So, few days ago I did the latest update to my system. All went well, but since then I am experiencing hard resets out of the blue, without doing anything but browsing (Firefox), or chatting at Discord. Of course it could be total coincidence that started after the update, and this might be some hardware issue, although I haven’t make any changes to my system for months, not even BIOS settings and I run on defaults (no O/C).
I tried looking in dmesg and journal, but I don’t see any errors or warning close to the reset time.
I also tried to push it to the limits by running some stress tests (memory & CPU), while checking temps, but nothing wrong with that either. Last reset was few minutes ago (13:01 local time), while I was scrolling my timeline on Fb.
Can you please help identify the issue?
journalctl --boot=-1 --priority=3 --catalog --no-pager
Aug 16 07:30:52 wizzy-manjaro-kde6 kernel: i2c i2c-1: Failed to register i2c client MSFT8000:00 at 0x40 (-16)
Aug 16 07:30:52 wizzy-manjaro-kde6 kernel: hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 16 07:30:52 wizzy-manjaro-kde6 kernel: usb 9-1.2.1.1.1: device descriptor read/64, error -110
Aug 16 07:30:53 wizzy-manjaro-kde6 systemd-udevd[663]: /etc/udev/rules.d/40-libsane.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Aug 16 07:30:53 wizzy-manjaro-kde6 systemd-udevd[663]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Unknown group 'uaccess', ignoring.
Aug 16 07:30:53 wizzy-manjaro-kde6 systemd-udevd[663]: /etc/udev/rules.d/S99-2000S1.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 11:3: cannot get min/max values for control 2 (id 11)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 13:3: cannot get min/max values for control 2 (id 13)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 12:3: cannot get min/max values for control 2 (id 12)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 16:3: cannot get min/max values for control 2 (id 16)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 1:3: cannot get min/max values for control 2 (id 1)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 2:3: cannot get min/max values for control 2 (id 2)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 23:3: cannot get min/max values for control 2 (id 23)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 25:3: cannot get min/max values for control 2 (id 25)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 8:3: cannot get min/max values for control 2 (id 8)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: usb 3-5.4: 27:3: cannot get min/max values for control 2 (id 27)
Aug 16 07:30:54 wizzy-manjaro-kde6 kernel: iwlwifi 0000:0e:00.0: WRT: Invalid buffer destination
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[674]: controlC0: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-5/3-5.4/3-5.4:1.3/sound/card0/controlC0/../uevent}="change", ignoring: No such file or directory
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[678]: hiddev0: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[708]: hiddev1: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[755]: hiddev5: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[672]: hiddev4: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[683]: hiddev3: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:54 wizzy-manjaro-kde6 (udev-worker)[696]: hiddev2: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 07:30:55 wizzy-manjaro-kde6 bluetoothd[989]: Failed to set mode: Failed (0x03)
Aug 16 07:32:08 wizzy-manjaro-kde6 bluetoothd[989]: Failed to set mode: Failed (0x03)
Aug 16 07:32:08 wizzy-manjaro-kde6 org_kde_powerdevil[1713]: busno=2, sleep-multiplier = 1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Aug 16 07:32:09 wizzy-manjaro-kde6 bluetoothd[989]: Failed to set mode: Failed (0x03)
Aug 16 10:52:37 wizzy-manjaro-kde6 (udev-worker)[28452]: hiddev3: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 10:52:37 wizzy-manjaro-kde6 (udev-worker)[28451]: hiddev2: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
Aug 16 10:52:37 wizzy-manjaro-kde6 (udev-worker)[28450]: hiddev1: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:61 Only network interfaces can be renamed, ignoring NAME="usb/%k".
dmesg
[ 0.000000] Linux version 6.6.44-1-MANJARO (builduser@fv-az1537-985) (gcc (GCC) 14.1.1 20240720, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Sat Aug 3 10:09:33 UTC 2024
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=7f121955-19f8-4849-a149-173dc55e9395 rw resume=UUID=55eb965d-0e06-44e5-8d57-876cb155362d udev.log_priority=3 amd_iommu=force_enable iommu=pt hugepages=16384 systemd.unified_cgroup_hierarchy=1 kvm.ignore_msrs=1 pcie_acs_override=downstream,multifunction vfio_iommu_type1.allow_unsafe_interrupts=1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009afefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009aff000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a211fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a212000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b020fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b021000-0x000000007e4cbfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007e4cc000-0x00000000844cbfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000844cc000-0x000000008467efff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000008467f000-0x000000008667efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008667f000-0x000000008e7fefff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e7ff000-0x000000008fff8fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008fff9000-0x000000008fffdfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008fffe000-0x000000008fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000090000000-0x0000000097ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009d7f3000-0x000000009fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f7000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000103de7ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000103eec0000-0x00000010801fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] e820: update [mem 0x7120f018-0x71233a57] usable ==> usable
[ 0.000000] e820: update [mem 0x79a83018-0x79a93857] usable ==> usable
[ 0.000000] e820: update [mem 0x711fe018-0x7120e857] usable ==> usable
[ 0.000000] e820: update [mem 0x711ee018-0x711fd057] usable ==> usable
[ 0.000000] e820: update [mem 0x79a78018-0x79a82e57] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000009afefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000009aff000-0x0000000009ffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a211fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a212000-0x000000000affffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000b000000-0x000000000b020fff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000b021000-0x00000000711ee017] usable
[ 0.000000] reserve setup_data: [mem 0x00000000711ee018-0x00000000711fd057] usable
[ 0.000000] reserve setup_data: [mem 0x00000000711fd058-0x00000000711fe017] usable
[ 0.000000] reserve setup_data: [mem 0x00000000711fe018-0x000000007120e857] usable
[ 0.000000] reserve setup_data: [mem 0x000000007120e858-0x000000007120f017] usable
[ 0.000000] reserve setup_data: [mem 0x000000007120f018-0x0000000071233a57] usable
[ 0.000000] reserve setup_data: [mem 0x0000000071233a58-0x0000000079a78017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079a78018-0x0000000079a82e57] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079a82e58-0x0000000079a83017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079a83018-0x0000000079a93857] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079a93858-0x000000007e4cbfff] usable
[ 0.000000] reserve setup_data: [mem 0x000000007e4cc000-0x00000000844cbfff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000844cc000-0x000000008467efff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x000000008467f000-0x000000008667efff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000008667f000-0x000000008e7fefff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000008e7ff000-0x000000008fff8fff] usable
[ 0.000000] reserve setup_data: [mem 0x000000008fff9000-0x000000008fffdfff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000008fffe000-0x000000008fffffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000090000000-0x0000000097ffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000009d7f3000-0x000000009fffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000f7000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000103de7ffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000103eec0000-0x00000010801fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] efi: EFI v2.9 by American Megatrends
[ 0.000000] efi: ACPI=0x86667000 ACPI 2.0=0x86667014 SMBIOS=0x8dcc9000 SMBIOS 3.0=0x8dcc8000 MEMATTR=0x7ab28118 ESRT=0x7c504f98 INITRD=0x79a94698 RNG=0x845bc018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem227: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[ 0.000000] efi: Remove mem228: MMIO range=[0xf7000000-0xfedfffff] (126MB) from e820 map
[ 0.000000] e820: remove [mem 0xf7000000-0xfedfffff] reserved
[ 0.000000] efi: Not removing mem229: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem230: MMIO range=[0xfee01000-0xffffffff] (17MB) from e820 map
[ 0.000000] e820: remove [mem 0xfee01000-0xffffffff] reserved
[ 0.000000] efi: Remove mem232: MMIO range=[0x1060000000-0x10801fffff] (514MB) from e820 map
[ 0.000000] e820: remove [mem 0x1060000000-0x10801fffff] reserved
[ 0.000000] SMBIOS 3.7.0 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. X670E AORUS MASTER/X670E AORUS MASTER, BIOS F30 05/22/2024
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 4200.032 MHz processor
[ 0.000109] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000110] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000115] last_pfn = 0x103de80 max_arch_pfn = 0x400000000
[ 0.000120] MTRR map: 5 entries (3 fixed + 2 variable; max 20), built from 9 variable MTRRs
[ 0.000121] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000308] e820: update [mem 0xa0000000-0xffffffff] usable ==> reserved
[ 0.000314] last_pfn = 0x90000 max_arch_pfn = 0x400000000
[ 0.002777] esrt: Reserving ESRT space from 0x000000007c504f98 to 0x000000007c504fd0.
[ 0.002782] e820: update [mem 0x7c504000-0x7c504fff] usable ==> reserved
[ 0.002801] Using GB pages for direct mapping
[ 0.003355] Secure boot disabled
[ 0.003355] RAMDISK: [mem 0x72334000-0x747a3fff]
[ 0.003374] ACPI: Early table checksum verification disabled
[ 0.003376] ACPI: RSDP 0x0000000086667014 000024 (v02 ALASKA)
[ 0.003379] ACPI: XSDT 0x0000000086666728 000104 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003382] ACPI: FACP 0x0000000084669000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003385] ACPI: DSDT 0x00000000845EC000 072DFE (v101 ALASKA A M I 01072009 INTL 20230628)
[ 0.003387] ACPI: FACS 0x0000000086663000 000040
[ 0.003388] ACPI: HWIN 0x000000008467E000 00006C (v00 GBT AMD 00050000 AMI 01000013)
[ 0.003389] ACPI: SSDT 0x0000000084673000 00A926 (v02 GBT GSWApp 00000001 INTL 20230628)
[ 0.003390] ACPI: SSDT 0x000000008466B000 007F64 (v02 AMD Splinter 00000002 MSFT 04000000)
[ 0.003391] ACPI: SSDT 0x000000008466A000 0003F1 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.003392] ACPI: FIDT 0x0000000084663000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003393] ACPI: MCFG 0x0000000084662000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.003394] ACPI: HPET 0x0000000084661000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003395] ACPI: WDRT 0x0000000084660000 000047 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003397] ACPI: FPDT 0x000000008465F000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003398] ACPI: VFCT 0x00000000845E1000 00AE84 (v01 ALASKA A M I 00000001 AMD 33504F47)
[ 0.003399] ACPI: BGRT 0x0000000084668000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003400] ACPI: SSDT 0x00000000845D7000 009BAE (v02 AMD AMD CPU 00000001 AMD 00000001)
[ 0.003401] ACPI: SSDT 0x0000000084667000 0006D4 (v02 AMD CPMWLRC 00000001 INTL 20230628)
[ 0.003402] ACPI: SSDT 0x0000000084665000 0015D0 (v02 AMD CPMDFIG2 00000001 INTL 20230628)
[ 0.003403] ACPI: SSDT 0x00000000845D4000 002AA6 (v02 AMD CDFAAIG2 00000001 INTL 20230628)
[ 0.003404] ACPI: SSDT 0x0000000084664000 00078F (v02 AMD CPMDFDG1 00000001 INTL 20230628)
[ 0.003405] ACPI: SSDT 0x00000000845CA000 009783 (v02 AMD CPMCMN 00000001 INTL 20230628)
[ 0.003407] ACPI: SSDT 0x00000000845C7000 0024AB (v02 AMD AOD 00000001 INTL 20230628)
[ 0.003408] ACPI: WSMT 0x00000000845C6000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003409] ACPI: APIC 0x00000000845C5000 00015E (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003410] ACPI: IVRS 0x00000000845C4000 0000C8 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003411] ACPI: SSDT 0x00000000845C3000 000500 (v02 AMD MEMTOOL0 00000002 INTL 20230628)
[ 0.003412] ACPI: SSDT 0x00000000845C2000 0009D0 (v02 AMD CPMMSOSC 00000001 INTL 20230628)
[ 0.003413] ACPI: SSDT 0x00000000845C1000 00047C (v02 AMD AMDWOV 00000001 INTL 20230628)
[ 0.003414] ACPI: SSDT 0x00000000845BF000 001046 (v02 AMD CPMACPV4 00000001 INTL 20230628)
[ 0.003415] ACPI: SSDT 0x00000000845BE000 00044E (v02 AMD AmdTable 00000001 INTL 20230628)
[ 0.003416] ACPI: SSDT 0x00000000845BD000 000771 (v02 AMD AmdTable 00000001 INTL 20230628)
[ 0.003417] ACPI: Reserving FACP table memory at [mem 0x84669000-0x84669113]
[ 0.003417] ACPI: Reserving DSDT table memory at [mem 0x845ec000-0x8465edfd]
[ 0.003418] ACPI: Reserving FACS table memory at [mem 0x86663000-0x8666303f]
[ 0.003418] ACPI: Reserving HWIN table memory at [mem 0x8467e000-0x8467e06b]
[ 0.003418] ACPI: Reserving SSDT table memory at [mem 0x84673000-0x8467d925]
[ 0.003419] ACPI: Reserving SSDT table memory at [mem 0x8466b000-0x84672f63]
[ 0.003419] ACPI: Reserving SSDT table memory at [mem 0x8466a000-0x8466a3f0]
[ 0.003419] ACPI: Reserving FIDT table memory at [mem 0x84663000-0x8466309b]
[ 0.003420] ACPI: Reserving MCFG table memory at [mem 0x84662000-0x8466203b]
[ 0.003420] ACPI: Reserving HPET table memory at [mem 0x84661000-0x84661037]
[ 0.003420] ACPI: Reserving WDRT table memory at [mem 0x84660000-0x84660046]
[ 0.003420] ACPI: Reserving FPDT table memory at [mem 0x8465f000-0x8465f043]
[ 0.003421] ACPI: Reserving VFCT table memory at [mem 0x845e1000-0x845ebe83]
[ 0.003421] ACPI: Reserving BGRT table memory at [mem 0x84668000-0x84668037]
[ 0.003421] ACPI: Reserving SSDT table memory at [mem 0x845d7000-0x845e0bad]
[ 0.003422] ACPI: Reserving SSDT table memory at [mem 0x84667000-0x846676d3]
[ 0.003422] ACPI: Reserving SSDT table memory at [mem 0x84665000-0x846665cf]
[ 0.003422] ACPI: Reserving SSDT table memory at [mem 0x845d4000-0x845d6aa5]
[ 0.003422] ACPI: Reserving SSDT table memory at [mem 0x84664000-0x8466478e]
[ 0.003423] ACPI: Reserving SSDT table memory at [mem 0x845ca000-0x845d3782]
[ 0.003423] ACPI: Reserving SSDT table memory at [mem 0x845c7000-0x845c94aa]
[ 0.003423] ACPI: Reserving WSMT table memory at [mem 0x845c6000-0x845c6027]
[ 0.003424] ACPI: Reserving APIC table memory at [mem 0x845c5000-0x845c515d]
[ 0.003424] ACPI: Reserving IVRS table memory at [mem 0x845c4000-0x845c40c7]
[ 0.003424] ACPI: Reserving SSDT table memory at [mem 0x845c3000-0x845c34ff]
[ 0.003424] ACPI: Reserving SSDT table memory at [mem 0x845c2000-0x845c29cf]
[ 0.003425] ACPI: Reserving SSDT table memory at [mem 0x845c1000-0x845c147b]
[ 0.003425] ACPI: Reserving SSDT table memory at [mem 0x845bf000-0x845c0045]
[ 0.003425] ACPI: Reserving SSDT table memory at [mem 0x845be000-0x845be44d]
[ 0.003426] ACPI: Reserving SSDT table memory at [mem 0x845bd000-0x845bd770]
[ 0.003467] No NUMA configuration found
[ 0.003467] Faking a node at [mem 0x0000000000000000-0x000000103de7ffff]
[ 0.003468] NODE_DATA(0) allocated [mem 0x103de7b000-0x103de7ffff]
[ 0.003502] Zone ranges:
[ 0.003502] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003503] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003503] Normal [mem 0x0000000100000000-0x000000103de7ffff]
[ 0.003504] Device empty
[ 0.003505] Movable zone start for each node
[ 0.003505] Early memory node ranges
[ 0.003505] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003506] node 0: [mem 0x0000000000100000-0x0000000009afefff]
[ 0.003506] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.003507] node 0: [mem 0x000000000a212000-0x000000000affffff]
[ 0.003507] node 0: [mem 0x000000000b021000-0x000000007e4cbfff]
[ 0.003507] node 0: [mem 0x000000008e7ff000-0x000000008fff8fff]
[ 0.003508] node 0: [mem 0x000000008fffe000-0x000000008fffffff]
[ 0.003508] node 0: [mem 0x0000000100000000-0x000000103de7ffff]
[ 0.003510] Initmem setup node 0 [mem 0x0000000000001000-0x000000103de7ffff]
[ 0.003513] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003523] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.003598] On node 0, zone DMA32: 1281 pages in unavailable ranges
[ 0.003607] On node 0, zone DMA32: 18 pages in unavailable ranges
[ 0.004537] On node 0, zone DMA32: 33 pages in unavailable ranges
[ 0.004638] On node 0, zone DMA32: 33587 pages in unavailable ranges
[ 0.004638] On node 0, zone DMA32: 5 pages in unavailable ranges
[ 0.043600] On node 0, zone Normal: 8576 pages in unavailable ranges
[ 0.044289] ACPI: PM-Timer IO Port: 0x808
[ 0.044295] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.044305] IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
[ 0.044309] IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
[ 0.044310] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.044311] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.044313] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.044313] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.044321] e820: update [mem 0x7a6cd000-0x7a723fff] usable ==> reserved
[ 0.044330] smpboot: Allowing 32 CPUs, 0 hotplug CPUs
[ 0.044343] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.044344] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.044345] PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
[ 0.044346] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a211fff]
[ 0.044346] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
[ 0.044347] PM: hibernation: Registered nosave memory: [mem 0x711ee000-0x711eefff]
[ 0.044348] PM: hibernation: Registered nosave memory: [mem 0x711fd000-0x711fdfff]
[ 0.044348] PM: hibernation: Registered nosave memory: [mem 0x711fe000-0x711fefff]
[ 0.044349] PM: hibernation: Registered nosave memory: [mem 0x7120e000-0x7120efff]
[ 0.044349] PM: hibernation: Registered nosave memory: [mem 0x7120f000-0x7120ffff]
[ 0.044350] PM: hibernation: Registered nosave memory: [mem 0x71233000-0x71233fff]
[ 0.044350] PM: hibernation: Registered nosave memory: [mem 0x79a78000-0x79a78fff]
[ 0.044351] PM: hibernation: Registered nosave memory: [mem 0x79a82000-0x79a82fff]
[ 0.044351] PM: hibernation: Registered nosave memory: [mem 0x79a83000-0x79a83fff]
[ 0.044352] PM: hibernation: Registered nosave memory: [mem 0x79a93000-0x79a93fff]
[ 0.044353] PM: hibernation: Registered nosave memory: [mem 0x7a6cd000-0x7a723fff]
[ 0.044353] PM: hibernation: Registered nosave memory: [mem 0x7c504000-0x7c504fff]
[ 0.044354] PM: hibernation: Registered nosave memory: [mem 0x7e4cc000-0x844cbfff]
[ 0.044354] PM: hibernation: Registered nosave memory: [mem 0x844cc000-0x8467efff]
[ 0.044354] PM: hibernation: Registered nosave memory: [mem 0x8467f000-0x8667efff]
[ 0.044355] PM: hibernation: Registered nosave memory: [mem 0x8667f000-0x8e7fefff]
[ 0.044355] PM: hibernation: Registered nosave memory: [mem 0x8fff9000-0x8fffdfff]
[ 0.044356] PM: hibernation: Registered nosave memory: [mem 0x90000000-0x97ffffff]
[ 0.044356] PM: hibernation: Registered nosave memory: [mem 0x98000000-0x9d7f2fff]
[ 0.044357] PM: hibernation: Registered nosave memory: [mem 0x9d7f3000-0x9fffffff]
[ 0.044357] PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xfedfffff]
[ 0.044357] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.044357] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[ 0.044358] [mem 0xa0000000-0xfedfffff] available for PCI devices
[ 0.044359] Booting paravirtualized kernel on bare hardware
[ 0.044361] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.047031] setup_percpu: NR_CPUS:320 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[ 0.047565] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.047569] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[ 0.047570] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.047573] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.047587] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=7f121955-19f8-4849-a149-173dc55e9395 rw resume=UUID=55eb965d-0e06-44e5-8d57-876cb155362d udev.log_priority=3 amd_iommu=force_enable iommu=pt hugepages=16384 systemd.unified_cgroup_hierarchy=1 kvm.ignore_msrs=1 pcie_acs_override=downstream,multifunction vfio_iommu_type1.allow_unsafe_interrupts=1
[ 0.047663] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 pcie_acs_override=downstream,multifunction", will be passed to user space.
