My laptop has a 2560 x 1440 built-in display. I usually connect the laptop to a 27-inch 2560 x 1440 external monitor via HDMI.
I use it as Single Display
with the external monitor only.
The following happens quite frequently:
When disconnecting the HDMI, using the laptop without the external monitor and then connecting back again, I see that online videos do not play as soon as I turn “on” the volume in the online service volume bar. Only when muting the volume, the video then plays.
See this quite explanatory video:
$ inxi -v7azy
Kernel: 5.10.167-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=75a0eed1-3787-4451-9020-fbb5e4209954 rw quiet apparmor=1
security=apparmor resume=UUID=1f35139c-62ba-45f9-afb4-8158f370195d
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 20N2S1PE00 v: ThinkPad T490
Mobo: LENOVO model: 20N2S1PE00 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: N2IET75W (1.53 )
date: 08/21/2019
ID-1: BAT0 charge: 18.7 Wh (44.7%) condition: 41.8/50.5 Wh (82.8%)
volts: 11.0 min: 11.5 model: SMP 02DL008 type: Li-poly serial: <filter>
status: discharging cycles: 714
RAM: total: 23.15 GiB used: 4.74 GiB (20.5%)
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 777 high: 1662 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 541 2: 551 3: 1662 4: 713
5: 700 6: 700 7: 700 8: 651 bogomips: 32012
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: HDMI-A-2 off: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony ThinkPad T490 Webcam type: USB driver: uvcvideo
bus-ID: 1-8:4 chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary model: HP Z27n G2
serial: <filter> built: 2019 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x2036 built: 2017
res: 2560x1440 dpi: 210 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 2560x1440
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound API: ALSA v: k5.10.167-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 394.18 GiB (82.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L7
lanes: 4 type: SSD serial: <filter> rev: 4M2QEXF7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 451.05 GiB size: 442.9 GiB (98.19%)
used: 394.18 GiB (89.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 75a0eed1-3787-4451-9020-fbb5e4209954
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F798-1318
ID-1: swap-1 type: partition size: 25.59 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 1f35139c-62ba-45f9-afb4-8158f370195d
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
chip-ID: 058f:9540 class-ID: 0b00
Device-2: 1-3:7 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA
chip-ID: 1bcf:0005 class-ID: 0301
Device-3: 1-4:8 info: HP Elite Keyboard type: Keyboard,HID
power: 100mA chip-ID: 03f0:034a class-ID: 0300
Device-4: 1-8:4 info: Chicony ThinkPad T490 Webcam type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-5: 1-9:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-6: 1-10:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C pch: 36.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 297 Uptime: 1h 15m wakeups: 34 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2100 libs: 482 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
