I just installed manjaro linux and whenever I connect to a wifi the whole system freezes after some time. If I connect to internet via usb tethering then nothing happens. I have tried installing vanilla arch and same thing happened, but pop os and fedora didn’t have this issue. I am not sure if it is arch related or device specific. so please help !! thank you
Hi! If you want help you need to provide error logs, system details. No one has crystal ball
I am not sure what logs to show and I think I have pinpointed the issue. It happens when I am connected to wifi and do an update or install with pacman. If I do similar thing when on USB tethering then nothing happens and pacman does it’s thing. Please help !!
Please show
inxi -Fmazy
for a start, and
journalctl -p 3 -xb
If freezes are total and you need to restart your computer, show previous boot errors by command:
journalctl -p 3 -xb -b -1
Don’t forget to use Preformatted text brackets before you send your post so command output is nice and tidy.
Thanks for the information actually I re-installed the OS with LTS kernel which seemed to have removed the freezes but there still are some spikes where I am not able to do anything for 5 secs. I also found some Internal clock never stabilised
messages in the journalctl
Thank you again and please help me out
$ inxi -Fazy
Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=309ca3ff-c802-4b03-afa7-a70610060e41 ro quiet udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude E5430 non-vPro v: 01
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0MYF02 v: A00 serial: <filter> UEFI: Dell v: A12
date: 08/07/2013
ID-1: BAT0 charge: 16.0 Wh condition: 33.4/48.8 Wh (68%) volts: 11.3/11.1
model: Samsung SDI DELL P8TC727 type: Li-ion serial: <filter>
status: Discharging
Info: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21538
Speed: 1265 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1265 2: 1261
3: 1197 4: 1240
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Microdia Laptop_Integrated_Webcam_E4HD type: USB driver: uvcvideo
bus ID: 1-1.5:5 chip ID: 0c45:6449
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.89-1-MANJARO
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
driver: wl v: kernel modules: bcma port: f040 bus ID: 02:00.0
chip ID: 14e4:4727
Device-2: Broadcom NetXtreme BCM5761 Gigabit Ethernet PCIe vendor: Dell
driver: tg3 v: 3.137 port: f040 bus ID: 0c:00.0 chip ID: 14e4:1681
IF: enp12s0 state: down mac: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 04
Local Storage: total: 494.4 GiB used: 6.74 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500VT000-1DK142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: SDC1
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00
ID-1: / raw size: 463.26 GiB size: 463.26 GiB (100.00%)
used: 6.71 GiB (1.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 688 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 2 GiB used: 22.2 MiB (1.1%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 52.0 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2778
Processes: 239 Uptime: 1h 38m wakeups: 7 Memory: 3.72 GiB
used: 2.36 GiB (63.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 977 lib: 270 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.2.02
$ sudo dmesg -l emerg,alert,crit,err,warn
[ 0.700917] i8042: Warning: Keylock active
[ 0.760560] mmc0: Internal clock never stabilised.
[ 0.760561] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.760572] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.760582] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.760593] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.760604] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.760615] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.760626] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 0.760637] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.760647] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.760657] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.760668] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.760677] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.760688] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.760698] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.760703] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.760704] mmc0: sdhci: ============================================
[ 0.780745] mmc0: Internal clock never stabilised.
[ 0.780746] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.780757] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.780766] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.780777] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.780788] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.780799] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.780810] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 0.780821] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.780831] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.780842] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.780850] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.780859] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.780870] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.780880] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.780886] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.780886] mmc0: sdhci: ============================================
[ 0.843960] mmc0: Internal clock never stabilised.
[ 0.843961] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.843973] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.843983] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.843994] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.844006] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.844016] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.844027] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 0.844038] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.844048] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.844059] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.844070] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.844081] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.844092] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.844102] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.844107] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.844107] mmc0: sdhci: ============================================
[ 0.864137] mmc0: Internal clock never stabilised.
[ 0.864138] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.864149] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.864160] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.864169] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.864180] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.864190] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.864201] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 0.864211] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.864223] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.864234] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.864244] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.864255] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.864266] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.864277] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.864283] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.864283] mmc0: sdhci: ============================================
[ 0.927298] mmc0: Internal clock never stabilised.