[ 0.047851] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.047852] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.047852] printk: log_buf_len min size: 131072 bytes
[ 0.047919] printk: log_buf_len: 262144 bytes
[ 0.047919] printk: early log buf free: 112392(85%)
[ 0.050529] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.051736] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.051793] Fallback order for Node 0: 0
[ 0.051795] Built 1 zonelists, mobility grouping on. Total pages: 16246203
[ 0.051796] Policy zone: Normal
[ 0.051886] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.051890] software IO TLB: area num 32.
[ 0.112631] Memory: 64644092K/66016972K available (18432K kernel code, 2155K rwdata, 13100K rodata, 3444K init, 3620K bss, 1372624K reserved, 0K cma-reserved)
[ 0.112753] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.112769] ftrace: allocating 49100 entries in 192 pages
[ 0.119306] ftrace: allocated 192 pages with 2 groups
[ 0.119355] Dynamic Preempt: full
[ 0.119404] rcu: Preemptible hierarchical RCU implementation.
[ 0.119404] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.119405] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.119405] Trampoline variant of Tasks RCU enabled.
[ 0.119406] Rude variant of Tasks RCU enabled.
[ 0.119406] Tracing variant of Tasks RCU enabled.
[ 0.119406] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.119406] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.120579] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.120747] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.120884] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.120909] Console: colour dummy device 80x25
[ 0.120911] printk: console [tty0] enabled
[ 0.120940] ACPI: Core revision 20230628
[ 0.121152] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.121163] APIC: Switch to symmetric I/O mode setup
[ 0.121626] AMD-Vi: Using global IVHD EFR:0x246577efa2254afa, EFR2:0x0
[ 0.121847] APIC: Switched APIC routing to: physical flat
[ 0.122401] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.137833] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3c8a7fbfbbf, max_idle_ns: 440795414358 ns
[ 0.137836] Calibrating delay loop (skipped), value calculated using timer frequency.. 8403.06 BogoMIPS (lpj=14000106)
[ 0.137846] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.137883] LVT offset 1 assigned for vector 0xf9
[ 0.138006] LVT offset 2 assigned for vector 0xf4
[ 0.138042] process: using mwait in idle threads
[ 0.138043] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.138043] Last level dTLB entries: 4KB 3072, 2MB 3072, 4MB 1536, 1GB 0
[ 0.138045] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.138047] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.138048] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.138049] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.138049] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.138050] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.138051] Speculative Return Stack Overflow: Mitigation: Safe RET
[ 0.138054] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.138054] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.138055] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.138055] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.138056] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.138056] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.138056] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.138057] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[ 0.138057] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.138058] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.138059] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.138059] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.138060] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.138060] x86/fpu: xstate_offset[11]: 2440, xstate_sizes[11]: 16
[ 0.138061] x86/fpu: Enabled xstate features 0xae7, context size is 2456 bytes, using 'compacted' format.
[ 0.152187] Freeing SMP alternatives memory: 40K
[ 0.152188] pid_max: default: 32768 minimum: 301
[ 0.154526] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[ 0.154546] landlock: Up and running.
[ 0.154547] Yama: becoming mindful.
[ 0.154550] LSM support for eBPF active
[ 0.154607] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.154653] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.261664] smpboot: CPU0: AMD Ryzen 9 7950X3D 16-Core Processor (family: 0x19, model: 0x61, stepping: 0x2)
[ 0.261795] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.261809] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.261821] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.261836] Performance Events: Fam17h+ 16-deep LBR, core perfctr, AMD PMU driver.
[ 0.261852] ... version: 2
[ 0.261853] ... bit width: 48
[ 0.261854] ... generic registers: 6
[ 0.261854] ... value mask: 0000ffffffffffff
[ 0.261855] ... max period: 00007fffffffffff
[ 0.261855] ... fixed-purpose events: 0
[ 0.261856] ... event mask: 000000000000003f
[ 0.261916] signal: max sigframe size: 3376
[ 0.261930] rcu: Hierarchical SRCU implementation.
[ 0.261931] rcu: Max phase no-delay instances is 1000.
[ 0.263577] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.263766] smp: Bringing up secondary CPUs ...
[ 0.263850] smpboot: x86: Booting SMP configuration:
[ 0.263851] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.286502] TSC synchronization [CPU#0 -> CPU#8]:
[ 0.286504] Measured 2058 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.286508] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[ 0.287862] #16 #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
[ 0.289602] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.289602] smp: Brought up 1 node, 32 CPUs
[ 0.289602] smpboot: Max logical packages: 1
[ 0.289602] smpboot: Total of 32 processors activated (268909.12 BogoMIPS)
[ 0.295134] devtmpfs: initialized
[ 0.295134] x86/mm: Memory block size: 2048MB
[ 0.295134] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a211fff] (73728 bytes)
[ 0.295134] ACPI: PM: Registering ACPI NVS region [mem 0x8467f000-0x8667efff] (33554432 bytes)
[ 0.295134] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.295134] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.295134] pinctrl core: initialized pinctrl subsystem
[ 0.295134] PM: RTC time: 11:57:42, date: 2024-08-16
[ 0.295134] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.295134] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.295193] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.295292] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.295304] audit: initializing netlink subsys (disabled)
[ 0.295308] audit: type=2000 audit(1723809462.173:1): state=initialized audit_enabled=0 res=1
[ 0.295308] thermal_sys: Registered thermal governor 'fair_share'
[ 0.295308] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.295308] thermal_sys: Registered thermal governor 'step_wise'
[ 0.295308] thermal_sys: Registered thermal governor 'user_space'
[ 0.295308] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.295308] cpuidle: using governor ladder
[ 0.295308] cpuidle: using governor menu
[ 0.295308] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.295308] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.295308] PCI: Using configuration type 1 for base access
[ 0.295493] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 1.590859] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.590861] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 1.590862] HugeTLB: registered 2.00 MiB page size, pre-allocated 16384 pages
[ 1.590863] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 1.591285] ACPI: Added _OSI(Module Device)
[ 1.591286] ACPI: Added _OSI(Processor Device)
[ 1.591287] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 1.591288] ACPI: Added _OSI(Processor Aggregator Device)
[ 1.616990] ACPI: 17 ACPI AML tables successfully acquired and loaded
[ 1.675051] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 1.675053] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 1.675383] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[ 1.676147] ACPI: Interpreter enabled
[ 1.676161] ACPI: PM: (supports S0 S3 S4 S5)
[ 1.676162] ACPI: Using IOAPIC for interrupt routing
[ 1.676476] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.676477] PCI: Ignoring E820 reservations for host bridge windows
[ 1.676920] ACPI: Enabled 11 GPEs in block 00 to 1F
[ 1.678846] ACPI: \_SB_.PCI0.GP17.XHC0.P0U0: New power resource
[ 1.680502] ACPI: \_SB_.PCI0.GP17.XHC1.P0U1: New power resource
[ 1.682853] ACPI: \_SB_.PCI0.GP19.XHC2.P0U2: New power resource
[ 1.683514] ACPI: \_SB_.PCI0.GPP0.M237: New power resource
[ 1.683795] ACPI: \_SB_.PCI0.GPP1.P0NV: New power resource
[ 1.684645] ACPI: \_SB_.PCI0.GPP7.PWRS: New power resource
[ 1.684965] ACPI: \_SB_.PCI0.GPP7.UP00.PWRS: New power resource
[ 1.685268] ACPI: \_SB_.PCI0.GPP7.UP00.DP00.PWRS: New power resource
[ 1.685714] ACPI: \_SB_.PCI0.GPP7.UP00.DP00.NV00.PWRS: New power resource
[ 1.685979] ACPI: \_SB_.PCI0.GPP7.UP00.DP08.PWRS: New power resource
[ 1.686194] ACPI: \_SB_.PCI0.GPP7.UP00.DP08.EP00.PWRS: New power resource
[ 1.686435] ACPI: \_SB_.PCI0.GPP7.UP00.DP10.PWRS: New power resource
[ 1.686651] ACPI: \_SB_.PCI0.GPP7.UP00.DP10.WN00.PWRS: New power resource
[ 1.686893] ACPI: \_SB_.PCI0.GPP7.UP00.DP18.PWRS: New power resource
[ 1.687106] ACPI: \_SB_.PCI0.GPP7.UP00.DP18.LN00.PWRS: New power resource
[ 1.687346] ACPI: \_SB_.PCI0.GPP7.UP00.DP20.PWRS: New power resource
[ 1.687787] ACPI: \_SB_.PCI0.GPP7.UP00.DP20.NV00.PWRS: New power resource
[ 1.688054] ACPI: \_SB_.PCI0.GPP7.UP00.DP28.PWRS: New power resource
[ 1.688492] ACPI: \_SB_.PCI0.GPP7.UP00.DP28.EP00.PWRS: New power resource
[ 1.688755] ACPI: \_SB_.PCI0.GPP7.UP00.DP30.PWRS: New power resource
[ 1.689193] ACPI: \_SB_.PCI0.GPP7.UP00.DP30.EP00.PWRS: New power resource
[ 1.689458] ACPI: \_SB_.PCI0.GPP7.UP00.DP38.PWRS: New power resource
[ 1.689671] ACPI: \_SB_.PCI0.GPP7.UP00.DP38.EP00.PWRS: New power resource
[ 1.689912] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.PWRS: New power resource
[ 1.690215] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.PWRS: New power resource
[ 1.690518] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP00.PWRS: New power resource
[ 1.690962] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP00.NV00.PWRS: New power resource
[ 1.691236] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP08.PWRS: New power resource
[ 1.691457] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP08.EP00.PWRS: New power resource
[ 1.691705] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP10.PWRS: New power resource
[ 1.691921] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP10.WN00.PWRS: New power resource
[ 1.692164] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP18.PWRS: New power resource
[ 1.692379] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP18.LN00.PWRS: New power resource
[ 1.692620] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP20.PWRS: New power resource
[ 1.692927] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP20.NV00.PWRS: New power resource
[ 1.693233] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP28.PWRS: New power resource
[ 1.693453] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP28.EP00.PWRS: New power resource
[ 1.693695] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP30.PWRS: New power resource
[ 1.693996] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP30.EP00.PWRS: New power resource
[ 1.694303] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP38.PWRS: New power resource
[ 1.694616] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP38.EP00.PWRS: New power resource
[ 1.694922] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP40.PWRS: New power resource
[ 1.695224] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP40.EP00.PWRS: New power resource
[ 1.695530] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP48.PWRS: New power resource
[ 1.695744] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP48.EP00.PWRS: New power resource
[ 1.695992] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP50.PWRS: New power resource
[ 1.696207] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP50.EP00.PWRS: New power resource
[ 1.696455] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP58.PWRS: New power resource
[ 1.696673] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP58.EP00.PWRS: New power resource
[ 1.696921] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP60.PWRS: New power resource
[ 1.697227] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP60.XH00.PWRS: New power resource
[ 1.697533] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP68.PWRS: New power resource
[ 1.697840] ACPI: \_SB_.PCI0.GPP7.UP00.DP40.UP00.DP68.SA00.PWRS: New power resource
[ 1.698257] ACPI: \_SB_.PCI0.GPP7.UP00.DP48.PWRS: New power resource
[ 1.698476] ACPI: \_SB_.PCI0.GPP7.UP00.DP48.EP00.PWRS: New power resource
[ 1.698719] ACPI: \_SB_.PCI0.GPP7.UP00.DP50.PWRS: New power resource
[ 1.698934] ACPI: \_SB_.PCI0.GPP7.UP00.DP50.EP00.PWRS: New power resource
[ 1.699180] ACPI: \_SB_.PCI0.GPP7.UP00.DP58.PWRS: New power resource
[ 1.699394] ACPI: \_SB_.PCI0.GPP7.UP00.DP58.EP00.PWRS: New power resource
[ 1.699633] ACPI: \_SB_.PCI0.GPP7.UP00.DP60.PWRS: New power resource
[ 1.699934] ACPI: \_SB_.PCI0.GPP7.UP00.DP60.XH00.PWRS: New power resource
[ 1.704617] ACPI: \_SB_.PCI0.GPP7.UP00.DP68.PWRS: New power resource
[ 1.704924] ACPI: \_SB_.PCI0.GPP7.UP00.DP68.SA00.PWRS: New power resource
[ 1.705074] ACPI: \_SB_.PCI0.GPP8.PWR1: New power resource
[ 1.708983] ACPI: \_SB_.PRWL: New power resource
[ 1.709004] ACPI: \_SB_.PRWB: New power resource
[ 1.709798] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.709802] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 1.709948] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 1.710465] PCI host bridge to bus 0000:00
[ 1.710466] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 1.710467] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 1.710468] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 1.710469] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.710470] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 1.710471] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xf6ffffff window]
[ 1.710472] pci_bus 0000:00: root bus resource [mem 0x1060000000-0xfcffffffff window]
[ 1.710473] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.710486] pci 0000:00:00.0: [1022:14d8] type 00 class 0x060000
[ 1.710565] pci 0000:00:00.2: [1022:14d9] type 00 class 0x080600
