Desktop show blur recent activities on 4 corners
kde
#1
Hi,
I have some issue with my desktop. When I run apps, and switch to desktop, it show blur activities of my apps on 4 corners. I used KDE and my screen resolution is 2560x1440. It’s kind of weird. Details on my picture.
#2
That’s normal behavior from “Show Desktop” button/key shortcut. You can use the alternative of “Minimize all windows” to avoid it.
#3
Thanks for your answer, but I’m using KDE, no option “Minimize all windows”, just “Minimize window” and “Show Desktop”.
#4
Then that :man_shrugging:
#5
Thanks for your reply. I found the solution, just install Widget Minimize Windows and assign shortcut to it. Minimize window option just minimize one-by-one app, not what I want.
closed #6
