So I am struggling from very slow shutdowns or reboots. This happens not ALL the time, for example if it happens and I restart my machine afterwards and then try to provoke the behaviour the shutdown/reboot is very fast. But if I used my machine for quite a while the shutdown makes a break for ~90ish seconds - so there must be some kind of timeout involved. How do I analyze the root cause of this behaviour? My question is not only targeted for the solution, but also letting me learn how to perform diagnostics…
Any help would be appreciated!
sudo inxi -Faz
Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=f8b3941a-e541-4f5d-b8d9-be01fa0cf445 ro quiet
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C84 v: 1.0 serial: N/A
Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: 1.70 date: 06/23/2021
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3400 min/max: 2200/5083 boost: enabled
base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400 28: 3400
29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217681
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1 bus-ID: 2f:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: HP ZR24w
serial: <filter> built: 2011 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: HP ZR24w
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 14.0.6 DRM 3.48 6.0.8-1-MANJARO) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 1-2:3 gen: 4 chip-ID: 152a:8750 speed: 16 GT/s class-ID: fe01
lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Thesycon System & Consulting GmbH DX3 Pro+ type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Mellanox MT27500 Family [ConnectX-3] driver: mlx4_core v: 4.0-0
pcie: gen: 3 speed: 8 GT/s lanes: 4 port: N/A bus-ID: 24:00.0
chip-ID: 15b3:1003 class-ID: 0200
IF: enp36s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-1: br10 state: down mac: <filter>
IF-ID-2: VLAN_30 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:5
Local Storage: total: 18.66 TiB used: 6.4 TiB (34.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
ZP2000GM30013 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: SU6SM001
temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 214d 14h cycles: 927
read-units: 23,226,159 [11.8 TB] written-units: 22,766,766 [11.6 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Seagate model: FireCuda 530
temp: 25.9 C scheme: GPT
SMART: yes health: PASSED on: 63d 1h cycles: 336
read-units: 2,232,997 [1.14 TB] written-units: 5,436,948 [2.78 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 512GB
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 22 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 178d 1h cycles: 3425
written: 93.63 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST16000NM001G-2KK103
family: Exos X16 size: 14.55 TiB block-size: physical: 4096 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: SN03
temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 197d 3h cycles: 853
read: 2.3 TiB written: 5.29 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 47.27 GiB (49.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:2
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 298 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:5
ID-3: /home raw-size: 1.72 TiB size: 1.7 TiB (98.37%)
used: 599.64 GiB (34.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:3
System Temperatures: cpu: 49.5 C mobo: 36.0 C gpu: amdgpu temp: 50.0 C
mem: 48.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 766 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 514 fan-7: 0 gpu: amdgpu fan: 0
Processes: 543 Uptime: 14m wakeups: 1 Memory: 62.72 GiB
used: 7.98 GiB (12.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1624 libs: 434 tools: pamac Shell: Bash (sudo) v: 5.1.16
running-in: konsole inxi: 3.3.23