[ 1.710635] pci 0000:00:01.0: [1022:14da] type 00 class 0x060000
[ 1.710692] pci 0000:00:01.1: [1022:14db] type 01 class 0x060400
[ 1.710757] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 1.711229] pci 0000:00:01.2: [1022:14db] type 01 class 0x060400
[ 1.711293] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 1.711402] pci 0000:00:02.0: [1022:14da] type 00 class 0x060000
[ 1.711461] pci 0000:00:02.1: [1022:14db] type 01 class 0x060400
[ 1.711481] pci 0000:00:02.1: enabling Extended Tags
[ 1.711525] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 1.711715] pci 0000:00:02.2: [1022:14db] type 01 class 0x060400
[ 1.711735] pci 0000:00:02.2: enabling Extended Tags
[ 1.711779] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 1.711886] pci 0000:00:03.0: [1022:14da] type 00 class 0x060000
[ 1.711948] pci 0000:00:04.0: [1022:14da] type 00 class 0x060000
[ 1.712014] pci 0000:00:08.0: [1022:14da] type 00 class 0x060000
[ 1.712072] pci 0000:00:08.1: [1022:14dd] type 01 class 0x060400
[ 1.712088] pci 0000:00:08.1: enabling Extended Tags
[ 1.712112] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 1.712200] pci 0000:00:08.3: [1022:14dd] type 01 class 0x060400
[ 1.712215] pci 0000:00:08.3: enabling Extended Tags
[ 1.712239] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 1.712326] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 1.712424] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 1.712526] pci 0000:00:18.0: [1022:14e0] type 00 class 0x060000
[ 1.712553] pci 0000:00:18.1: [1022:14e1] type 00 class 0x060000
[ 1.712581] pci 0000:00:18.2: [1022:14e2] type 00 class 0x060000
[ 1.712607] pci 0000:00:18.3: [1022:14e3] type 00 class 0x060000
[ 1.712634] pci 0000:00:18.4: [1022:14e4] type 00 class 0x060000
[ 1.712660] pci 0000:00:18.5: [1022:14e5] type 00 class 0x060000
[ 1.712687] pci 0000:00:18.6: [1022:14e6] type 00 class 0x060000
[ 1.712713] pci 0000:00:18.7: [1022:14e7] type 00 class 0x060000
[ 1.712798] pci 0000:01:00.0: [10de:2704] type 00 class 0x030000
[ 1.712805] pci 0000:01:00.0: reg 0x10: [mem 0xf3000000-0xf3ffffff]
[ 1.712811] pci 0000:01:00.0: reg 0x14: [mem 0xfcc0000000-0xfccfffffff 64bit pref]
[ 1.712817] pci 0000:01:00.0: reg 0x1c: [mem 0xfcd0000000-0xfcd1ffffff 64bit pref]
[ 1.712821] pci 0000:01:00.0: reg 0x24: [io 0xf000-0xf07f]
[ 1.712826] pci 0000:01:00.0: reg 0x30: [mem 0xf4000000-0xf407ffff pref]
[ 1.712862] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.712984] pci 0000:01:00.1: [10de:22bb] type 00 class 0x040300
[ 1.712990] pci 0000:01:00.1: reg 0x10: [mem 0xf4080000-0xf4083fff]
[ 1.713089] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 1.713092] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 1.713094] pci 0000:00:01.1: bridge window [mem 0xf3000000-0xf40fffff]
[ 1.713096] pci 0000:00:01.1: bridge window [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 1.713178] pci 0000:02:00.0: [2646:5013] type 00 class 0x010802
[ 1.713219] pci 0000:02:00.0: reg 0x10: [mem 0xf6600000-0xf6603fff 64bit]
[ 1.713944] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 1.713947] pci 0000:00:01.2: bridge window [mem 0xf6600000-0xf66fffff]
[ 1.714009] pci 0000:03:00.0: [1022:43f4] type 01 class 0x060400
[ 1.714038] pci 0000:03:00.0: enabling Extended Tags
[ 1.714082] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 1.714294] pci 0000:00:02.1: PCI bridge to [bus 03-13]
[ 1.714296] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 1.714298] pci 0000:00:02.1: bridge window [mem 0xf4400000-0xf5ffffff]
[ 1.714414] pci 0000:04:00.0: [1022:43f5] type 01 class 0x060400
[ 1.714444] pci 0000:04:00.0: enabling Extended Tags
[ 1.714492] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 1.714612] pci 0000:04:04.0: [1022:43f5] type 01 class 0x060400
[ 1.714641] pci 0000:04:04.0: enabling Extended Tags
[ 1.714689] pci 0000:04:04.0: PME# supported from D0 D3hot D3cold
[ 1.714804] pci 0000:04:05.0: [1022:43f5] type 01 class 0x060400
[ 1.714834] pci 0000:04:05.0: enabling Extended Tags
[ 1.714881] pci 0000:04:05.0: PME# supported from D0 D3hot D3cold
[ 1.714997] pci 0000:04:06.0: [1022:43f5] type 01 class 0x060400
[ 1.715026] pci 0000:04:06.0: enabling Extended Tags
[ 1.715074] pci 0000:04:06.0: PME# supported from D0 D3hot D3cold
[ 1.715195] pci 0000:04:08.0: [1022:43f5] type 01 class 0x060400
[ 1.715225] pci 0000:04:08.0: enabling Extended Tags
[ 1.715270] pci 0000:04:08.0: PME# supported from D0 D3hot D3cold
[ 1.715432] pci 0000:04:0c.0: [1022:43f5] type 01 class 0x060400
[ 1.715461] pci 0000:04:0c.0: enabling Extended Tags
[ 1.715494] pci 0000:04:0c.0: PME# supported from D0 D3hot D3cold
[ 1.715588] pci 0000:04:0d.0: [1022:43f5] type 01 class 0x060400
[ 1.715617] pci 0000:04:0d.0: enabling Extended Tags
[ 1.715649] pci 0000:04:0d.0: PME# supported from D0 D3hot D3cold
[ 1.715730] pci 0000:03:00.0: PCI bridge to [bus 04-13]
[ 1.715734] pci 0000:03:00.0: bridge window [io 0xe000-0xefff]
[ 1.715736] pci 0000:03:00.0: bridge window [mem 0xf4400000-0xf5ffffff]
[ 1.715773] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 1.715813] pci 0000:04:04.0: PCI bridge to [bus 06]
[ 1.715852] pci 0000:04:05.0: PCI bridge to [bus 07]
[ 1.715892] pci 0000:04:06.0: PCI bridge to [bus 08]
[ 1.715942] pci 0000:09:00.0: [1022:43f4] type 01 class 0x060400
[ 1.715988] pci 0000:09:00.0: enabling Extended Tags
[ 1.716059] pci 0000:09:00.0: PME# supported from D0 D3hot D3cold
[ 1.716287] pci 0000:04:08.0: PCI bridge to [bus 09-11]
[ 1.716290] pci 0000:04:08.0: bridge window [io 0xe000-0xefff]
[ 1.716292] pci 0000:04:08.0: bridge window [mem 0xf4400000-0xf5cfffff]
[ 1.716432] pci 0000:0a:00.0: [1022:43f5] type 01 class 0x060400
[ 1.716479] pci 0000:0a:00.0: enabling Extended Tags
[ 1.716555] pci 0000:0a:00.0: PME# supported from D0 D3hot D3cold
[ 1.716721] pci 0000:0a:04.0: [1022:43f5] type 01 class 0x060400
[ 1.716768] pci 0000:0a:04.0: enabling Extended Tags
[ 1.716842] pci 0000:0a:04.0: PME# supported from D0 D3hot D3cold
[ 1.717007] pci 0000:0a:06.0: [1022:43f5] type 01 class 0x060400
[ 1.717054] pci 0000:0a:06.0: enabling Extended Tags
[ 1.717127] pci 0000:0a:06.0: PME# supported from D0 D3hot D3cold
[ 1.717292] pci 0000:0a:07.0: [1022:43f5] type 01 class 0x060400
[ 1.717338] pci 0000:0a:07.0: enabling Extended Tags
[ 1.717412] pci 0000:0a:07.0: PME# supported from D0 D3hot D3cold
[ 1.717578] pci 0000:0a:08.0: [1022:43f5] type 01 class 0x060400
[ 1.717624] pci 0000:0a:08.0: enabling Extended Tags
[ 1.717698] pci 0000:0a:08.0: PME# supported from D0 D3hot D3cold
[ 1.717869] pci 0000:0a:0c.0: [1022:43f5] type 01 class 0x060400
[ 1.717916] pci 0000:0a:0c.0: enabling Extended Tags
[ 1.717967] pci 0000:0a:0c.0: PME# supported from D0 D3hot D3cold
[ 1.718069] pci 0000:0a:0d.0: [1022:43f5] type 01 class 0x060400
[ 1.718115] pci 0000:0a:0d.0: enabling Extended Tags
[ 1.718167] pci 0000:0a:0d.0: PME# supported from D0 D3hot D3cold
[ 1.718273] pci 0000:09:00.0: PCI bridge to [bus 0a-11]
[ 1.718278] pci 0000:09:00.0: bridge window [io 0xe000-0xefff]
[ 1.718281] pci 0000:09:00.0: bridge window [mem 0xf4400000-0xf5cfffff]
[ 1.718327] pci 0000:0a:00.0: PCI bridge to [bus 0b]
[ 1.718433] pci 0000:0c:00.0: [8086:10c9] type 00 class 0x020000
[ 1.718464] pci 0000:0c:00.0: reg 0x10: [mem 0xf5420000-0xf543ffff]
[ 1.718479] pci 0000:0c:00.0: reg 0x14: [mem 0xf5000000-0xf53fffff]
[ 1.718493] pci 0000:0c:00.0: reg 0x18: [io 0xe020-0xe03f]
[ 1.718508] pci 0000:0c:00.0: reg 0x1c: [mem 0xf5444000-0xf5447fff]
[ 1.718549] pci 0000:0c:00.0: reg 0x30: [mem 0xf4c00000-0xf4ffffff pref]
[ 1.718718] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
[ 1.718791] pci 0000:0c:00.0: reg 0x184: [mem 0x00000000-0x00003fff 64bit]
[ 1.718793] pci 0000:0c:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit] (contains BAR0 for 8 VFs)
[ 1.718830] pci 0000:0c:00.0: reg 0x190: [mem 0x00000000-0x00003fff 64bit]
[ 1.718831] pci 0000:0c:00.0: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit] (contains BAR3 for 8 VFs)
[ 1.719032] pci 0000:0c:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:0a:04.0 (capable of 8.000 Gb/s with 2.5 GT/s PCIe x4 link)
[ 1.719209] pci 0000:0c:00.1: [8086:10c9] type 00 class 0x020000
[ 1.719240] pci 0000:0c:00.1: reg 0x10: [mem 0xf5400000-0xf541ffff]
[ 1.719255] pci 0000:0c:00.1: reg 0x14: [mem 0xf4800000-0xf4bfffff]
[ 1.719269] pci 0000:0c:00.1: reg 0x18: [io 0xe000-0xe01f]
[ 1.719283] pci 0000:0c:00.1: reg 0x1c: [mem 0xf5440000-0xf5443fff]
[ 1.719325] pci 0000:0c:00.1: reg 0x30: [mem 0xf4400000-0xf47fffff pref]
[ 1.719494] pci 0000:0c:00.1: PME# supported from D0 D3hot D3cold
[ 1.719566] pci 0000:0c:00.1: reg 0x184: [mem 0x00000000-0x00003fff 64bit]
[ 1.719567] pci 0000:0c:00.1: VF(n) BAR0 space: [mem 0x00000000-0x0001ffff 64bit] (contains BAR0 for 8 VFs)
[ 1.719605] pci 0000:0c:00.1: reg 0x190: [mem 0x00000000-0x00003fff 64bit]
[ 1.719606] pci 0000:0c:00.1: VF(n) BAR3 space: [mem 0x00000000-0x0001ffff 64bit] (contains BAR3 for 8 VFs)
[ 1.719951] pci 0000:0a:04.0: PCI bridge to [bus 0c]
[ 1.719956] pci 0000:0a:04.0: bridge window [io 0xe000-0xefff]
[ 1.719959] pci 0000:0a:04.0: bridge window [mem 0xf4400000-0xf54fffff]
[ 1.719964] pci 0000:0a:04.0: bridge has subordinate 0c but max busn 0d
[ 1.720043] pci 0000:0d:00.0: [8086:15f3] type 00 class 0x020000
[ 1.720066] pci 0000:0d:00.0: reg 0x10: [mem 0xf5800000-0xf58fffff]
[ 1.720103] pci 0000:0d:00.0: reg 0x1c: [mem 0xf5900000-0xf5903fff]
[ 1.720255] pci 0000:0d:00.0: PME# supported from D0 D3hot D3cold
[ 1.720498] pci 0000:0a:06.0: PCI bridge to [bus 0d]
[ 1.720505] pci 0000:0a:06.0: bridge window [mem 0xf5800000-0xf59fffff]
[ 1.720588] pci 0000:0e:00.0: [8086:2725] type 00 class 0x028000
[ 1.720618] pci 0000:0e:00.0: reg 0x10: [mem 0xf5c00000-0xf5c03fff 64bit]
[ 1.720778] pci 0000:0e:00.0: PME# supported from D0 D3hot D3cold
[ 1.721001] pci 0000:0a:07.0: PCI bridge to [bus 0e]
[ 1.721008] pci 0000:0a:07.0: bridge window [mem 0xf5c00000-0xf5cfffff]
[ 1.721074] pci 0000:0f:00.0: [1cc1:5350] type 00 class 0x010802
[ 1.721098] pci 0000:0f:00.0: reg 0x10: [mem 0xf5b00000-0xf5b03fff 64bit]
[ 1.721524] pci 0000:0a:08.0: PCI bridge to [bus 0f]
[ 1.721531] pci 0000:0a:08.0: bridge window [mem 0xf5b00000-0xf5bfffff]
[ 1.721590] pci 0000:10:00.0: [1022:43f7] type 00 class 0x0c0330
[ 1.721608] pci 0000:10:00.0: reg 0x10: [mem 0xf5a00000-0xf5a07fff 64bit]
[ 1.721650] pci 0000:10:00.0: enabling Extended Tags
[ 1.721706] pci 0000:10:00.0: PME# supported from D0 D3hot D3cold
[ 1.721823] pci 0000:0a:0c.0: PCI bridge to [bus 10]
[ 1.721827] pci 0000:0a:0c.0: bridge window [mem 0xf5a00000-0xf5afffff]
[ 1.722166] pci 0000:11:00.0: [1022:43f6] type 00 class 0x010601
[ 1.722215] pci 0000:11:00.0: reg 0x24: [mem 0xf5680000-0xf56803ff]
[ 1.722223] pci 0000:11:00.0: reg 0x30: [mem 0xf5600000-0xf567ffff pref]
[ 1.722230] pci 0000:11:00.0: enabling Extended Tags
[ 1.722276] pci 0000:11:00.0: PME# supported from D0 D3hot D3cold
[ 1.722378] pci 0000:0a:0d.0: PCI bridge to [bus 11]
[ 1.722383] pci 0000:0a:0d.0: bridge window [mem 0xf5600000-0xf57fffff]
[ 1.722463] pci 0000:12:00.0: [1022:43f7] type 00 class 0x0c0330
[ 1.722474] pci 0000:12:00.0: reg 0x10: [mem 0xf5f00000-0xf5f07fff 64bit]
[ 1.722501] pci 0000:12:00.0: enabling Extended Tags
[ 1.722536] pci 0000:12:00.0: PME# supported from D0 D3hot D3cold
[ 1.722637] pci 0000:04:0c.0: PCI bridge to [bus 12]
[ 1.722640] pci 0000:04:0c.0: bridge window [mem 0xf5f00000-0xf5ffffff]
[ 1.722686] pci 0000:13:00.0: [1022:43f6] type 00 class 0x010601
[ 1.722718] pci 0000:13:00.0: reg 0x24: [mem 0xf5e80000-0xf5e803ff]
[ 1.722723] pci 0000:13:00.0: reg 0x30: [mem 0xf5e00000-0xf5e7ffff pref]
[ 1.722728] pci 0000:13:00.0: enabling Extended Tags
[ 1.722757] pci 0000:13:00.0: PME# supported from D0 D3hot D3cold
[ 1.722836] pci 0000:04:0d.0: PCI bridge to [bus 13]
[ 1.722840] pci 0000:04:0d.0: bridge window [mem 0xf5e00000-0xf5efffff]
[ 1.722922] pci 0000:14:00.0: [144d:a808] type 00 class 0x010802
[ 1.722935] pci 0000:14:00.0: reg 0x10: [mem 0xf6500000-0xf6503fff 64bit]
[ 1.723105] pci 0000:00:02.2: PCI bridge to [bus 14]
[ 1.723109] pci 0000:00:02.2: bridge window [mem 0xf6500000-0xf65fffff]
[ 1.723180] pci 0000:15:00.0: [1002:164e] type 00 class 0x030000
[ 1.723188] pci 0000:15:00.0: reg 0x10: [mem 0xfce0000000-0xfcefffffff 64bit pref]
[ 1.723193] pci 0000:15:00.0: reg 0x18: [mem 0xfcf0000000-0xfcf01fffff 64bit pref]
[ 1.723197] pci 0000:15:00.0: reg 0x20: [io 0xd000-0xd0ff]
[ 1.723201] pci 0000:15:00.0: reg 0x24: [mem 0xf6300000-0xf637ffff]
[ 1.723206] pci 0000:15:00.0: enabling Extended Tags
[ 1.723215] pci 0000:15:00.0: BAR 0: assigned to efifb
[ 1.723241] pci 0000:15:00.0: PME# supported from D1 D2 D3hot D3cold
[ 1.723329] pci 0000:15:00.2: [1022:1649] type 00 class 0x108000
[ 1.723359] pci 0000:15:00.2: reg 0x18: [mem 0xf6200000-0xf62fffff]
[ 1.723366] pci 0000:15:00.2: reg 0x24: [mem 0xf6380000-0xf6381fff]
[ 1.723371] pci 0000:15:00.2: enabling Extended Tags
[ 1.723445] pci 0000:15:00.3: [1022:15b6] type 00 class 0x0c0330
[ 1.723453] pci 0000:15:00.3: reg 0x10: [mem 0xf6100000-0xf61fffff 64bit]
[ 1.723469] pci 0000:15:00.3: enabling Extended Tags
[ 1.723492] pci 0000:15:00.3: PME# supported from D0 D3hot D3cold
[ 1.723558] pci 0000:15:00.4: [1022:15b7] type 00 class 0x0c0330
[ 1.723565] pci 0000:15:00.4: reg 0x10: [mem 0xf6000000-0xf60fffff 64bit]
[ 1.723582] pci 0000:15:00.4: enabling Extended Tags
[ 1.723605] pci 0000:15:00.4: PME# supported from D0 D3hot D3cold
[ 1.723678] pci 0000:00:08.1: PCI bridge to [bus 15]
[ 1.723681] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 1.723682] pci 0000:00:08.1: bridge window [mem 0xf6000000-0xf63fffff]
[ 1.723684] pci 0000:00:08.1: bridge window [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 1.723717] pci 0000:16:00.0: [1022:15b8] type 00 class 0x0c0330
[ 1.723729] pci 0000:16:00.0: reg 0x10: [mem 0xf6400000-0xf64fffff 64bit]
[ 1.723751] pci 0000:16:00.0: enabling Extended Tags
[ 1.723778] pci 0000:16:00.0: PME# supported from D0 D3hot D3cold
[ 1.723858] pci 0000:00:08.3: PCI bridge to [bus 16]
[ 1.723861] pci 0000:00:08.3: bridge window [mem 0xf6400000-0xf64fffff]
[ 1.731489] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 1.731535] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 1.731576] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 1.731625] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 1.731670] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 1.731707] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 1.731745] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 1.731782] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 1.734514] iommu: Default domain type: Passthrough (set via kernel command line)
[ 1.734624] SCSI subsystem initialized
[ 1.734631] libata version 3.00 loaded.
