The desktop from my second monitor will sometimes not show up on my second monitor. The wallpaper doesn’t show, icons will not be able to be put on the second monitor, any existing icons are not there, and I cannot right click on the right monitor to pull up the menu. Most of the time, the second monitor’s desktop will display on top of desktop on the primary monitor’s desktop, but slid up a few hundred pixels. And its not just the wallpapers, the icons from the second monitor’s desktop will be where they supposed to be in relation to the wallpaper, and the primary monitor’s desktop icons will be covered up by the second monitor’s desktop wall paper too.
Based on past posts, I thought it may have been the global theme or certain default wallpapers being corrupt, but with default global theme (and I did try with and without the “Use desktop layout from theme” option) and custom added wallpapers (I also tried with default wallpapers), It still does the same thing. It also isn’t a kernal thing because it happens in 5.4 and 5.10.
Kernel: 5.10.13-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=fb76771e-c2fb-45f6-938a-5029c1b414d0 rw quiet apparmor=1
security=apparmor resume=UUID=34903fdd-2ada-44e8-af4d-0b4ea0dd20fd
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 3103 date: 06/17/2020
RAM: total: 31.35 GiB used: 2.44 GiB (7.8%)
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 4 MiB
bogomips: 102242
Speed: 2413 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 2413 2: 1368 3: 1342 4: 1342 5: 1373 6: 1369 7: 1375 8: 1374 9: 1336
10: 1336 11: 1375 12: 1375 13: 1371 14: 1375 15: 3003 16: 1358
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia
v: 460.39 alternate: nouveau,nvidia_drm bus ID: 08:00.0 chip ID: 10de:1b80
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1530 s-dpi: 107 s-size: 1216x363mm (47.9x14.3")
s-diag: 1269mm (50")
Monitor-1: DVI-D-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-4 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 08:00.1 chip ID: 10de:10f0
class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0a:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-1:2 chip ID: 046d:082c class ID: 0e02 serial: <filter>
Device-4: VIA FX-AUDIO-DAC-X6 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-3:3 chip ID: 040d:340b
class ID: 0300
Sound Server: ALSA v: k5.10.13-2-MANJARO
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: e000 bus ID: 03:00.0 chip ID: 8086:1539 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
bus ID: 07:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp7s0 state: up mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-9:4
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 4.66 TiB used: 467.81 GiB (9.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 96R9
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS200T2B0A-00SM50 size: 1.82 TiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 40WD
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD110 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: A8J0
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM006-2DM164
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: CC26
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH16NS40 rev: 1.02
dev-links: cdrom
ID-1: / raw size: 102.69 GiB size: 100.58 GiB (97.94%)
used: 90.96 GiB (90.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: fb76771e-c2fb-45f6-938a-5029c1b414d0
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0438-46FB
ID-3: /gaming raw size: 2.73 TiB size: 2.71 TiB (99.18%)
used: 376.85 GiB (13.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: vg0-bulk label: N/A uuid: N/A
Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 34903fdd-2ada-44e8-af4d-0b4ea0dd20fd
ID-1: /dev/sdb1 maj-min: 8:17 size: 579 MiB fs: ntfs label: System Reserved
uuid: 9E2009F92009D8E3
ID-2: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: N/A
uuid: 429C0BF89C0BE56F
ID-3: /dev/sdb3 maj-min: 8:19 size: 100 MiB fs: vfat label: N/A
uuid: AA6B-5E16
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Logitech HD Webcam C615 type: Audio,Video
Device-2: 1-5:3
info: Corsair CORSAIR K70 RGB MK.2 SE Mechanical Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 1b1c:1b6b class ID: 0300 serial: <filter>
Device-3: 1-9:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029 class ID: e001
Device-4: 1-10:5 info: Corsair H100i v2 type: <vendor specific> driver: N/A
interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 1b1c:0c09 class ID: 0000
serial: <filter>
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
chip ID: 046d:c08b class ID: 0300 serial: <filter>
Device-2: 3-3:3 info: VIA FX-AUDIO-DAC-X6 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s chip ID: 040d:340b class ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.2 C mobo: N/A gpu: nvidia temp: 41 C
Processes: 332 Uptime: 17m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1521 lib: 447 flatpak: 0
Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.3.00