[ 0.927300] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.927308] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.927318] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.927328] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.927339] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.927350] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.927361] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00002003
[ 0.927372] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.927383] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.927394] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.927402] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.927412] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.927421] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.927432] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.927437] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.927437] mmc0: sdhci: ============================================
[ 0.947474] mmc0: Internal clock never stabilised.
[ 0.947475] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 0.947486] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 0.947497] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 0.947507] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 0.947517] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 0.947528] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 0.947537] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00002003
[ 0.947548] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 0.947558] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 0.947566] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 0.947588] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 0.947596] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 0.947607] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 0.947617] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 0.947623] mmc0: sdhci: Host ctl2: 0x00000000
[ 0.947623] mmc0: sdhci: ============================================
[ 1.010619] mmc0: Internal clock never stabilised.
[ 1.010621] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 1.010632] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 1.010643] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 1.010654] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 1.010665] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 1.010676] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 1.010685] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004003
[ 1.010695] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 1.010706] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 1.010716] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 1.010727] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 1.010738] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 1.010748] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 1.010767] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 1.010775] mmc0: sdhci: Host ctl2: 0x00000000
[ 1.010776] mmc0: sdhci: ============================================
[ 1.030801] mmc0: Internal clock never stabilised.
[ 1.030802] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 1.030813] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 1.030823] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 1.030833] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 1.030852] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 1.030862] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 1.030872] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004003
[ 1.030880] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 1.030890] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 1.030900] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 1.030910] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 1.030921] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 1.030931] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 1.030942] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 1.030947] mmc0: sdhci: Host ctl2: 0x00000000
[ 1.030947] mmc0: sdhci: ============================================
[ 11.446921] i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[ 11.554368] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[ 11.554380] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 11.554385] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 11.554389] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 11.554392] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 11.596122] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 12.008558] dell-smbios PNP0C14:00-A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[ 12.219050] wl: loading out-of-tree module taints kernel.
[ 12.219055] wl: module license 'MIXED/Proprietary' taints kernel.
[ 12.219055] Disabling lock debugging due to kernel taint
[ 12.570273] wlan0: Broadcom BCM4727 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 15.116895] kauditd_printk_skb: 4 callbacks suppressed
[ 30.212292] proc: Bad value for 'hidepid'
[ 30.872713] proc: Bad value for 'hidepid'
[ 37.260222] proc: Bad value for 'hidepid'
[ 37.335348] kauditd_printk_skb: 16 callbacks suppressed
[ 262.178451] proc: Bad value for 'hidepid'
[ 262.210226] proc: Bad value for 'hidepid'
[ 262.314237] kauditd_printk_skb: 4 callbacks suppressed
[ 265.682695] proc: Bad value for 'hidepid'
[ 587.274152] proc: Bad value for 'hidepid'
[ 699.464978] proc: Bad value for 'hidepid'
[ 835.573929] proc: Bad value for 'hidepid'
[ 1005.582731] proc: Bad value for 'hidepid'
[ 1146.272732] proc: Bad value for 'hidepid'
[ 1195.204527] proc: Bad value for 'hidepid'
[ 1231.537908] proc: Bad value for 'hidepid'
[ 1412.002716] proc: Bad value for 'hidepid'
[ 1774.295545] proc: Bad value for 'hidepid'
[ 2243.258440] proc: Bad value for 'hidepid'
[ 2372.378307] proc: Bad value for 'hidepid'
[ 2480.110723] proc: Bad value for 'hidepid'
[ 2532.488831] proc: Bad value for 'hidepid'
[ 2699.269542] proc: Bad value for 'hidepid'
[ 2815.496610] kauditd_printk_skb: 98 callbacks suppressed
[ 2834.033544] kauditd_printk_skb: 117 callbacks suppressed
[ 2881.030966] ERROR @wl_cfg80211_scan :
[ 2881.030968] WLC_SCAN error (-22)
[ 3650.212013] ERROR @wl_cfg80211_scan :
[ 3650.212015] WLC_SCAN error (-22)
[ 3767.685688] proc: Bad value for 'hidepid'
[ 3827.224868] proc: Bad value for 'hidepid'
[ 4054.058905] proc: Bad value for 'hidepid'
$ journalctl --since “2 days ago” -p “emerg”…"err"
-- Journal begins at Mon 2021-02-01 09:44:07 IST, ends at Mon 2021-02-01 11:30:46 IST. --
Feb 01 09:44:07 havoc kernel: mmc0: Internal clock never stabilised.