[ 1.734631] ACPI: bus type USB registered
[ 1.734631] usbcore: registered new interface driver usbfs
[ 1.734631] usbcore: registered new interface driver hub
[ 1.734631] usbcore: registered new device driver usb
[ 1.759671] i2c i2c-1: Failed to register i2c client MSFT8000:00 at 0x40 (-16)
[ 1.759676] fbcon: Taking over console
[ 1.759745] pps_core: LinuxPPS API ver. 1 registered
[ 1.759746] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.759748] PTP clock support registered
[ 1.759754] EDAC MC: Ver: 3.0.0
[ 1.761187] efivars: Registered efivars operations
[ 1.761332] NetLabel: Initializing
[ 1.761332] NetLabel: domain hash size = 128
[ 1.761333] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.761346] NetLabel: unlabeled traffic allowed by default
[ 1.761349] mctp: management component transport protocol core
[ 1.761349] NET: Registered PF_MCTP protocol family
[ 1.761352] PCI: Using ACPI for IRQ routing
[ 1.766053] PCI: pci_cache_line_size set to 64 bytes
[ 1.766055] pci 0000:00:02.1: can't claim BAR 14 [mem 0xf4400000-0xf5ffffff]: address conflict with AMDIF031:00 [mem 0xf5700000-0xf5700fff]
[ 1.766058] pci 0000:03:00.0: can't claim BAR 14 [mem 0xf4400000-0xf5ffffff]: no compatible bridge window
[ 1.766059] pci 0000:04:08.0: can't claim BAR 14 [mem 0xf4400000-0xf5cfffff]: no compatible bridge window
[ 1.766060] pci 0000:09:00.0: can't claim BAR 14 [mem 0xf4400000-0xf5cfffff]: no compatible bridge window
[ 1.766061] pci 0000:0a:04.0: can't claim BAR 14 [mem 0xf4400000-0xf54fffff]: no compatible bridge window
[ 1.766062] pci 0000:0a:06.0: can't claim BAR 14 [mem 0xf5800000-0xf59fffff]: no compatible bridge window
[ 1.766063] pci 0000:0a:07.0: can't claim BAR 14 [mem 0xf5c00000-0xf5cfffff]: no compatible bridge window
[ 1.766064] pci 0000:0a:08.0: can't claim BAR 14 [mem 0xf5b00000-0xf5bfffff]: no compatible bridge window
[ 1.766065] pci 0000:0a:0c.0: can't claim BAR 14 [mem 0xf5a00000-0xf5afffff]: no compatible bridge window
[ 1.766066] pci 0000:0a:0d.0: can't claim BAR 14 [mem 0xf5600000-0xf57fffff]: no compatible bridge window
[ 1.766067] pci 0000:04:0c.0: can't claim BAR 14 [mem 0xf5f00000-0xf5ffffff]: no compatible bridge window
[ 1.766068] pci 0000:04:0d.0: can't claim BAR 14 [mem 0xf5e00000-0xf5efffff]: no compatible bridge window
[ 1.766091] pci 0000:0d:00.0: can't claim BAR 0 [mem 0xf5800000-0xf58fffff]: no compatible bridge window
[ 1.766092] pci 0000:0d:00.0: can't claim BAR 3 [mem 0xf5900000-0xf5903fff]: no compatible bridge window
[ 1.766099] pci 0000:0f:00.0: can't claim BAR 0 [mem 0xf5b00000-0xf5b03fff 64bit]: no compatible bridge window
[ 1.766102] pci 0000:10:00.0: can't claim BAR 0 [mem 0xf5a00000-0xf5a07fff 64bit]: no compatible bridge window
[ 1.766105] pci 0000:11:00.0: can't claim BAR 5 [mem 0xf5680000-0xf56803ff]: no compatible bridge window
[ 1.766107] pci 0000:12:00.0: can't claim BAR 0 [mem 0xf5f00000-0xf5f07fff 64bit]: no compatible bridge window
[ 1.766109] pci 0000:13:00.0: can't claim BAR 5 [mem 0xf5e80000-0xf5e803ff]: no compatible bridge window
[ 1.766139] pci 0000:0c:00.0: can't claim BAR 0 [mem 0xf5420000-0xf543ffff]: no compatible bridge window
[ 1.766140] pci 0000:0c:00.0: can't claim BAR 1 [mem 0xf5000000-0xf53fffff]: no compatible bridge window
[ 1.766141] pci 0000:0c:00.0: can't claim BAR 3 [mem 0xf5444000-0xf5447fff]: no compatible bridge window
[ 1.766145] pci 0000:0c:00.1: can't claim BAR 0 [mem 0xf5400000-0xf541ffff]: no compatible bridge window
[ 1.766146] pci 0000:0c:00.1: can't claim BAR 1 [mem 0xf4800000-0xf4bfffff]: no compatible bridge window
[ 1.766147] pci 0000:0c:00.1: can't claim BAR 3 [mem 0xf5440000-0xf5443fff]: no compatible bridge window
[ 1.766154] pci 0000:0e:00.0: can't claim BAR 0 [mem 0xf5c00000-0xf5c03fff 64bit]: no compatible bridge window
[ 1.766173] e820: reserve RAM buffer [mem 0x09aff000-0x0bffffff]
[ 1.766175] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 1.766175] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 1.766176] e820: reserve RAM buffer [mem 0x711ee018-0x73ffffff]
[ 1.766177] e820: reserve RAM buffer [mem 0x711fe018-0x73ffffff]
[ 1.766177] e820: reserve RAM buffer [mem 0x7120f018-0x73ffffff]
[ 1.766178] e820: reserve RAM buffer [mem 0x79a78018-0x7bffffff]
[ 1.766179] e820: reserve RAM buffer [mem 0x79a83018-0x7bffffff]
[ 1.766179] e820: reserve RAM buffer [mem 0x7a6cd000-0x7bffffff]
[ 1.766180] e820: reserve RAM buffer [mem 0x7c504000-0x7fffffff]
[ 1.766181] e820: reserve RAM buffer [mem 0x7e4cc000-0x7fffffff]
[ 1.766181] e820: reserve RAM buffer [mem 0x8fff9000-0x8fffffff]
[ 1.766182] e820: reserve RAM buffer [mem 0x103de80000-0x103fffffff]
[ 1.767857] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 1.767857] pci 0000:01:00.0: vgaarb: bridge control possible
[ 1.767857] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1.767857] pci 0000:15:00.0: vgaarb: setting as boot VGA device (overriding previous)
[ 1.767857] pci 0000:15:00.0: vgaarb: bridge control possible
[ 1.767857] pci 0000:15:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1.767857] vgaarb: loaded
[ 1.767904] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.767913] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 1.767913] clocksource: Switched to clocksource hpet
[ 1.768017] VFS: Disk quotas dquot_6.6.0
[ 1.768028] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.768077] pnp: PnP ACPI init
[ 1.768145] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.768203] system 00:01: [mem 0x1040000000-0x105fffffff window] has been reserved
[ 1.768416] system 00:03: [io 0x0a00-0x0a2f] has been reserved
[ 1.768417] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 1.768418] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 1.768419] system 00:03: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 1.768608] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 1.768609] system 00:04: [io 0x040b] has been reserved
[ 1.768610] system 00:04: [io 0x04d6] has been reserved
[ 1.768611] system 00:04: [io 0x0c00-0x0c01] has been reserved
[ 1.768612] system 00:04: [io 0x0c14] has been reserved
[ 1.768613] system 00:04: [io 0x0c50-0x0c51] has been reserved
[ 1.768614] system 00:04: [io 0x0c52] has been reserved
[ 1.768615] system 00:04: [io 0x0c6c] has been reserved
[ 1.768616] system 00:04: [io 0x0c6f] has been reserved
[ 1.768617] system 00:04: [io 0x0cd8-0x0cdf] has been reserved
[ 1.768618] system 00:04: [io 0x0800-0x089f] has been reserved
[ 1.768619] system 00:04: [io 0x0b00-0x0b0f] has been reserved
[ 1.768620] system 00:04: [io 0x0b20-0x0b3f] has been reserved
[ 1.768621] system 00:04: [io 0x0900-0x090f] has been reserved
[ 1.768622] system 00:04: [io 0x0910-0x091f] has been reserved
[ 1.768623] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 1.768624] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 1.768626] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[ 1.768627] system 00:04: [mem 0xfeb00000-0xfeb00fff] has been reserved
[ 1.768628] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 1.774096] pnp: PnP ACPI: found 5 devices
[ 1.779888] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.779926] NET: Registered PF_INET protocol family
[ 1.780020] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.781328] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.781363] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.781523] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 1.781747] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 1.781798] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.781922] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 1.781986] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.782061] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.782132] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.782136] NET: Registered PF_XDP protocol family
[ 1.782138] pci 0000:0c:00.0: can't claim BAR 6 [mem 0xf4c00000-0xf4ffffff pref]: no compatible bridge window
[ 1.782140] pci 0000:0c:00.1: can't claim BAR 6 [mem 0xf4400000-0xf47fffff pref]: no compatible bridge window
[ 1.782141] pci 0000:11:00.0: can't claim BAR 6 [mem 0xf5600000-0xf567ffff pref]: no compatible bridge window
[ 1.782142] pci 0000:13:00.0: can't claim BAR 6 [mem 0xf5e00000-0xf5e7ffff pref]: no compatible bridge window
[ 1.782151] pci 0000:00:02.1: BAR 14: assigned [mem 0xa0000000-0xa19fffff]
[ 1.782153] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 1.782154] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 1.782157] pci 0000:00:01.1: bridge window [mem 0xf3000000-0xf40fffff]
[ 1.782158] pci 0000:00:01.1: bridge window [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 1.782168] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 1.782170] pci 0000:00:01.2: bridge window [mem 0xf6600000-0xf66fffff]
[ 1.782181] pci 0000:03:00.0: BAR 14: assigned [mem 0xa0000000-0xa19fffff]
[ 1.782183] pci 0000:04:08.0: BAR 14: assigned [mem 0xa0000000-0xa17fffff]
[ 1.782184] pci 0000:04:0c.0: BAR 14: assigned [mem 0xa1800000-0xa18fffff]
[ 1.782185] pci 0000:04:0d.0: BAR 14: assigned [mem 0xa1900000-0xa19fffff]
[ 1.782186] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 1.782197] pci 0000:04:04.0: PCI bridge to [bus 06]
[ 1.782203] pci 0000:04:05.0: PCI bridge to [bus 07]
[ 1.782209] pci 0000:04:06.0: PCI bridge to [bus 08]
[ 1.782216] pci 0000:09:00.0: BAR 14: assigned [mem 0xa0000000-0xa17fffff]
[ 1.782218] pci 0000:0a:04.0: BAR 14: assigned [mem 0xa0000000-0xa11fffff]
[ 1.782219] pci 0000:0a:06.0: BAR 14: assigned [mem 0xa1200000-0xa13fffff]
[ 1.782220] pci 0000:0a:07.0: BAR 14: assigned [mem 0xa1400000-0xa14fffff]
[ 1.782221] pci 0000:0a:08.0: BAR 14: assigned [mem 0xa1500000-0xa15fffff]
[ 1.782222] pci 0000:0a:0c.0: BAR 14: assigned [mem 0xa1600000-0xa16fffff]
[ 1.782223] pci 0000:0a:0d.0: BAR 14: assigned [mem 0xa1700000-0xa17fffff]
[ 1.782224] pci 0000:0a:00.0: PCI bridge to [bus 0b]
[ 1.782236] pci 0000:0c:00.0: BAR 1: assigned [mem 0xa0000000-0xa03fffff]
[ 1.782243] pci 0000:0c:00.0: BAR 6: assigned [mem 0xa0400000-0xa07fffff pref]
[ 1.782244] pci 0000:0c:00.1: BAR 1: assigned [mem 0xa0800000-0xa0bfffff]
[ 1.782250] pci 0000:0c:00.1: BAR 6: assigned [mem 0xa0c00000-0xa0ffffff pref]
[ 1.782251] pci 0000:0c:00.0: BAR 0: assigned [mem 0xa1000000-0xa101ffff]
[ 1.782258] pci 0000:0c:00.1: BAR 0: assigned [mem 0xa1020000-0xa103ffff]
[ 1.782264] pci 0000:0c:00.0: BAR 3: assigned [mem 0xa1040000-0xa1043fff]
[ 1.782271] pci 0000:0c:00.0: BAR 7: assigned [mem 0xa1044000-0xa1063fff 64bit]
[ 1.782280] pci 0000:0c:00.0: BAR 10: assigned [mem 0xa1064000-0xa1083fff 64bit]
[ 1.782288] pci 0000:0c:00.1: BAR 3: assigned [mem 0xa1084000-0xa1087fff]
[ 1.782295] pci 0000:0c:00.1: BAR 7: assigned [mem 0xa1088000-0xa10a7fff 64bit]
[ 1.782304] pci 0000:0c:00.1: BAR 10: assigned [mem 0xa10a8000-0xa10c7fff 64bit]
[ 1.782313] pci 0000:0a:04.0: PCI bridge to [bus 0c]
[ 1.782315] pci 0000:0a:04.0: bridge window [io 0xe000-0xefff]
[ 1.782319] pci 0000:0a:04.0: bridge window [mem 0xa0000000-0xa11fffff]
[ 1.782326] pci 0000:0d:00.0: BAR 0: assigned [mem 0xa1200000-0xa12fffff]
[ 1.782331] pci 0000:0d:00.0: BAR 3: assigned [mem 0xa1300000-0xa1303fff]
[ 1.782335] pci 0000:0a:06.0: PCI bridge to [bus 0d]
[ 1.782339] pci 0000:0a:06.0: bridge window [mem 0xa1200000-0xa13fffff]
[ 1.782346] pci 0000:0e:00.0: BAR 0: assigned [mem 0xa1400000-0xa1403fff 64bit]
[ 1.782360] pci 0000:0a:07.0: PCI bridge to [bus 0e]
[ 1.782364] pci 0000:0a:07.0: bridge window [mem 0xa1400000-0xa14fffff]
[ 1.782371] pci 0000:0f:00.0: BAR 0: assigned [mem 0xa1500000-0xa1503fff 64bit]
[ 1.782381] pci 0000:0a:08.0: PCI bridge to [bus 0f]
[ 1.782385] pci 0000:0a:08.0: bridge window [mem 0xa1500000-0xa15fffff]
[ 1.782392] pci 0000:10:00.0: BAR 0: assigned [mem 0xa1600000-0xa1607fff 64bit]
[ 1.782400] pci 0000:0a:0c.0: PCI bridge to [bus 10]
[ 1.782404] pci 0000:0a:0c.0: bridge window [mem 0xa1600000-0xa16fffff]
[ 1.782411] pci 0000:11:00.0: BAR 6: assigned [mem 0xa1700000-0xa177ffff pref]
[ 1.782412] pci 0000:11:00.0: BAR 5: assigned [mem 0xa1780000-0xa17803ff]
[ 1.782415] pci 0000:0a:0d.0: PCI bridge to [bus 11]
[ 1.782418] pci 0000:0a:0d.0: bridge window [mem 0xa1700000-0xa17fffff]
[ 1.782425] pci 0000:09:00.0: PCI bridge to [bus 0a-11]
[ 1.782427] pci 0000:09:00.0: bridge window [io 0xe000-0xefff]
[ 1.782431] pci 0000:09:00.0: bridge window [mem 0xa0000000-0xa17fffff]
[ 1.782437] pci 0000:04:08.0: PCI bridge to [bus 09-11]
[ 1.782439] pci 0000:04:08.0: bridge window [io 0xe000-0xefff]
[ 1.782441] pci 0000:04:08.0: bridge window [mem 0xa0000000-0xa17fffff]
[ 1.782446] pci 0000:12:00.0: BAR 0: assigned [mem 0xa1800000-0xa1807fff 64bit]
[ 1.782452] pci 0000:04:0c.0: PCI bridge to [bus 12]
[ 1.782454] pci 0000:04:0c.0: bridge window [mem 0xa1800000-0xa18fffff]
[ 1.782459] pci 0000:13:00.0: BAR 6: assigned [mem 0xa1900000-0xa197ffff pref]
[ 1.782460] pci 0000:13:00.0: BAR 5: assigned [mem 0xa1980000-0xa19803ff]
[ 1.782462] pci 0000:04:0d.0: PCI bridge to [bus 13]
[ 1.782465] pci 0000:04:0d.0: bridge window [mem 0xa1900000-0xa19fffff]
[ 1.782469] pci 0000:03:00.0: PCI bridge to [bus 04-13]
[ 1.782471] pci 0000:03:00.0: bridge window [io 0xe000-0xefff]
[ 1.782473] pci 0000:03:00.0: bridge window [mem 0xa0000000-0xa19fffff]
[ 1.782478] pci 0000:00:02.1: PCI bridge to [bus 03-13]
[ 1.782479] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 1.782481] pci 0000:00:02.1: bridge window [mem 0xa0000000-0xa19fffff]
[ 1.782491] pci 0000:00:02.2: PCI bridge to [bus 14]
[ 1.782493] pci 0000:00:02.2: bridge window [mem 0xf6500000-0xf65fffff]
[ 1.782504] pci 0000:00:08.1: PCI bridge to [bus 15]
[ 1.782509] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 1.782511] pci 0000:00:08.1: bridge window [mem 0xf6000000-0xf63fffff]
[ 1.782512] pci 0000:00:08.1: bridge window [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 1.782515] pci 0000:00:08.3: PCI bridge to [bus 16]
[ 1.782516] pci 0000:00:08.3: bridge window [mem 0xf6400000-0xf64fffff]
[ 1.782520] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 1.782521] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 1.782521] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 1.782522] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 1.782523] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 1.782524] pci_bus 0000:00: resource 9 [mem 0xa0000000-0xf6ffffff window]
[ 1.782525] pci_bus 0000:00: resource 10 [mem 0x1060000000-0xfcffffffff window]
[ 1.782526] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 1.782527] pci_bus 0000:01: resource 1 [mem 0xf3000000-0xf40fffff]
[ 1.782527] pci_bus 0000:01: resource 2 [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 1.782528] pci_bus 0000:02: resource 1 [mem 0xf6600000-0xf66fffff]
[ 1.782529] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 1.782530] pci_bus 0000:03: resource 1 [mem 0xa0000000-0xa19fffff]
[ 1.782531] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 1.782532] pci_bus 0000:04: resource 1 [mem 0xa0000000-0xa19fffff]
[ 1.782533] pci_bus 0000:09: resource 0 [io 0xe000-0xefff]
[ 1.782534] pci_bus 0000:09: resource 1 [mem 0xa0000000-0xa17fffff]
[ 1.782534] pci_bus 0000:0a: resource 0 [io 0xe000-0xefff]
[ 1.782535] pci_bus 0000:0a: resource 1 [mem 0xa0000000-0xa17fffff]
[ 1.782536] pci_bus 0000:0c: resource 0 [io 0xe000-0xefff]
[ 1.782537] pci_bus 0000:0c: resource 1 [mem 0xa0000000-0xa11fffff]
[ 1.782538] pci_bus 0000:0d: resource 1 [mem 0xa1200000-0xa13fffff]
[ 1.782539] pci_bus 0000:0e: resource 1 [mem 0xa1400000-0xa14fffff]
[ 1.782540] pci_bus 0000:0f: resource 1 [mem 0xa1500000-0xa15fffff]
[ 1.782540] pci_bus 0000:10: resource 1 [mem 0xa1600000-0xa16fffff]
[ 1.782541] pci_bus 0000:11: resource 1 [mem 0xa1700000-0xa17fffff]
[ 1.782542] pci_bus 0000:12: resource 1 [mem 0xa1800000-0xa18fffff]
[ 1.782543] pci_bus 0000:13: resource 1 [mem 0xa1900000-0xa19fffff]
[ 1.782544] pci_bus 0000:14: resource 1 [mem 0xf6500000-0xf65fffff]
[ 1.782545] pci_bus 0000:15: resource 0 [io 0xd000-0xdfff]
[ 1.782545] pci_bus 0000:15: resource 1 [mem 0xf6000000-0xf63fffff]
[ 1.782546] pci_bus 0000:15: resource 2 [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 1.782547] pci_bus 0000:16: resource 1 [mem 0xf6400000-0xf64fffff]
[ 1.782672] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 1.782691] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 1.783202] PCI: CLS 64 bytes, default 64
[ 1.783213] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.783244] pci 0000:00:01.0: Adding to iommu group 0
[ 1.783251] Trying to unpack rootfs image as initramfs...
