/dev/sda1 filesystem unknown
Hey guys. Today my friend tried to dual boot windows and manjaro on Dell Vostra 7590, but faced the following issue: in the manjaro installation guide it is said that /dev/sda1 on his machine has no filesystem (it is said “filesystem: unknown. Size is 128MB”, so he can’t mount it to /boot/efi as a boot loader. Of cource, he can format it to FAT32 and then mount /boot/efi, but this would brake Windows 10, wouldn’t it? If you have any suggessions, that would be great.
Can you boot Windows ?
Yeap, windows works perfectly
Look here to start with.
Can you post the partitioning and your /etc/fstab ?
@yistarostin Hi welcome to the forum please see:
Without enough good info no one will be able to assist you with your problem.