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Host ctl2: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ============================================
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00002003
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004003
Feb 01 09:44:28 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:44:35 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:15 havoc gdm-password][1484]: gkr-pam: unable to locate daemon control file
Feb 01 09:48:20 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:20 havoc sudo[1802]: pam_unix(sudo:auth): conversation failed
Feb 01 09:48:20 havoc sudo[1802]: pam_unix(sudo:auth): auth could not identify password for [retr>
Feb 01 09:48:23 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:24 havoc pipewire[1978]: Failed to receive portal pid: org.freedesktop.DBus.Error.Na>
Feb 01 09:50:23 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:51:24 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:52:36 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:53:45 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:54:53 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:55:37 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:56:31 havoc systemd[1494]: Failed to start Application launched by gnome-shell.
Feb 01 09:56:52 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:57:53 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:58:19 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:17 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:35 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:43 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:01:20 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:02:35 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:03:00 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:03:04 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:03:49 havoc systemd-coredump[2942]: Process 2606 (gjs) of user 1000 dumped core.
Stack trace of thread 2606:
#0 0x00007f1955c83d86 n/a (libgtk-3.so.0 + 0x29ad8>
#1 0x00007f195ab4343c g_cclosure_marshal_VOID__FLA>
#2 0x00007f195ab6198a g_signal_emit_valist (libgob>
#3 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#4 0x00007f1955d2ffa0 n/a (libgtk-3.so.0 + 0x346fa>
#5 0x00007f1955d212d8 n/a (libgtk-3.so.0 + 0x3382d>
#6 0x00007f1955c84d10 gtk_switch_set_state (libgtk>
#7 0x00007f1955c84f6e n/a (libgtk-3.so.0 + 0x29bf6>
#8 0x00007f1955a6dcac n/a (libgtk-3.so.0 + 0x84cac)
#9 0x00007f195ab6198a g_signal_emit_valist (libgob>
#10 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#11 0x00007f1955c84900 gtk_switch_set_active (libgt>
#12 0x00007f195ab4d6cf n/a (libgobject-2.0.so.0 + 0>
#13 0x00007f195ab54dac g_object_setv (libgobject-2.>
#14 0x00007f195ab54e7c g_object_set_property (libgo>
#15 0x00007f195aa5ef95 n/a (libgio-2.0.so.0 + 0xe8f>
#16 0x00007f195ab45052 g_closure_invoke (libgobject>
#17 0x00007f195ab6d9c5 n/a (libgobject-2.0.so.0 + 0>
#18 0x00007f195ab6159d g_signal_emit_valist (libgob>
#19 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#20 0x00007f195aa52673 n/a (libgio-2.0.so.0 + 0xdc6>
#21 0x00007f195a9e2325 n/a (libgio-2.0.so.0 + 0x6c3>
#22 0x00007f195ab6198a g_signal_emit_valist (libgob>
#23 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#24 0x00007f195aa53eaf n/a (libgio-2.0.so.0 + 0xdde>
#25 0x00007f195aa4ed8b n/a (libgio-2.0.so.0 + 0xd8d>
#26 0x00007f195abdc155 g_main_context_invoke_full (>
#27 0x00007f195aa4f511 n/a (libgio-2.0.so.0 + 0xd95>
#28 0x00007f195400f498 n/a (libdconfsettings.so + 0>
#29 0x00007f195400f772 n/a (libdconfsettings.so + 0>
#30 0x00007f195aaa468b n/a (libgio-2.0.so.0 + 0x12e>
#31 0x00007f195aa5f333 n/a (libgio-2.0.so.0 + 0xe93>
#32 0x00007f195ab45052 g_closure_invoke (libgobject>
#33 0x00007f195ab6d9c5 n/a (libgobject-2.0.so.0 + 0>
#34 0x00007f195ab6159d g_signal_emit_valist (libgob>
#35 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#36 0x00007f195ab4bf76 n/a (libgobject-2.0.so.0 + 0>
#37 0x00007f195ab4d242 g_object_notify_by_pspec (li>
#38 0x00007f1955c84910 gtk_switch_set_active (libgt>
#39 0x00007f1955c84a76 n/a (libgtk-3.so.0 + 0x29ba7>
#40 0x00007f1955d1f316 n/a (libgtk-3.so.0 + 0x33631>
#41 0x00007f195ab6198a g_signal_emit_valist (libgob>
#42 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
#43 0x00007f195592a05d n/a (libgdk-3.so.0 + 0x4005d)
#44 0x00007f19559178ac n/a (libgdk-3.so.0 + 0x2d8ac)
#45 0x00007f195abdd2c4 n/a (libglib-2.0.so.0 + 0x53>
...skipping...