[ 1.783255] pci 0000:00:01.1: Adding to iommu group 1
[ 1.783268] pci 0000:00:01.2: Adding to iommu group 2
[ 1.783285] pci 0000:00:02.0: Adding to iommu group 3
[ 1.783295] pci 0000:00:02.1: Adding to iommu group 4
[ 1.783306] pci 0000:00:02.2: Adding to iommu group 5
[ 1.783322] pci 0000:00:03.0: Adding to iommu group 6
[ 1.783337] pci 0000:00:04.0: Adding to iommu group 7
[ 1.783354] pci 0000:00:08.0: Adding to iommu group 8
[ 1.783367] pci 0000:00:08.1: Adding to iommu group 9
[ 1.783378] pci 0000:00:08.3: Adding to iommu group 10
[ 1.783400] pci 0000:00:14.0: Adding to iommu group 11
[ 1.783411] pci 0000:00:14.3: Adding to iommu group 11
[ 1.783469] pci 0000:00:18.0: Adding to iommu group 12
[ 1.783480] pci 0000:00:18.1: Adding to iommu group 12
[ 1.783490] pci 0000:00:18.2: Adding to iommu group 12
[ 1.783500] pci 0000:00:18.3: Adding to iommu group 12
[ 1.783510] pci 0000:00:18.4: Adding to iommu group 12
[ 1.783521] pci 0000:00:18.5: Adding to iommu group 12
[ 1.783531] pci 0000:00:18.6: Adding to iommu group 12
[ 1.783541] pci 0000:00:18.7: Adding to iommu group 12
[ 1.783564] pci 0000:01:00.0: Adding to iommu group 13
[ 1.783575] pci 0000:01:00.1: Adding to iommu group 13
[ 1.783586] pci 0000:02:00.0: Adding to iommu group 14
[ 1.783597] pci 0000:03:00.0: Adding to iommu group 15
[ 1.783608] pci 0000:04:00.0: Adding to iommu group 16
[ 1.783618] pci 0000:04:04.0: Adding to iommu group 17
[ 1.783629] pci 0000:04:05.0: Adding to iommu group 18
[ 1.783640] pci 0000:04:06.0: Adding to iommu group 19
[ 1.783650] pci 0000:04:08.0: Adding to iommu group 20
[ 1.783661] pci 0000:04:0c.0: Adding to iommu group 21
[ 1.783672] pci 0000:04:0d.0: Adding to iommu group 22
[ 1.783674] pci 0000:09:00.0: Adding to iommu group 20
[ 1.783677] pci 0000:0a:00.0: Adding to iommu group 20
[ 1.783680] pci 0000:0a:04.0: Adding to iommu group 20
[ 1.783682] pci 0000:0a:06.0: Adding to iommu group 20
[ 1.783685] pci 0000:0a:07.0: Adding to iommu group 20
[ 1.783687] pci 0000:0a:08.0: Adding to iommu group 20
[ 1.783690] pci 0000:0a:0c.0: Adding to iommu group 20
[ 1.783693] pci 0000:0a:0d.0: Adding to iommu group 20
[ 1.783696] pci 0000:0c:00.0: Adding to iommu group 20
[ 1.783698] pci 0000:0c:00.1: Adding to iommu group 20
[ 1.783701] pci 0000:0d:00.0: Adding to iommu group 20
[ 1.783704] pci 0000:0e:00.0: Adding to iommu group 20
[ 1.783706] pci 0000:0f:00.0: Adding to iommu group 20
[ 1.783709] pci 0000:10:00.0: Adding to iommu group 20
[ 1.783713] pci 0000:11:00.0: Adding to iommu group 20
[ 1.783715] pci 0000:12:00.0: Adding to iommu group 21
[ 1.783718] pci 0000:13:00.0: Adding to iommu group 22
[ 1.783728] pci 0000:14:00.0: Adding to iommu group 23
[ 1.783759] pci 0000:15:00.0: Adding to iommu group 24
[ 1.783770] pci 0000:15:00.2: Adding to iommu group 25
[ 1.783781] pci 0000:15:00.3: Adding to iommu group 26
[ 1.783792] pci 0000:15:00.4: Adding to iommu group 27
[ 1.783803] pci 0000:16:00.0: Adding to iommu group 28
[ 1.784062] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.784063] AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
[ 1.784068] AMD-Vi: Interrupt remapping enabled
[ 1.784147] AMD-Vi: Virtual APIC enabled
[ 1.784152] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.784154] software IO TLB: mapped [mem 0x0000000075a78000-0x0000000079a78000] (64MB)
[ 1.784216] LVT offset 0 assigned for vector 0x400
[ 1.787360] perf: AMD IBS detected (0x00000bff)
[ 1.787369] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 1.790501] Initialise system trusted keyrings
[ 1.790507] Key type blacklist registered
[ 1.790543] workingset: timestamp_bits=41 max_order=24 bucket_order=0
[ 1.790548] zbud: loaded
[ 1.790659] integrity: Platform Keyring initialized
[ 1.790661] integrity: Machine keyring initialized
[ 1.795339] Key type asymmetric registered
[ 1.795340] Asymmetric key parser 'x509' registered
[ 1.795348] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 1.795390] io scheduler mq-deadline registered
[ 1.795391] io scheduler kyber registered
[ 1.795396] io scheduler bfq registered
[ 1.796631] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[ 1.796741] pcieport 0000:00:01.2: PME: Signaling with IRQ 29
[ 1.796857] pcieport 0000:00:02.1: PME: Signaling with IRQ 30
[ 1.796971] pcieport 0000:00:02.2: PME: Signaling with IRQ 31
[ 1.797066] pcieport 0000:00:08.1: PME: Signaling with IRQ 32
[ 1.797171] pcieport 0000:00:08.3: PME: Signaling with IRQ 33
[ 1.798801] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.798947] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.798962] ACPI: button: Power Button [PWRB]
[ 1.798985] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.800457] ACPI: button: Power Button [PWRF]
[ 1.800578] Estimated ratio of average max frequency by base frequency (times 1024): 1214
[ 1.800601] Monitor-Mwait will be used to enter C-1 state
[ 1.800608] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 1.800842] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 1.801089] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 1.801328] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 1.801566] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 1.801808] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 1.802049] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 1.802289] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 1.802499] ACPI: \_SB_.PLTF.C010: Found 3 idle states
[ 1.802702] ACPI: \_SB_.PLTF.C012: Found 3 idle states
[ 1.802887] ACPI: \_SB_.PLTF.C014: Found 3 idle states
[ 1.802968] ACPI: \_SB_.PLTF.C016: Found 3 idle states
[ 1.803085] ACPI: \_SB_.PLTF.C018: Found 3 idle states
[ 1.803203] ACPI: \_SB_.PLTF.C01A: Found 3 idle states
[ 1.803289] ACPI: \_SB_.PLTF.C01C: Found 3 idle states
[ 1.803409] ACPI: \_SB_.PLTF.C01E: Found 3 idle states
[ 1.803491] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 1.803573] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 1.803682] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 1.803803] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 1.803915] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 1.804028] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 1.804138] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 1.804250] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 1.804335] ACPI: \_SB_.PLTF.C011: Found 3 idle states
[ 1.804448] ACPI: \_SB_.PLTF.C013: Found 3 idle states
[ 1.804563] ACPI: \_SB_.PLTF.C015: Found 3 idle states
[ 1.804673] ACPI: \_SB_.PLTF.C017: Found 3 idle states
[ 1.804787] ACPI: \_SB_.PLTF.C019: Found 3 idle states
[ 1.804903] ACPI: \_SB_.PLTF.C01B: Found 3 idle states
[ 1.805016] ACPI: \_SB_.PLTF.C01D: Found 3 idle states
[ 1.805134] ACPI: \_SB_.PLTF.C01F: Found 3 idle states
[ 1.805455] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.807354] Non-volatile memory driver v1.3
[ 1.807355] Linux agpgart interface v0.103
[ 1.807425] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 1.807486] ACPI: bus type drm_connector registered
[ 1.809904] ahci 0000:11:00.0: version 3.0
[ 1.810032] ahci 0000:11:00.0: SSS flag set, parallel bus scan disabled
[ 1.810070] ahci 0000:11:00.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0xf impl SATA mode
[ 1.810072] ahci 0000:11:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 1.810426] scsi host0: ahci
[ 1.810526] scsi host1: ahci
[ 1.810614] scsi host2: ahci
[ 1.810695] scsi host3: ahci
[ 1.810778] scsi host4: ahci
[ 1.810861] scsi host5: ahci
[ 1.810886] ata1: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780100 irq 47
[ 1.810888] ata2: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780180 irq 47
[ 1.810890] ata3: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780200 irq 47
[ 1.810891] ata4: SATA max UDMA/133 abar m1024@0xa1780000 port 0xa1780280 irq 47
[ 1.810893] ata5: DUMMY
[ 1.810893] ata6: DUMMY
[ 1.810986] ahci 0000:13:00.0: SSS flag set, parallel bus scan disabled
[ 1.811010] ahci 0000:13:00.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0xf impl SATA mode
[ 1.811012] ahci 0000:13:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 1.811340] scsi host6: ahci
[ 1.811423] scsi host7: ahci
[ 1.811507] scsi host8: ahci
[ 1.811588] scsi host9: ahci
[ 1.811671] scsi host10: ahci
[ 1.811755] scsi host11: ahci
[ 1.811782] ata7: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980100 irq 48
[ 1.811783] ata8: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980180 irq 48
[ 1.811784] ata9: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980200 irq 48
[ 1.811786] ata10: SATA max UDMA/133 abar m1024@0xa1980000 port 0xa1980280 irq 48
[ 1.811787] ata11: DUMMY
[ 1.811788] ata12: DUMMY
[ 1.811862] usbcore: registered new interface driver usbserial_generic
[ 1.811867] usbserial: USB Serial support registered for generic
[ 1.811932] rtc_cmos 00:02: RTC can wake from S4
[ 1.812137] rtc_cmos 00:02: registered as rtc0
[ 1.812189] rtc_cmos 00:02: setting system clock to 2024-08-16T11:57:44 UTC (1723809464)
[ 1.812213] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
[ 1.817657] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.817875] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 1.821571] Console: switching to colour frame buffer device 160x45
[ 1.825158] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 1.825253] hid: raw HID events driver (C) Jiri Kosina
[ 1.825413] drop_monitor: Initializing network drop monitor service
[ 1.832627] Initializing XFRM netlink socket
[ 1.832656] NET: Registered PF_INET6 protocol family
[ 1.862775] Freeing initrd memory: 37312K
[ 1.867215] Segment Routing with IPv6
[ 1.867217] RPL Segment Routing with IPv6
[ 1.867228] In-situ OAM (IOAM) with IPv6
[ 1.867254] NET: Registered PF_PACKET protocol family
[ 1.869676] microcode: CPU8: patch_level=0x0a601206
[ 1.869676] microcode: CPU0: patch_level=0x0a601206
[ 1.869679] microcode: CPU1: patch_level=0x0a601206
[ 1.869681] microcode: CPU2: patch_level=0x0a601206
[ 1.869682] microcode: CPU16: patch_level=0x0a601206
[ 1.869683] microcode: CPU17: patch_level=0x0a601206
[ 1.869683] microcode: CPU10: patch_level=0x0a601206
[ 1.869684] microcode: CPU5: patch_level=0x0a601206
[ 1.869683] microcode: CPU19: patch_level=0x0a601206
[ 1.869684] microcode: CPU18: patch_level=0x0a601206
[ 1.869684] microcode: CPU4: patch_level=0x0a601206
[ 1.869684] microcode: CPU21: patch_level=0x0a601206
[ 1.869684] microcode: CPU6: patch_level=0x0a601206
[ 1.869684] microcode: CPU11: patch_level=0x0a601206
[ 1.869684] microcode: CPU22: patch_level=0x0a601206
[ 1.869685] microcode: CPU12: patch_level=0x0a601206
[ 1.869686] microcode: CPU26: patch_level=0x0a601206
[ 1.869687] microcode: CPU13: patch_level=0x0a601206
[ 1.869686] microcode: CPU9: patch_level=0x0a601206
[ 1.869686] microcode: CPU23: patch_level=0x0a601206
[ 1.869684] microcode: CPU7: patch_level=0x0a601206
[ 1.869687] microcode: CPU24: patch_level=0x0a601206
[ 1.869688] microcode: CPU25: patch_level=0x0a601206
[ 1.869685] microcode: CPU3: patch_level=0x0a601206
[ 1.869688] microcode: CPU28: patch_level=0x0a601206
[ 1.869688] microcode: CPU14: patch_level=0x0a601206
[ 1.869690] microcode: CPU29: patch_level=0x0a601206
[ 1.869684] microcode: CPU20: patch_level=0x0a601206
[ 1.869689] microcode: CPU15: patch_level=0x0a601206
[ 1.869692] microcode: CPU30: patch_level=0x0a601206
[ 1.869690] microcode: CPU27: patch_level=0x0a601206
[ 1.869693] microcode: CPU31: patch_level=0x0a601206
[ 1.869743] microcode: Microcode Update Driver: v2.2.
[ 1.870329] resctrl: L3 allocation detected
[ 1.870330] resctrl: MB allocation detected
[ 1.870331] resctrl: SMBA allocation detected
[ 1.870332] resctrl: L3 monitoring detected
[ 1.870334] IPI shorthand broadcast: enabled
[ 1.871915] registered taskstats version 1
[ 1.873355] Loading compiled-in X.509 certificates
[ 1.875058] Loaded X.509 cert 'Build time autogenerated kernel key: 7a0a28026ef01e724ee848443586d5a11bdd20f9'
[ 1.877377] zswap: loaded using pool zstd/zsmalloc
[ 1.879294] Key type .fscrypt registered
[ 1.879295] Key type fscrypt-provisioning registered
[ 1.879626] PM: Magic number: 4:822:984
[ 1.879660] platform PNP0C14:01: hash matches
[ 1.879667] acpi PNP0C14:01: hash matches
[ 1.883158] RAS: Correctable Errors collector initialized.
