Desktop shortcut in manjaro pahvo gnome
Hi,
  1. Is there a shortcut key by default for search bar in the apps on the gnome desktop environment ?
  2. what is the name of file manager in this edition ?
The default file manager of GNOME is called Nautilus. I can’t answer your other question, though ─ I don’t use GNOME ─ but I’m sure somebody else will. :wink:
The package name is still nautilus, but it’s now called Files.
Tap Super once to open the Activities Overview and start typing to search. You can also tap it twice (or Super+A) to go straight to the Application menu.
See here for more:
https://wiki.gnome.org/Design/OS/KeyboardShortcuts
Thanks @yochanan & @Aragorn it works
