortunately.
At first I tried pacman -U, did not work
Tried compiling from source, which worked partially, but the symlinks don’t seem to work
Tried the suggested approach of pacman-static, which is also not possible due to libxml2 missing.
No, you didn’t read it.
Well, I read
The pinned comment and the PKGBUILD provides a way to directly download the binary, which can be used to reinstall pacman or to upgrade the entire system in case of partial upgrades.
I added the repo to pacman.conf
[pacman-static]
SigLevel = Required
Server = https://pkgbuild.com/~morganamilo/$repo/$arch
I downloaded the binary
I read the PKGBUILD, but couldn’t find anything really useful there. At least not obvious to me.
Copied the pacman-static binary to /usr/bin.
When I now run pacman-static as normal user it says that I don’t have enough rights. When I try sudo, it says the the command is not found.
EDIT: Reddit to the rescue. Couldn’t figure it out with the PKDBUILD. Though someone on Reddit had a similar issue
Download pacman-static binary from a trusted user here.
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x ./pacman-static
sudo ./pacman-static -Syu
Use this with the correct repo mentioned on the AUR site! (Index of /~morganamilo/pacman-static/x86_64/bin/)
Now I could update the system and everything is working again!
Hi @mielouk,
See:
I previously helped someone else with a similar, if not the same issue.
I meant find the binary of the static from somewhere, like here for example
https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/
Indeed I didn’t read it correctly. Sorry for the inconvenience!
Thanks to @abracadabra @Arrababiski and @Teo
Everything is fine now! Thanks for your patience and your help!
Have a very nice day, knowing you helped me immensely!
libxml2 is required by a number of other packages
see pacman -Qi libxml2 | grep Required for all the packages that are likely broken
pacman -R would have warned about possible dependency issues
pacman -Rd skips dependency version checks
pacman -Rdd skips all checks
IMO it would be simpler to use manjaro-chroot on a Live ISO to reinstall libxml2 repository
sudo pacman -S libxml2
but OP might need to use -dd option again to skip checks
It would be if pacman was working. Unfortunately it was broken because libxml2 was missing.