[ 2.123952] ata1: SATA link down (SStatus 0 SControl 330)
[ 2.280705] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.282676] ata7.00: ATA-10: CT2000BX500SSD1, M6CR061, max UDMA/133
[ 2.284076] ata7.00: 3907029168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 2.289944] ata7.00: Features: Dev-Sleep
[ 2.301562] ata7.00: configured for UDMA/133
[ 2.437662] ata2: SATA link down (SStatus 0 SControl 330)
[ 2.751181] ata3: SATA link down (SStatus 0 SControl 330)
[ 3.064252] ata4: SATA link down (SStatus 0 SControl 330)
[ 3.064609] scsi 6:0:0:0: Direct-Access ATA CT2000BX500SSD1 061 PQ: 0 ANSI: 5
[ 3.065054] sd 6:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 3.065066] sd 6:0:0:0: [sda] Write Protect is off
[ 3.065069] sd 6:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.065085] sd 6:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.065107] sd 6:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 3.130046] sda: sda1
[ 3.130263] sd 6:0:0:0: [sda] Attached SCSI disk
[ 3.377734] ata8: SATA link down (SStatus 0 SControl 300)
[ 3.847375] ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 3.849337] ata9.00: supports DRM functions and may not be fully accessible
[ 3.849344] ata9.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT02B6Q, max UDMA/133
[ 3.849952] ata9.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 3.851958] ata9.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 3.852288] ata9.00: supports DRM functions and may not be fully accessible
[ 3.855078] ata9.00: configured for UDMA/133
[ 3.855293] scsi 8:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
[ 3.855670] sd 8:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 3.855682] sd 8:0:0:0: [sdb] Write Protect is off
[ 3.855685] sd 8:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3.855701] sd 8:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.855743] sd 8:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[ 3.857689] sdb: sdb1 sdb2 sdb3 sdb4
[ 3.858185] sd 8:0:0:0: [sdb] supports TCG Opal
[ 3.858186] sd 8:0:0:0: [sdb] Attached SCSI disk
[ 4.167714] ata10: SATA link down (SStatus 0 SControl 300)
[ 4.168034] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 4.170200] clk: Disabling unused clocks
[ 4.171578] Freeing unused decrypted memory: 2028K
[ 4.172006] Freeing unused kernel image (initmem) memory: 3444K
[ 4.172008] Write protecting the kernel read-only data: 32768k
[ 4.172560] Freeing unused kernel image (rodata/data gap) memory: 1236K
[ 4.201922] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 4.201926] rodata_test: all tests were successful
[ 4.201929] Run /init as init process
[ 4.201930] with arguments:
[ 4.201931] /init
[ 4.201932] with environment:
[ 4.201933] HOME=/
[ 4.201934] TERM=linux
[ 4.201934] BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
[ 4.201935] pcie_acs_override=downstream,multifunction
[ 4.228889] VFIO - User Level meta-driver version: 0.3
[ 4.242075] pcieport 0000:0a:04.0: bridge has subordinate 0c but max busn 0d
[ 4.242176] pci_bus 0000:04: Allocating resources
[ 4.300274] ccp 0000:15:00.2: enabling device (0000 -> 0002)
[ 4.310603] ccp 0000:15:00.2: tee enabled
[ 4.310791] ccp 0000:15:00.2: psp enabled
[ 4.322045] kvm_amd: TSC scaling supported
[ 4.322047] kvm_amd: Nested Virtualization enabled
[ 4.322047] kvm_amd: Nested Paging enabled
[ 4.322048] kvm_amd: LBR virtualization supported
[ 4.322052] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 4.322052] kvm_amd: Virtual GIF supported
[ 4.322053] kvm_amd: Virtual NMI enabled
[ 4.454798] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 4.455063] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/LNXVIDEO:00/input/input2
[ 4.462234] xhci_hcd 0000:10:00.0: xHCI Host Controller
[ 4.462240] xhci_hcd 0000:10:00.0: new USB bus registered, assigned bus number 1
[ 4.465202] nvme 0000:02:00.0: platform quirk: setting simple suspend
[ 4.465259] nvme nvme1: pci function 0000:02:00.0
[ 4.465259] nvme nvme0: pci function 0000:0f:00.0
[ 4.465287] nvme nvme2: pci function 0000:14:00.0
[ 4.470557] nvme nvme1: Shutdown timeout set to 10 seconds
[ 4.470861] nvme nvme2: missing or invalid SUBNQN field.
[ 4.471037] nvme nvme2: Shutdown timeout set to 8 seconds
[ 4.474058] nvme nvme1: 32/0/0 default/read/poll queues
[ 4.476708] nvme1n1: p1 p2
[ 4.498981] nvme nvme2: 32/0/0 default/read/poll queues
[ 4.503367] nvme2n1: p1 p2 p3
[ 4.518236] xhci_hcd 0000:10:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[ 4.518661] xhci_hcd 0000:10:00.0: xHCI Host Controller
[ 4.518664] xhci_hcd 0000:10:00.0: new USB bus registered, assigned bus number 2
[ 4.518665] xhci_hcd 0000:10:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 4.519234] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.519236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.519238] usb usb1: Product: xHCI Host Controller
[ 4.519239] usb usb1: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.519240] usb usb1: SerialNumber: 0000:10:00.0
[ 4.519339] hub 1-0:1.0: USB hub found
[ 4.519354] hub 1-0:1.0: 12 ports detected
[ 4.519593] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.519608] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.519610] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.519611] usb usb2: Product: xHCI Host Controller
[ 4.519612] usb usb2: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.519613] usb usb2: SerialNumber: 0000:10:00.0
[ 4.519687] hub 2-0:1.0: USB hub found
[ 4.519695] hub 2-0:1.0: 5 ports detected
[ 4.519860] xhci_hcd 0000:12:00.0: xHCI Host Controller
[ 4.519863] xhci_hcd 0000:12:00.0: new USB bus registered, assigned bus number 3
[ 4.575835] xhci_hcd 0000:12:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[ 4.576211] xhci_hcd 0000:12:00.0: xHCI Host Controller
[ 4.576213] xhci_hcd 0000:12:00.0: new USB bus registered, assigned bus number 4
[ 4.576215] xhci_hcd 0000:12:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 4.576827] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.576828] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.576830] usb usb3: Product: xHCI Host Controller
[ 4.576830] usb usb3: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.576831] usb usb3: SerialNumber: 0000:12:00.0
[ 4.576933] hub 3-0:1.0: USB hub found
[ 4.576944] hub 3-0:1.0: 12 ports detected
[ 4.584443] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.584458] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.584459] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.584460] usb usb4: Product: xHCI Host Controller
[ 4.584461] usb usb4: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.584462] usb usb4: SerialNumber: 0000:12:00.0
[ 4.584538] hub 4-0:1.0: USB hub found
[ 4.584545] hub 4-0:1.0: 5 ports detected
[ 4.587728] xhci_hcd 0000:15:00.3: xHCI Host Controller
[ 4.587730] xhci_hcd 0000:15:00.3: new USB bus registered, assigned bus number 5
[ 4.588075] xhci_hcd 0000:15:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000410
[ 4.588539] xhci_hcd 0000:15:00.3: xHCI Host Controller
[ 4.588541] xhci_hcd 0000:15:00.3: new USB bus registered, assigned bus number 6
[ 4.588543] xhci_hcd 0000:15:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.588566] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.588568] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.588569] usb usb5: Product: xHCI Host Controller
[ 4.588569] usb usb5: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.588570] usb usb5: SerialNumber: 0000:15:00.3
[ 4.588653] hub 5-0:1.0: USB hub found
[ 4.588657] hub 5-0:1.0: 2 ports detected
[ 4.589986] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.590005] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.590006] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.590007] usb usb6: Product: xHCI Host Controller
[ 4.590008] usb usb6: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.590009] usb usb6: SerialNumber: 0000:15:00.3
[ 4.590086] hub 6-0:1.0: USB hub found
[ 4.590090] hub 6-0:1.0: 2 ports detected
[ 4.591617] xhci_hcd 0000:15:00.4: xHCI Host Controller
[ 4.591620] xhci_hcd 0000:15:00.4: new USB bus registered, assigned bus number 7
[ 4.591961] xhci_hcd 0000:15:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000410
[ 4.592426] xhci_hcd 0000:15:00.4: xHCI Host Controller
[ 4.592428] xhci_hcd 0000:15:00.4: new USB bus registered, assigned bus number 8
[ 4.592429] xhci_hcd 0000:15:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.592451] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.592452] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.592453] usb usb7: Product: xHCI Host Controller
[ 4.592454] usb usb7: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.592455] usb usb7: SerialNumber: 0000:15:00.4
[ 4.592537] hub 7-0:1.0: USB hub found
[ 4.592540] hub 7-0:1.0: 2 ports detected
[ 4.593889] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.593903] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.593905] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.593906] usb usb8: Product: xHCI Host Controller
[ 4.593906] usb usb8: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.593907] usb usb8: SerialNumber: 0000:15:00.4
[ 4.593983] hub 8-0:1.0: USB hub found
[ 4.593987] hub 8-0:1.0: 2 ports detected
[ 4.595490] xhci_hcd 0000:16:00.0: xHCI Host Controller
[ 4.595493] xhci_hcd 0000:16:00.0: new USB bus registered, assigned bus number 9
[ 4.596759] xhci_hcd 0000:16:00.0: USB3 root hub has no ports
[ 4.596761] xhci_hcd 0000:16:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000410
[ 4.597249] xhci_hcd 0000:16:00.0: xHCI Host Controller
[ 4.597251] xhci_hcd 0000:16:00.0: new USB bus registered, assigned bus number 10
[ 4.597252] xhci_hcd 0000:16:00.0: Host supports USB 3.0 SuperSpeed
[ 4.597278] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 4.597279] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.597280] usb usb9: Product: xHCI Host Controller
[ 4.597281] usb usb9: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.597282] usb usb9: SerialNumber: 0000:16:00.0
[ 4.597361] hub 9-0:1.0: USB hub found
[ 4.597365] hub 9-0:1.0: 1 port detected
[ 4.598054] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.598068] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 4.598070] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.598071] usb usb10: Product: xHCI Host Controller
[ 4.598071] usb usb10: Manufacturer: Linux 6.6.44-1-MANJARO xhci-hcd
[ 4.598072] usb usb10: SerialNumber: 0000:16:00.0
[ 4.598144] hub 10-0:1.0: USB hub found
[ 4.598147] hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 4.834031] usb 1-9: new full-speed USB device number 2 using xhci_hcd
[ 4.847340] usb 9-1: new high-speed USB device number 2 using xhci_hcd
[ 4.900454] usb 3-5: new high-speed USB device number 2 using xhci_hcd
[ 4.990851] usb 9-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 4.990857] usb 9-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.990859] usb 9-1: Product: USB2.0 Hub
[ 5.046385] hub 9-1:1.0: USB hub found
[ 5.046972] hub 9-1:1.0: 4 ports detected
[ 5.140792] usb 3-5: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 2.01
[ 5.140798] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.140800] usb 3-5: Product: USB2.1 Hub
[ 5.140802] usb 3-5: Manufacturer: Generic
[ 5.149595] hub 3-5:1.0: USB hub found
[ 5.152751] hub 3-5:1.0: 4 ports detected
[ 5.227871] usb 1-9: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
[ 5.227879] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.245152] usb 4-5: new SuperSpeed USB device number 2 using xhci_hcd
[ 5.271351] usb 4-5: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 2.01
[ 5.271356] usb 4-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.271357] usb 4-5: Product: USB3.2 Hub
[ 5.271359] usb 4-5: Manufacturer: Generic
[ 5.279491] hub 4-5:1.0: USB hub found
[ 5.280737] hub 4-5:1.0: 4 ports detected
[ 5.330709] usb 9-1.2: new high-speed USB device number 3 using xhci_hcd
[ 5.425957] usb 9-1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 5.425963] usb 9-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.425965] usb 9-1.2: Product: USB2.1 Hub
[ 5.425967] usb 9-1.2: Manufacturer: GenesysLogic
[ 5.454120] usb 3-6: new full-speed USB device number 3 using xhci_hcd
[ 5.462189] hub 9-1.2:1.0: USB hub found
[ 5.462754] hub 9-1.2:1.0: 4 ports detected
[ 5.770480] usb 9-1.2.1: new high-speed USB device number 4 using xhci_hcd
[ 5.827393] usb 3-5.4: new high-speed USB device number 4 using xhci_hcd
[ 5.853606] usb 3-6: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
[ 5.853615] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.853618] usb 3-6: Product: ITE Device
[ 5.853619] usb 3-6: Manufacturer: ITE Tech. Inc.
[ 5.889067] usb 9-1.2.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 5.889075] usb 9-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.889077] usb 9-1.2.1: Product: USB2.1 Hub
[ 5.889079] usb 9-1.2.1: Manufacturer: GenesysLogic
[ 5.941745] hub 9-1.2.1:1.0: USB hub found
[ 5.942239] hub 9-1.2.1:1.0: 4 ports detected
[ 5.955055] usb 3-5.4: config 1 interface 2 altsetting 0 bulk endpoint 0x82 has invalid maxpacket 256
[ 5.966822] usb 3-5.4: New USB device found, idVendor=041e, idProduct=3265, bcdDevice=10.10
[ 5.966831] usb 3-5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=7
[ 5.966833] usb 3-5.4: Product: Sound Blaster X5
[ 5.966835] usb 3-5.4: Manufacturer: Creative Technology Ltd
[ 5.966836] usb 3-5.4: SerialNumber: 9BE3ADD73F9BB8AD
[ 6.044045] usb 9-1.2.2: new full-speed USB device number 5 using xhci_hcd
[ 6.127410] usb 3-12: new high-speed USB device number 5 using xhci_hcd
[ 6.180308] usb 9-1.2.2: New USB device found, idVendor=0b95, idProduct=6804, bcdDevice= 0.12
[ 6.180316] usb 9-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.180319] usb 9-1.2.2: Product: AX68004
[ 6.180320] usb 9-1.2.2: Manufacturer: ASIX Electronics
[ 6.180322] usb 9-1.2.2: SerialNumber: 00000003
[ 6.230619] hub 9-1.2.2:1.0: USB hub found
[ 6.233267] hub 9-1.2.2:1.0: 7 ports detected
[ 6.260718] usb 9-1.2.1.1: new high-speed USB device number 6 using xhci_hcd
[ 6.370793] usb 3-12: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
[ 6.370799] usb 3-12: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.370801] usb 3-12: Product: 4-Port USB 2.0 Hub
[ 6.370803] usb 3-12: Manufacturer: Generic
[ 6.379073] usb 9-1.2.1.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 6.379077] usb 9-1.2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.379079] usb 9-1.2.1.1: Product: USB2.1 Hub
[ 6.379080] usb 9-1.2.1.1: Manufacturer: GenesysLogic
[ 6.381165] hub 3-12:1.0: USB hub found
[ 6.384763] hub 3-12:1.0: 4 ports detected
[ 6.421564] hub 9-1.2.1.1:1.0: USB hub found
[ 6.422099] hub 9-1.2.1.1:1.0: 4 ports detected
[ 6.470716] usb 9-1.2.3: new high-speed USB device number 7 using xhci_hcd
[ 6.591454] usb 9-1.2.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 6.591460] usb 9-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 6.591462] usb 9-1.2.3: Product: USB 10/100/1000 LAN
[ 6.591464] usb 9-1.2.3: Manufacturer: Realtek
[ 6.591465] usb 9-1.2.3: SerialNumber: 001000001
[ 6.684050] usb 9-1.2.1.2: new high-speed USB device number 8 using xhci_hcd
[ 6.727155] usb 3-12.1: new high-speed USB device number 6 using xhci_hcd
[ 6.803106] usb 9-1.2.1.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[ 6.803115] usb 9-1.2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.803117] usb 9-1.2.1.2: Product: USB2.1 Hub
[ 6.803119] usb 9-1.2.1.2: Manufacturer: GenesysLogic
[ 6.838065] hub 9-1.2.1.2:1.0: USB hub found
[ 6.838605] hub 9-1.2.1.2:1.0: 4 ports detected
[ 6.877447] usb 9-1.2.2.1: new full-speed USB device number 9 using xhci_hcd
[ 6.996264] usb 9-1.2.2.1: New USB device found, idVendor=feed, idProduct=1225, bcdDevice= 0.01
[ 6.996271] usb 9-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.996273] usb 9-1.2.2.1: Product: KNIGHT
[ 6.996274] usb 9-1.2.2.1: Manufacturer: X-BOWS
[ 7.070727] usb 9-1.2.1.1.1: new full-speed USB device number 10 using xhci_hcd
[ 7.207297] usb 9-1.2.1.1.1: New USB device found, idVendor=1e7d, idProduct=afca, bcdDevice= 1.07
[ 7.207306] usb 9-1.2.1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.207309] usb 9-1.2.1.1.1: Product: ROCCAT Kone Air
[ 7.207310] usb 9-1.2.1.1.1: Manufacturer: ROCCAT
[ 7.207312] usb 9-1.2.1.1.1: SerialNumber: 000000000000
[ 7.268423] nvme nvme0: 15/0/0 default/read/poll queues
[ 7.284052] usb 9-1.2.4: new full-speed USB device number 11 using xhci_hcd
[ 7.444275] usb 9-1.2.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 7.444283] usb 9-1.2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 7.444285] usb 9-1.2.4: Product: USB Serial
[ 7.469760] nvme nvme0: Ignoring bogus Namespace Identifiers
[ 7.471524] nvme0n1: p1 p2
[ 7.484380] hid-generic 0003:048D:5702.0001: hiddev96,hidraw0: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:12:00.0-6/input0
[ 7.492837] input: Creative Technology Ltd Sound Blaster X5 as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-5/3-5.4/3-5.4:1.0/0003:041E:3265.0002/input/input3
[ 7.510419] usb 9-1.2.2.6: new full-speed USB device number 12 using xhci_hcd
[ 7.547167] hid-generic 0003:041E:3265.0002: input,hidraw1: USB HID v1.10 Device [Creative Technology Ltd Sound Blaster X5] on usb-0000:12:00.0-5.4/input0
[ 7.551312] input: X-BOWS KNIGHT as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.0/0003:FEED:1225.0003/input/input4
[ 7.607253] hid-generic 0003:FEED:1225.0003: input,hidraw2: USB HID v1.11 Keyboard [X-BOWS KNIGHT] on usb-0000:16:00.0-1.2.2.1/input0
[ 7.614364] input: X-BOWS KNIGHT Mouse as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEED:1225.0004/input/input5
[ 7.614427] input: X-BOWS KNIGHT System Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEED:1225.0004/input/input6
[ 7.627211] usb 9-1.2.2.6: New USB device found, idVendor=0b95, idProduct=6801, bcdDevice= 0.02
[ 7.627216] usb 9-1.2.2.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.627218] usb 9-1.2.2.6: Product: AX68004
[ 7.627220] usb 9-1.2.2.6: Manufacturer: ASIX Electronics
[ 7.627222] usb 9-1.2.2.6: SerialNumber: 00000003
[ 7.670542] input: X-BOWS KNIGHT Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEED:1225.0004/input/input7
[ 7.670630] input: X-BOWS KNIGHT Keyboard as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.1/9-1.2.2.1:1.1/0003:FEED:1225.0004/input/input8
[ 7.670850] hid-generic 0003:FEED:1225.0004: input,hidraw3: USB HID v1.11 Mouse [X-BOWS KNIGHT] on usb-0000:16:00.0-1.2.2.1/input1
[ 7.677343] input: ROCCAT ROCCAT Kone Air as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.1/9-1.2.1.1.1:1.0/0003:1E7D:AFCA.0005/input/input9
[ 7.677433] hid-generic 0003:1E7D:AFCA.0005: input,hidraw4: USB HID v1.11 Mouse [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input0
[ 7.685415] input: ROCCAT ROCCAT Kone Air Keyboard as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.1/9-1.2.1.1.1:1.1/0003:1E7D:AFCA.0006/input/input10
[ 7.703756] usb 9-1.2.1.1.4: new full-speed USB device number 13 using xhci_hcd
[ 7.710378] input: ASIX Electronics AX68004 as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.0/0003:0B95:6801.0007/input/input12
[ 7.740507] input: ROCCAT ROCCAT Kone Air as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.1/9-1.2.1.1.1:1.1/0003:1E7D:AFCA.0006/input/input11
[ 7.797304] hid-generic 0003:0B95:6801.0007: input,hidraw5: USB HID v1.10 Keyboard [ASIX Electronics AX68004] on usb-0000:16:00.0-1.2.2.6/input0
[ 7.797444] hid-generic 0003:1E7D:AFCA.0006: input,hiddev97,hidraw6: USB HID v1.11 Keyboard [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input1
[ 7.804472] hid-generic 0003:1E7D:AFCA.0008: hiddev98,hidraw7: USB HID v1.11 Device [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input2
[ 7.805408] input: ASIX Electronics AX68004 as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.1/0003:0B95:6801.0009/input/input13
[ 7.805487] input: ASIX Electronics AX68004 System Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.1/0003:0B95:6801.0009/input/input14
[ 7.812443] hid-generic 0003:1E7D:AFCA.000A: hiddev99,hidraw8: USB HID v1.11 Device [ROCCAT ROCCAT Kone Air] on usb-0000:16:00.0-1.2.1.1.1/input3
[ 7.837235] usb 9-1.2.1.1.4: New USB device found, idVendor=31b2, idProduct=0011, bcdDevice= 1.00
[ 7.837239] usb 9-1.2.1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.837241] usb 9-1.2.1.1.4: Product: USB_Audio_Device
[ 7.837243] usb 9-1.2.1.1.4: Manufacturer: KTMicro
[ 7.837245] usb 9-1.2.1.1.4: SerialNumber: 214b206000000178
[ 7.860535] input: ASIX Electronics AX68004 Consumer Control as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.2/9-1.2.2.6/9-1.2.2.6:1.1/0003:0B95:6801.0009/input/input15
[ 7.860624] hid-generic 0003:0B95:6801.0009: input,hidraw9: USB HID v1.10 Mouse [ASIX Electronics AX68004] on usb-0000:16:00.0-1.2.2.6/input1
[ 7.860702] usbcore: registered new interface driver usbhid
[ 7.860706] usbhid: USB HID core driver
[ 7.934336] input: KTMicro USB_Audio_Device as /devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2.1/9-1.2.1.1/9-1.2.1.1.4/9-1.2.1.1.4:1.3/0003:31B2:0011.000B/input/input16
[ 7.990495] hid-generic 0003:31B2:0011.000B: input,hidraw10: USB HID v1.10 Device [KTMicro USB_Audio_Device] on usb-0000:16:00.0-1.2.1.1.4/input3
[ 8.341675] [drm] amdgpu kernel modesetting enabled.
