My laptop starts normally, with the display working. When I run the following command, my external monitor works, but my laptop display goes black. I can still see and move around the mouse cursor on the laptop display. If I lock my screen with i3lock, the laptop screen shows its regular contents again. When I unlock, it flashes the contents for a second, then returns to black.
xrandr --output DP-1-0 --scale 1x1 --mode 3840x1600 --above eDP-1 --output eDP-1 --mode 2560x1600
inxi --admin --verbosity=7 --filter --width:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=2ea59b10-ae23-4e87-a32b-cf15ef914681 rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd-intel-dspcfg.dsp_driver=1
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: Precision 5770 v: N/A
Mobo: Dell model: 087KND v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 03/08/2022
ID-1: BAT0 charge: 84.8 Wh (100.0%) condition: 84.8/95.1 Wh (89.2%)
volts: 12.9 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly serial: <filter>
status: full
RAM: total: 62.49 GiB used: 4.25 GiB (6.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x421
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2065 high: 3800 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3015 2: 950 3: 1282
4: 886 5: 396 6: 1027 7: 876 8: 2723 9: 3506 10: 2841 11: 3800 12: 3800
13: 2838 14: 2841 15: 2866 16: 2911 17: 1838 18: 723 19: 942 20: 1245
bogomips: 116780
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni
smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA104GLM [RTX A3000 Laptop GPU] vendor: Dell
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24bb
class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0c45:6a15 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x3200 s-dpi: 64 s-size: 1524x1270mm (60.00x50.00")
s-diag: 1984mm (78.1")
Monitor-1: DP-1-0 pos: primary,top res: 3840x1600 dpi: 111
size: 879x366mm (34.61x14.41") diag: 952mm (37.49") modes: N/A
Monitor-2: eDP-1 pos: primary,bottom res: 2560x1600 hz: 60 dpi: 178
size: 366x229mm (14.41x9.02") diag: 432mm (17") modes: N/A
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: br-a182e017d6ab state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: br-bf3edf1b45c3 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: veth2e0d7eb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth3f89f27 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth64341fe state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethf2838a9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 2.05 TiB used: 119.9 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: SK Hynix model: BC711 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41002131 temp: 29.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 119.9 GiB (6.5%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 2ea59b10-ae23-4e87-a32b-cf15ef914681
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 304 KiB
(0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: NO_LABEL
uuid: D41A-1FFC
ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 775 MiB fs: vfat label: ESP
uuid: F261-3CCC
ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 8 GiB fs: vfat label: OS
uuid: AE7A-1926
ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 229.72 GiB fs: ext4
label: UBUNTU uuid: 178dabb0-24a4-4910-aa23-55b057b90bed
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-9:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-3: 1-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 5-2:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Device-1: 5-2.1:3 info: ZSA Moonlander Mark I type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.1 speed: 12 Mb/s
power: 500mA chip-ID: 3297:1969 class-ID: 0300
Device-2: 5-2.2:4 info: Evoluent VerticalMouse D type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1a7c:0197 class-ID: 0301
Device-3: 5-2.4:5 info: LG USA Monitor Controls type: HID
chip-ID: 043e:9a39 class-ID: 0300 serial: <filter>
Hub-7: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 6-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-9: 7-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 8-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 416 Uptime: 7h 17m wakeups: 4151 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1494 nix-default: 0 nix-sys: 0 nix-usr: 227 lib: 65 pacman: 1267
lib: 332 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.20
xrandr:
Screen 0: minimum 320 x 200, current 3840 x 3200, maximum 16384 x 16384
eDP-1 connected primary 2560x1600+0+1600 (normal left inverted right x axis y axis) 366mm x 229mm
3840x2400 59.99 + 48.00
3840x2160 60.00 60.01 59.98 59.97
3200x1800 59.96 59.94
2880x1620 59.96 59.97
2560x1600 59.99* 59.97
2560x1440 59.99 59.99 59.96 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-1-0 connected 3840x1600+0+0 (normal left inverted right x axis y axis) 879mm x 366mm
3840x1600 74.98 + 59.99*
1920x1080 60.00 59.94
1280x720 59.94
1024x768 60.00
800x600 60.32
720x480 59.94
640x480 59.94 59.93
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
DP-1-6 disconnected (normal left inverted right x axis y axis)
DP-1-7 disconnected (normal left inverted right x axis y axis)
1024x768 (0x81) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x90) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0x9d) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
sudo mhwd -li:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
sudo dmesg | less shows many lines like the following:
[25385.381149] i915 0000:00:02.0: [drm] *ERROR* Fault errors on pipe A: 0x00000080
cat /proc/cmdline:
BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=[redacted] rw quiet apparmor=1 security=apparmor udev.log_priority=3 snd-intel-dspcfg.dsp_driver=1