Feb 01 10:47:45 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:48:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:51:23 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:51:32 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:51:58 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:52:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:53:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:53:53 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:54:34 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:55:42 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:56:57 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:57:51 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:01:07 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:02:20 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:02:49 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:03:40 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:04:37 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:05:11 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:09:51 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:10:59 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:14:36 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:16:10 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:16:44 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:20:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:24:11 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
lines 314-338/338 (END)
Can you show
lspci -kv
lsusb -t
sudo fdisk -l
lspci -kv
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Dell Device 053c
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: ivb_uncore
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 35
Memory at f6400000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI])
Flags: medium devsel, IRQ 32
Memory at f7f00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at f7f1b000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
Flags: medium devsel, IRQ 16
Memory at f7f18000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at f7f10000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: f7e00000-f7efffff [size=1M]
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=00, secondary=03, subordinate=06, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f7200000-f7bfffff [size=10M]
Prefetchable memory behind bridge: 00000000f0a00000-00000000f13fffff [size=10M]
00:1c.3 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=07, subordinate=0a, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: f6800000-f71fffff [size=10M]
Prefetchable memory behind bridge: 00000000f0000000-00000000f09fffff [size=10M]
00:1c.5 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 6 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: f7d00000-f7dfffff [size=1M]
00:1c.6 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 7 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31
Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
Memory behind bridge: f7c00000-f7cfffff [size=1M]
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
Flags: medium devsel, IRQ 21
Memory at f7f17000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
Flags: bus master, medium devsel, latency 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 04)
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 33
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f7f16000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
Flags: medium devsel, IRQ 18
Memory at f7f15000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4313 802.11bgn Wireless Network Adapter (rev 01)
Subsystem: Dell Device 0015
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7e00000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: wl
Kernel modules: bcma, wl
0b:00.0 SD Host controller: O2 Micro, Inc. OZ600FJ0/OZ900FJ0/OZ600FJS SD/MMC Card Reader Controller (rev 05) (prog-if 01)
Memory at f7d00000 (32-bit, non-prefetchable) [size=512]
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
0c:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 37
Memory at f7c10000 (64-bit, non-prefetchable) [size=64K]
Memory at f7c00000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: tg3
Kernel modules: tg3
lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 4: Dev 4, If 2, Class=Vendor Specific Class, Driver=, 12M
|__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=btusb, 12M
|__ Port 4: Dev 4, If 3, Class=Application Specific Interface, Driver=, 12M
|__ Port 4: Dev 4, If 1, Class=Vendor Specific Class, Driver=btusb, 12M
|__ Port 5: Dev 5, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 5, If 1, Class=Video, Driver=uvcvideo, 480M
sudo fdisk -l
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: ST500VT000-1DK14
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: A32E9E13-8D7D-4D2B-A494-D55B1331D1E2
Device Start End Sectors Size Type
/dev/sda1 2048 1050623 1048576 512M EFI System
/dev/sda2 1050624 5244927 4194304 2G Linux swap
/dev/sda3 5244928 976773134 971528207 463.3G Linux root (x86-64)
Did you had any SD cards inserted at any time recently?
does connecting a phone count ?
This is error message followed by error dump when some kind of SD card was inserted. I could be a phone.
Any ideas on how to reproduce it so I can verify if it is phone memerycard or not?
Plug in the phone And watch for new errors.
Will do !! I will let u know if something comes up