[ 8.341694] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 8.341845] amdgpu: ATPX version 1, functions 0x00000000
[ 8.350994] amdgpu: Virtual CRAT table created for CPU
[ 8.351002] amdgpu: Topology: Add CPU node
[ 8.351072] amdgpu 0000:15:00.0: enabling device (0006 -> 0007)
[ 8.351102] [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x164E 0x1458:0xD000 0xC9).
[ 8.351109] [drm] register mmio base: 0xF6300000
[ 8.351110] [drm] register mmio size: 524288
[ 8.352419] [drm] add ip block number 0 <nv_common>
[ 8.352420] [drm] add ip block number 1 <gmc_v10_0>
[ 8.352421] [drm] add ip block number 2 <navi10_ih>
[ 8.352422] [drm] add ip block number 3 <psp>
[ 8.352422] [drm] add ip block number 4 <smu>
[ 8.352423] [drm] add ip block number 5 <dm>
[ 8.352423] [drm] add ip block number 6 <gfx_v10_0>
[ 8.352424] [drm] add ip block number 7 <sdma_v5_2>
[ 8.352425] [drm] add ip block number 8 <vcn_v3_0>
[ 8.352425] [drm] add ip block number 9 <jpeg_v3_0>
[ 8.352430] amdgpu 0000:15:00.0: amdgpu: Fetched VBIOS from VFCT
[ 8.352431] amdgpu: ATOM BIOS: 102-RAPHAEL-008
[ 8.356679] [drm] VCN(0) decode is enabled in VM mode
[ 8.356680] [drm] VCN(0) encode is enabled in VM mode
[ 8.357920] [drm] JPEG decode is enabled in VM mode
[ 8.370504] Console: switching to colour dummy device 80x25
[ 8.398564] amdgpu 0000:15:00.0: vgaarb: deactivate vga console
[ 8.398569] amdgpu 0000:15:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 8.398596] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 8.398601] amdgpu 0000:15:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[ 8.398602] amdgpu 0000:15:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 8.398604] amdgpu 0000:15:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 8.398608] [drm] Detected VRAM RAM=512M, BAR=512M
[ 8.398609] [drm] RAM width 128bits DDR5
[ 8.398789] [drm] amdgpu: 512M of VRAM memory ready
[ 8.398792] [drm] amdgpu: 31623M of GTT memory ready.
[ 8.398811] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 8.398919] [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
[ 8.399083] [drm] Loading DMUB firmware via PSP: version=0x05001900
[ 8.399502] [drm] use_doorbell being set to: [true]
[ 8.399518] [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 2
[ 8.399523] amdgpu 0000:15:00.0: amdgpu: Will use PSP to load VCN firmware
[ 8.421487] [drm] reserve 0xa00000 from 0xf41e000000 for PSP TMR
[ 8.489313] amdgpu 0000:15:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 8.495022] amdgpu 0000:15:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 8.495023] amdgpu 0000:15:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 8.496532] amdgpu 0000:15:00.0: amdgpu: SMU is initialized successfully!
[ 8.496733] [drm] Display Core v3.2.247 initialized on DCN 3.1.5
[ 8.496735] [drm] DP-HDMI FRL PCON supported
[ 8.497498] [drm] DMUB hardware initialized: version=0x05001900
[ 8.561444] ------------[ cut here ]------------
[ 8.561445] WARNING: CPU: 18 PID: 407 at drivers/gpu/drm/amd/amdgpu/../display/dc/link/protocols/link_dp_capability.c:1526 dp_retrieve_lttpr_cap+0x16f/0x1a0 [amdgpu]
[ 8.561675] Modules linked in: amdgpu(+) i2c_algo_bit drm_ttm_helper ttm drm_exec drm_suballoc_helper amdxcp drm_buddy usbhid gpu_sched drm_display_helper crc32c_intel nvme cec xhci_pci nvme_core xhci_pci_renesas nvme_common video wmi kvm_amd ccp kvm vfio_pci vfio_pci_core vfio_iommu_type1 vfio iommufd irqbypass
[ 8.561693] CPU: 18 PID: 407 Comm: (udev-worker) Not tainted 6.6.44-1-MANJARO #1 8598aea1d868f10d66f5d5ae2b57b59e735cd775
[ 8.561695] Hardware name: Gigabyte Technology Co., Ltd. X670E AORUS MASTER/X670E AORUS MASTER, BIOS F30 05/22/2024
[ 8.561696] RIP: 0010:dp_retrieve_lttpr_cap+0x16f/0x1a0 [amdgpu]
[ 8.561847] Code: 04 25 28 00 00 00 75 45 48 83 c4 10 89 d8 5b 5d e9 91 d1 ee e5 48 c7 c2 44 ee 02 c1 be 02 00 00 00 31 ff e8 23 4a 70 e5 eb b7 <0f> 0b c6 85 9c 02 00 00 80 b9 80 00 00 00 48 c7 c2 48 68 00 c1 31
[ 8.561848] RSP: 0018:ffffc90006d6f5c8 EFLAGS: 00010246
[ 8.561849] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 00ffffffffffffff
[ 8.561850] RDX: 0000000000000007 RSI: ffff88890296f0c0 RDI: 0000000000000000
[ 8.561851] RBP: ffff88890ad1b800 R08: ffff88891d88c040 R09: 00000000000f0000
[ 8.561852] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000001
[ 8.561853] R13: 0000000000000020 R14: 0000000000000000 R15: ffff888904d3c240
[ 8.561854] FS: 00007fbfa88ad880(0000) GS:ffff888ffe680000(0000) knlGS:0000000000000000
[ 8.561855] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 8.561856] CR2: 000056234f79f5b8 CR3: 000000091459c000 CR4: 0000000000f50ee0
[ 8.561857] PKRU: 55555554
[ 8.561857] Call Trace:
[ 8.561859] <TASK>
[ 8.561860] ? dp_retrieve_lttpr_cap+0x16f/0x1a0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.561995] ? __warn+0x81/0x140
[ 8.561998] ? dp_retrieve_lttpr_cap+0x16f/0x1a0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562128] ? report_bug+0x16f/0x1a0
[ 8.562131] ? handle_bug+0x3c/0x80
[ 8.562133] ? exc_invalid_op+0x17/0x70
[ 8.562135] ? asm_exc_invalid_op+0x1a/0x20
[ 8.562138] ? dp_retrieve_lttpr_cap+0x16f/0x1a0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562267] ? dp_retrieve_lttpr_cap+0x114/0x1a0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562394] retrieve_link_cap+0x7b/0xbb0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562522] ? dal_gpio_close+0x1e/0x30 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562689] detect_link_and_local_sink+0xb09/0xf80 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.562858] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.562860] link_detect+0x37/0x4a0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563005] ? dal_gpio_destroy_irq+0x25/0x40 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563156] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.563158] ? query_hpd_status+0x6e/0xa0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563316] amdgpu_dm_init.isra.0+0xf28/0x1df0 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563478] ? __pfx_enable_assr+0x10/0x10 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563625] ? __pfx_update_config+0x10/0x10 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563780] dm_hw_init+0x12/0x30 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.563927] amdgpu_device_init+0x1dbe/0x2390 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.564039] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564042] amdgpu_driver_load_kms+0x19/0x190 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.564153] amdgpu_pci_probe+0x156/0x460 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.564267] local_pci_probe+0x42/0xa0
[ 8.564270] pci_device_probe+0xbd/0x2a0
[ 8.564271] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564273] ? sysfs_do_create_link_sd+0x6e/0xe0
[ 8.564275] really_probe+0x19b/0x3e0
[ 8.564278] ? __pfx___driver_attach+0x10/0x10
[ 8.564279] __driver_probe_device+0x78/0x160
[ 8.564281] driver_probe_device+0x1f/0xa0
[ 8.564282] __driver_attach+0xba/0x1c0
[ 8.564284] bus_for_each_dev+0x8c/0xe0
[ 8.564286] bus_add_driver+0x112/0x240
[ 8.564288] driver_register+0x5c/0x100
[ 8.564290] ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 19a831b488cd245788879290e079e1a7dbff8356]
[ 8.564401] do_one_initcall+0x5a/0x320
[ 8.564404] do_init_module+0x60/0x240
[ 8.564407] init_module_from_file+0x89/0xe0
[ 8.564411] idempotent_init_module+0x121/0x2b0
[ 8.564414] __x64_sys_finit_module+0x5e/0xb0
[ 8.564416] do_syscall_64+0x5a/0x80
[ 8.564418] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564419] ? syscall_exit_to_user_mode+0x22/0x40
[ 8.564421] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564422] ? do_syscall_64+0x66/0x80
[ 8.564424] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564425] ? syscall_exit_to_user_mode+0x22/0x40
[ 8.564426] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.564428] ? do_syscall_64+0x66/0x80
[ 8.564429] entry_SYSCALL_64_after_hwframe+0x78/0xe2
[ 8.564431] RIP: 0033:0x7fbfa90841fd
[ 8.564436] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e3 fa 0c 00 f7 d8 64 89 01 48
[ 8.564437] RSP: 002b:00007ffc91869df8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 8.564439] RAX: ffffffffffffffda RBX: 000056234f78c8a0 RCX: 00007fbfa90841fd
[ 8.564439] RDX: 0000000000000004 RSI: 00007fbfa88a7376 RDI: 0000000000000029
[ 8.564440] RBP: 00007fbfa88a7376 R08: 0000000000000001 R09: 00007ffc91869e40
[ 8.564441] R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
[ 8.564442] R13: 000056234f784a10 R14: 0000000000000000 R15: 000056234f7a9910
[ 8.564445] </TASK>
[ 8.564445] ---[ end trace 0000000000000000 ]---
[ 8.787835] [drm] kiq ring mec 2 pipe 1 q 0
[ 8.789838] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 8.789863] [drm] JPEG decode initialized successfully.
[ 8.805535] amdgpu: HMM registered 512MB device memory
[ 8.806658] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 8.806671] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 8.806815] amdgpu: Virtual CRAT table created for GPU
[ 8.807487] amdgpu: Topology: Add dGPU node [0x164e:0x1002]
[ 8.807491] kfd kfd: amdgpu: added device 1002:164e
[ 8.807499] amdgpu 0000:15:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 8.807635] amdgpu 0000:15:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 8.807638] amdgpu 0000:15:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 8.807640] amdgpu 0000:15:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 8.807642] amdgpu 0000:15:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 8.807644] amdgpu 0000:15:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 8.807646] amdgpu 0000:15:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 8.807648] amdgpu 0000:15:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 8.807650] amdgpu 0000:15:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 8.807652] amdgpu 0000:15:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 8.807655] amdgpu 0000:15:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 11 on hub 0
[ 8.807657] amdgpu 0000:15:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 8.807659] amdgpu 0000:15:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[ 8.807661] amdgpu 0000:15:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[ 8.807663] amdgpu 0000:15:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[ 8.807665] amdgpu 0000:15:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[ 8.808381] [drm] Initialized amdgpu 3.54.0 20150101 for 0000:15:00.0 on minor 1
[ 8.816012] fbcon: amdgpudrmfb (fb0) is primary device
[ 8.816190] [drm] DSC precompute is not needed.
[ 9.034642] [drm] REG_WAIT timeout 1us * 100000 tries - optc31_disable_crtc line:136
[ 9.191771] usb 3-12.1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
[ 9.191774] usb 3-12.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 9.191775] usb 3-12.1: Product: HD Pro Webcam C920
[ 9.191776] usb 3-12.1: SerialNumber: DBEEDE1F
[ 9.300429] usb 3-12.3: new full-speed USB device number 7 using xhci_hcd
[ 9.345228] Console: switching to colour frame buffer device 160x45
[ 9.364161] amdgpu 0000:15:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 9.619858] usb 3-12.3: New USB device found, idVendor=1e7d, idProduct=2cb6, bcdDevice= 1.07
[ 9.619868] usb 3-12.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.619870] usb 3-12.3: Product: ROCCAT Kone XP Air Dongle
[ 9.619872] usb 3-12.3: Manufacturer: ROCCAT
[ 9.619874] usb 3-12.3: SerialNumber: 682E4ED09317C911
[ 9.689217] input: ROCCAT ROCCAT Kone XP Air Dongle as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3-12.3:1.0/0003:1E7D:2CB6.000C/input/input17
[ 9.689333] hid-generic 0003:1E7D:2CB6.000C: input,hidraw11: USB HID v1.10 Mouse [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0-12.3/input0
[ 9.708211] input: ROCCAT ROCCAT Kone XP Air Dongle as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3-12.3:1.1/0003:1E7D:2CB6.000D/input/input18
[ 9.764156] hid-generic 0003:1E7D:2CB6.000D: input,hidraw12: USB HID v1.10 Keyboard [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0-12.3/input1
[ 9.783435] input: ROCCAT ROCCAT Kone XP Air Dongle System Control as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3-12.3:1.2/0003:1E7D:2CB6.000E/input/input19
[ 9.837319] input: ROCCAT ROCCAT Kone XP Air Dongle Consumer Control as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3-12.3:1.2/0003:1E7D:2CB6.000E/input/input20
[ 9.837430] input: ROCCAT ROCCAT Kone XP Air Dongle as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:12:00.0/usb3/3-12/3-12.3/3-12.3:1.2/0003:1E7D:2CB6.000E/input/input21
[ 9.837577] hid-generic 0003:1E7D:2CB6.000E: input,hiddev100,hidraw13: USB HID v1.10 Device [ROCCAT ROCCAT Kone XP Air Dongle] on usb-0000:12:00.0-12.3/input2
[ 9.920733] usb 3-12.4: new high-speed USB device number 8 using xhci_hcd
[ 10.052862] usb 3-12.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
[ 10.052872] usb 3-12.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.052874] usb 3-12.4: Product: 4-Port USB 2.0 Hub
[ 10.052876] usb 3-12.4: Manufacturer: Generic
[ 10.064954] hub 3-12.4:1.0: USB hub found
[ 10.068861] hub 3-12.4:1.0: 4 ports detected
[ 10.184429] PM: Image not found (code -22)
[ 10.400422] usb 3-12.4.1: new high-speed USB device number 9 using xhci_hcd
[ 10.528796] usb 3-12.4.1: New USB device found, idVendor=0bda, idProduct=5409, bcdDevice= 0.06
[ 10.528800] usb 3-12.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.528802] usb 3-12.4.1: Product: USB2.1 Hub
[ 10.528803] usb 3-12.4.1: Manufacturer: Generic
[ 10.540810] hub 3-12.4.1:1.0: USB hub found
[ 10.543773] hub 3-12.4.1:1.0: 5 ports detected
[ 10.720923] EXT4-fs (nvme2n1p2): 4 orphan inodes deleted
[ 10.720927] EXT4-fs (nvme2n1p2): recovery complete
[ 10.728291] EXT4-fs (nvme2n1p2): mounted filesystem 7f121955-19f8-4849-a149-173dc55e9395 r/w with ordered data mode. Quota mode: none.
[ 10.803871] systemd[1]: systemd 256.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 10.803877] systemd[1]: Detected architecture x86-64.
[ 10.804624] systemd[1]: Hostname set to <wizzy-manjaro-kde6>.
[ 10.866724] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 10.883760] usb 3-12.4.1.5: new high-speed USB device number 10 using xhci_hcd
[ 11.008833] usb 3-12.4.1.5: New USB device found, idVendor=187c, idProduct=100e, bcdDevice= 1.01
[ 11.008838] usb 3-12.4.1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.008840] usb 3-12.4.1.5: Product: HID Device
[ 11.008841] usb 3-12.4.1.5: Manufacturer: Realtek
[ 11.028442] hid-generic 0003:187C:100E.000F: hiddev101,hidraw14: USB HID v1.11 Device [Realtek HID Device] on usb-0000:12:00.0-12.4.1.5/input0
[ 11.234374] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 11.379449] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.428475] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 11.429046] systemd[1]: Created slice Slice /system/dirmngr.
[ 11.429329] systemd[1]: Created slice Slice /system/getty.
[ 11.429599] systemd[1]: Created slice Slice /system/gpg-agent.
[ 11.429846] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 11.430076] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 11.430310] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 11.430538] systemd[1]: Created slice Slice /system/keyboxd.
[ 11.430776] systemd[1]: Created slice Slice /system/modprobe.
[ 11.431007] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 11.431182] systemd[1]: Created slice User and Session Slice.
[ 11.431239] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.431381] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.431404] systemd[1]: Expecting device /dev/disk/by-uuid/49D2-9C89...
[ 11.431491] systemd[1]: Expecting device /dev/disk/by-uuid/54cbc6e5-f67c-4410-9d37-8f9df49aadb4...
[ 11.431531] systemd[1]: Expecting device /dev/disk/by-uuid/55eb965d-0e06-44e5-8d57-876cb155362d...
[ 11.431579] systemd[1]: Expecting device /dev/disk/by-uuid/e709cf55-e838-42dd-800f-7219b6b9e3a5...
[ 11.431636] systemd[1]: Reached target Login Prompts.
[ 11.431683] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 11.431721] systemd[1]: Reached target Slice Units.
[ 11.431757] systemd[1]: Reached target Local Verity Protected Volumes.
[ 11.431831] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.431919] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.432802] systemd[1]: Listening on Process Core Dump Socket.
[ 11.433250] systemd[1]: Listening on Credential Encryption/Decryption.
[ 11.433331] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.433399] systemd[1]: Listening on Journal Sockets.
[ 11.433433] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 11.433445] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 11.433511] systemd[1]: Listening on udev Control Socket.
[ 11.433555] systemd[1]: Listening on udev Kernel Socket.
[ 11.433601] systemd[1]: Listening on User Database Manager Socket.
[ 11.434367] systemd[1]: Mounting Huge Pages File System...
[ 11.434801] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.435286] systemd[1]: Mounting Kernel Debug File System...
[ 11.435742] systemd[1]: Mounting Kernel Trace File System...
[ 11.436349] systemd[1]: Starting Create List of Static Device Nodes...
[ 11.436846] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 11.437386] systemd[1]: Starting Load Kernel Module configfs...
[ 11.437912] systemd[1]: Starting Load Kernel Module dm_mod...
[ 11.438423] systemd[1]: Starting Load Kernel Module drm...
[ 11.439014] systemd[1]: Starting Load Kernel Module fuse...
[ 11.439509] systemd[1]: Starting Load Kernel Module loop...
[ 11.439567] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 11.439593] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 11.440688] systemd[1]: Starting Journal Service...
[ 11.441508] systemd[1]: Starting Load Kernel Modules...
[ 11.441528] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 11.441972] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.442010] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 11.442483] systemd[1]: Starting Load udev Rules from Credentials...
[ 11.442919] systemd[1]: Starting Coldplug All udev Devices...
[ 11.443361] systemd[1]: Starting Virtual Console Setup...
[ 11.444656] systemd[1]: Mounted Huge Pages File System.
[ 11.444730] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.445372] systemd[1]: Mounted Kernel Debug File System.
[ 11.445742] systemd[1]: Mounted Kernel Trace File System.
[ 11.445769] loop: module loaded
[ 11.450211] device-mapper: uevent: version 1.0.3
[ 11.450320] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 11.450770] systemd-journald[602]: Collecting audit messages is disabled.
[ 11.451136] fuse: init (API version 7.39)
[ 11.454174] i2c_dev: i2c /dev entries driver
[ 11.494062] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.494757] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 11.507320] EXT4-fs (nvme2n1p2): re-mounted 7f121955-19f8-4849-a149-173dc55e9395 r/w. Quota mode: none.
[ 11.520617] systemd[1]: Finished Load Kernel Module configfs.
[ 11.521400] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 11.540622] systemd[1]: Finished Load Kernel Module dm_mod.
[ 11.540746] systemd[1]: Started Journal Service.
[ 11.820444] systemd-journald[602]: Received client request to flush runtime journal.
[ 12.275474] raid6: skipped pq benchmark and selected avx512x4
[ 12.275478] raid6: using avx512x2 recovery algorithm
[ 12.279442] xor: automatically using best checksumming function avx
[ 12.288194] mousedev: PS/2 mouse device common for all mice
[ 12.304110] dca service started, version 1.12.1
[ 12.306902] Intel(R) 2.5G Ethernet Linux Driver
[ 12.306904] Copyright(c) 2018 Intel Corporation.
[ 12.307528] cdc_acm 3-5.4:1.1: ttyACM0: USB ACM device
[ 12.307752] igc 0000:0d:00.0: PCIe PTM not supported by PCIe bus/controller
[ 12.308775] usbcore: registered new interface driver cdc_acm
[ 12.308776] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 12.357597] pps pps0: new PPS source ptp0
[ 12.357713] igc 0000:0d:00.0 (unnamed net_device) (uninitialized): PHC added
[ 12.384204] igc 0000:0d:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 12.384208] igc 0000:0d:00.0 eth0: MAC: 74:56:3c:4b:74:7e
[ 12.419291] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20230628/utaddress-204)
[ 12.419298] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 12.419384] mc: Linux media interface: v0.10
[ 12.419431] igb: Intel(R) Gigabit Ethernet Network Driver
[ 12.419433] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 12.419515] igb 0000:0c:00.0: enabling device (0000 -> 0002)
[ 12.419805] input: PC Speaker as /devices/platform/pcspkr/input/input22
[ 12.420683] gigabyte-wmi DEADBEEF-2001-0000-00A0-C90629100000: No temperature sensors usable
[ 12.421174] Btrfs loaded, zoned=yes, fsverity=yes
[ 12.426340] Adding 9227464k swap on /dev/nvme2n1p3. Priority:-2 extents:1 across:9227464k SS
[ 12.428763] igc 0000:0d:00.0 enp13s0: renamed from eth0
[ 12.429896] vfio-pci 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=none
[ 12.443785] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 12.443787] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 12.471065] BTRFS: device label Timeshift devid 1 transid 7137 /dev/nvme0n1p1 scanned by (udev-worker) (674)
[ 12.471775] usbcore: registered new interface driver ch341
[ 12.472159] usbserial: USB Serial support registered for ch341-uart
[ 12.472342] ch341 9-1.2.4:1.0: ch341-uart converter detected
[ 12.480696] Bluetooth: Core ver 2.22
[ 12.480708] NET: Registered PF_BLUETOOTH protocol family
[ 12.480710] Bluetooth: HCI device and connection manager initialized
[ 12.480712] Bluetooth: HCI socket layer initialized
[ 12.480714] Bluetooth: L2CAP socket layer initialized
[ 12.480720] Bluetooth: SCO socket layer initialized
[ 12.482190] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 12.482222] cryptd: max_cpu_qlen set to 1000
[ 12.482383] usbcore: registered new device driver r8152-cfgselector
[ 12.482581] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 12.483133] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 12.485265] usb 9-1.2.4: ch341-uart converter now attached to ttyUSB0
[ 12.488746] AVX2 version of gcm_enc/dec engaged.
[ 12.488838] AES CTR mode by8 optimization enabled
[ 12.490880] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.491068] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.491193] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 12.495532] videodev: Linux video capture interface: v2.00
[ 12.505124] Intel(R) Wireless WiFi driver for Linux
[ 12.505166] iwlwifi 0000:0e:00.0: enabling device (0000 -> 0002)
[ 12.505203] usbcore: registered new interface driver btusb
[ 12.506624] iwlwifi 0000:0e:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 12.506631] iwlwifi 0000:0e:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
[ 12.510429] iwlwifi 0000:0e:00.0: api flags index 2 larger than supported by driver
[ 12.510438] iwlwifi 0000:0e:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
[ 12.510532] Bluetooth: hci0: Firmware timestamp 2024.18 buildtype 1 build 81528
[ 12.510753] iwlwifi 0000:0e:00.0: loaded firmware version 83.e8f84e98.0 ty-a0-gf-a0-83.ucode op_mode iwlmvm
[ 12.515571] usb 3-12.1: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[ 12.515609] Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
[ 12.515624] Bluetooth: hci0: Boot Address: 0x100800
[ 12.515625] Bluetooth: hci0: Firmware Version: 120-18.24
[ 12.515626] Bluetooth: hci0: Firmware already loaded
[ 12.522540] MCE: In-kernel MCE decoding enabled.
[ 12.532628] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 12.532676] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 12.532683] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 12.570942] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input23
[ 12.571000] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input24
[ 12.571051] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input25
[ 12.571096] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card1/input26
[ 12.571402] iwlwifi 0000:0e:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 12.571472] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 12.573917] usbcore: registered new interface driver uvcvideo
[ 12.578733] iwlwifi 0000:0e:00.0: WRT: Invalid buffer destination
[ 12.664961] EXT4-fs (nvme0n1p2): recovery complete
[ 12.665016] EXT4-fs (nvme0n1p2): mounted filesystem 54cbc6e5-f67c-4410-9d37-8f9df49aadb4 r/w with ordered data mode. Quota mode: none.
[ 12.722019] intel_rapl_common: Found RAPL domain package
[ 12.722023] intel_rapl_common: Found RAPL domain core
[ 12.734490] iwlwifi 0000:0e:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 12.734508] iwlwifi 0000:0e:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 12.734522] iwlwifi 0000:0e:00.0: WFPM_AUTH_KEY_0: 0x90
[ 12.734535] iwlwifi 0000:0e:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 12.734815] iwlwifi 0000:0e:00.0: loaded PNVM version 35148b80
[ 12.750612] iwlwifi 0000:0e:00.0: Detected RF GF, rfid=0x10d000
[ 12.819149] iwlwifi 0000:0e:00.0: base HW address: f0:d4:15:03:8e:cd
[ 12.833071] igb 0000:0c:00.0: added PHC on eth0
[ 12.833112] igb 0000:0c:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 12.833114] igb 0000:0c:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 98:b7:85:01:e3:3e
[ 12.833196] igb 0000:0c:00.0: eth0: PBA No: E43709-003
[ 12.833198] igb 0000:0c:00.0: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 12.833236] igb 0000:0c:00.1: enabling device (0000 -> 0002)
[ 12.925655] EXT4-fs (sda1): recovery complete
[ 12.926381] EXT4-fs (sda1): mounted filesystem e709cf55-e838-42dd-800f-7219b6b9e3a5 r/w with ordered data mode. Quota mode: none.
[ 12.949306] r8152-cfgselector 9-1.2.3: reset high-speed USB device number 7 using xhci_hcd
[ 13.078057] igb 0000:0c:00.1: added PHC on eth1
[ 13.078095] igb 0000:0c:00.1: Intel(R) Gigabit Ethernet Network Connection
[ 13.078096] igb 0000:0c:00.1: eth1: (PCIe:2.5Gb/s:Width x1) 98:b7:85:01:e3:3f
[ 13.078181] igb 0000:0c:00.1: eth1: PBA No: E43709-003
[ 13.078182] igb 0000:0c:00.1: Using MSI-X interrupts. 8 rx queue(s), 8 tx queue(s)
[ 13.079745] iwlwifi 0000:0e:00.0 wlp14s0: renamed from wlan0
[ 13.107344] igb 0000:0c:00.1 enp12s0f1: renamed from eth1
[ 13.122566] r8152 9-1.2.3:1.0: load rtl8153b-2 v2 04/27/23 successfully
[ 13.150521] igb 0000:0c:00.0 enp12s0f0: renamed from eth0
[ 13.199637] r8152 9-1.2.3:1.0 eth0: v1.12.13
[ 13.199658] usbcore: registered new interface driver r8152
[ 13.206464] usbcore: registered new interface driver cdc_ether
[ 13.208596] usbcore: registered new interface driver r8153_ecm
[ 13.298105] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.298107] Bluetooth: BNEP filters: protocol multicast
[ 13.298110] Bluetooth: BNEP socket layer initialized
[ 13.299194] Bluetooth: MGMT ver 1.22
[ 13.302696] NET: Registered PF_ALG protocol family
[ 13.346215] NET: Registered PF_QIPCRTR protocol family
[ 13.755960] r8152 9-1.2.3:1.0 enp22s0u1u2u3: renamed from eth0
[ 13.995492] usbcore: registered new interface driver snd-usb-audio
[ 15.604848] igb 0000:0c:00.0 enp12s0f0: igb: enp12s0f0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 16.086319] r8152 9-1.2.3:1.0 enp22s0u1u2u3: carrier on
[ 16.304587] igc 0000:0d:00.0 enp13s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 16.412123] igc 0000:0d:00.0 enp13s0: Force mode currently not supported
[ 18.691404] igb 0000:0c:00.0 enp12s0f0: igb: enp12s0f0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 19.758025] igc 0000:0d:00.0 enp13s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 24.787878] FS-Cache: Loaded
[ 24.790205] Key type dns_resolver registered
[ 24.851578] Key type cifs.spnego registered
[ 24.851589] Key type cifs.idmap registered
[ 24.851912] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
[ 24.851914] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.851915] CIFS: Attempting to mount //192.168.50.41/Wizzy/Pictures
[ 24.851971] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852041] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852044] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852046] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852047] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852058] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852060] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 24.852119] CIFS: enabling forceuid mount option implicitly because uid= option is specified
[ 25.064569] CIFS: Attempting to mount //192.168.50.41/Wizzy/Videos
[ 25.071242] CIFS: Attempting to mount //192.168.50.41/Download
[ 25.087493] CIFS: Attempting to mount //192.168.50.41/Music
[ 25.104060] CIFS: Attempting to mount //192.168.50.41/Wizzy/Desktop
[ 25.110555] CIFS: Attempting to mount //192.168.50.41/Cinema
[ 25.126686] CIFS: Attempting to mount //192.168.50.41/Wizzy/Downloads
[ 25.134123] CIFS: Attempting to mount //192.168.50.41/Public
[ 25.148882] CIFS: Attempting to mount //192.168.50.41/Wizzy/Documents
[ 25.155467] CIFS: Attempting to mount //192.168.50.41/Family
[ 25.308013] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 25.674377] vfio-pci 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=none
[ 25.674386] amdgpu 0000:15:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 27.729861] block nvme1n1: No UUID available providing old NGUID
[ 36.466988] usb 3-12.1: reset high-speed USB device number 6 using xhci_hcd
[ 37.779162] Bluetooth: RFCOMM TTY layer initialized
[ 37.779168] Bluetooth: RFCOMM socket layer initialized
[ 37.779170] Bluetooth: RFCOMM ver 1.11
[ 38.376106] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 138.407547] BTRFS info (device nvme0n1p1): first mount of filesystem 3d42b7b8-cb3c-4663-8736-ce9796a1da69
[ 138.407563] BTRFS info (device nvme0n1p1): using crc32c (crc32c-intel) checksum algorithm
[ 138.407567] BTRFS info (device nvme0n1p1): using free space tree
[ 138.422755] BTRFS info (device nvme0n1p1): enabling ssd optimizations
[ 138.422757] BTRFS info (device nvme0n1p1): auto enabling async discard
[ 138.645535] BTRFS info (device nvme0n1p1): last unmount of filesystem 3d42b7b8-cb3c-4663-8736-ce9796a1da69
